Adorable Wire Cat Earrings DIY
2,042
41
Posted in CraftJewelry
Introduction: Adorable Wire Cat Earrings DIY
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about...
Cat lovers should try this adorable wire wrapped earrings!
Step 1: Materials Needed in Wire Cat Earrings:
2mm Golden Seed Beads
8mm Blue Cat Eye Beads
Silver Copper Wire EPS4.Ocm-0.8mm
Aluminum Wire AW10×1.5cm
0.3mm, 0.5mm Golden Copper Wire
Eye Pins EPS4.0cm
Flat Nose Plier
Side Cutting Plier
Round Nose Plier
Step 2: Make the Shape of Cat’s Face
1st, cut off aluminum wire as the length of about 130mm;
2nd, wrap it to form the shape of cat face as the pictures showed below.
Step 3: Add Eyes and Whisker to Her Face
1st, use the blue cat eye beads to be the eyes of the adorable cat;
2nd, slide a golden seed bead with the silver copper wire to be the nose of it;
3rd, thread three 0.5mm golden copper wire to the “nose” to be its whisker. (Each of the copper wire is 15mm) Then you can see, a cute wire cat is in front of you.
Step 4: Make a Dangle Link
1st, thread beads with an eye pin
2nd, make a loop at the other end of the eye pin as picture shows.
Step 5: Finish the Handmade Cat Jewelry
Tutorial source: http://lc.pandahall.com/articles/2327-handmade-cat-jewelry-idea-how-to-make-adorable-wire-cat-earrings-diy-with-cat-eye-beads.html
    • Spotless Contest
      Spotless Contest
    • Flowers Challenge
      Flowers Challenge
