Adjusting Laptop Brightness Via Flowstone!
Published
Introduction: Adjusting Laptop Brightness Via Flowstone!
About: Update 12 September 2017: A very special thanks to Sam Elder, a manager here at Instructables, who tracked down the cause of my lost publications and fixed the issue. Take a bow Sam!
For an embedded automation system I'm creating, I need to adjust the screen brightness quickly via a touchscreen interface. The computer is actually a touchscreen netbook that can flip right around. I won't have access to the keyboard to press the hotkeys that alter brightness.
Read on for how I achieved this in a very diy fashion.
Step 1: Nircmd.exe
This neat program allows me to easily change screen brightness via the command prompt. To use it, just download from its homepage and run nircmd.exe.
It will ask you to copy to the Windows directory and you should allow it to.
Step 2: Implementing in Flowstone.
I used a Slider in Flowstone to give a float value from 0 to 1. Using some maths I made this into an integer from 0 to 100. In the screenshots you will see the command prompt to allow nircmd to change screen brightness.
At the top of the slider the netbook screen will go fully bright. At the bottom the back light will be off. Very cool and versatile!
Step 3: Auto Brightness.
Using a labjack u3 hv, I used a photocell to allow dynamic adjustment of the screen so I don't have to manually adjust the slider.
Very cool!
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
    2 Comments
    I didn't know flowstone, many thanks!
