3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Enable Advance mode on eee PC 701
I will show you in this tutorial, how to change from easy mode to advance mode on the eee PC.
I am NOT responsible for any damage or loss of data
Step 1Open the "Terminal"
Open the \"Terminal\"
To open the "Terminal" in easy mode press "Ctrl-Alt-T". Now type in "sudo bash" to gain administrative power.
28 comments
Sep 6, 2008. 9:28 PMpeach_fart says:
i did this just right now and i already like it. but it wont launch frets on fire...
Jun 8, 2011. 5:16 PMpeach_fart says:
so i got frets on fire to launch (3 years later. i wasnt in a hurry to get it) and i had to do a f9 restore after installing the necessary packages. dont get it its not worth the hassle
Sep 7, 2008. 10:27 AMpeach_fart says:
im not sure if its xandros, it says that it cant find some file so it never boots up, it just has a thing that displays what files are loaded
Sep 20, 2008. 12:59 AMpeach_fart says:
i was bored so i tried to put it on from eeeuser, but it didnt load when i opened it
Jul 4, 2010. 5:31 AMLance Mt. says:
So what distro ARe you using?
Dec 25, 2010. 5:32 PMCapnChkn says:
Yeah, I'm stuck. Is that the stock Xandros that comes with the old 701? Honestly it was so useless I put Ubuntu on a Flash drive and installed that.
I also dropped the Netbook version. It was full of fancy stuff and I couldn't get anything done. If Xandros, the "advanced" mode was something similar to the classic desktop Ubuntu.
Jul 29, 2010. 11:20 PMLance Mt. says:
Then what distro is that? ^^^^^^^^
May 30, 2008. 4:44 PMgamer says:
Haha, the EEEPC here where I live comes with Vista... Odd... Oh well
Sep 7, 2008. 10:53 AMpeach_fart says:
what are the specs on it?(hard drive, RAM, video, processor speed, etc.)
Sep 8, 2008. 2:29 PMgamer says:
I don't know, I would actually have to check....
Ok.... Click Here to get the specs from The Source...
On this page, it says that it comes with Windows XP, but I did see one with Vista on it though....
-gamer
Sep 20, 2008. 11:44 AMmondaymonkey says:
To run vista w/ Aero desktop (Don't bother getting vista unless you like translucent windows), you NEED at least 1.5 gbs of RAM to do anything... My laptop runs about 1.25 gbs at standstill with no programs open.
Sep 5, 2009. 8:34 AMxc1024 says:
I think you don't even actually need vista to have transparent windows. If you install Compiz Fusion or something similar on the Linux system that came with the laptop, you should get transparent windows, "wobbly" windows, cube when changing desktops and all this stuff. Assuming it is possible to install Compiz on that, because the laptop's distro may have a different structure and/or contain hacks that provide certain functionality in a way different from standard, so Compiz may not be able to use it in this case. However I think it should be possible in most cases. AND it doesn't use up 1.25GB of ram when doing nothing. That solution would be way more wallet-saving and sanity-saving (you don't have to spend extra money on vista version and you don't have to put up with the system slowness.)
Sep 13, 2008. 10:10 PMpeach_fart says:
it just has the normal eee pc specs but its got xp....
Mar 7, 2009. 2:45 PMmspark400 says:
Nice ible! It got me working on my eee pc (2g surf) and used this link in easy mode to successfully switch to advanced mode without a hitch!
Advance mode makes my eee pc so much more useful!
cheers,
Mspark400
Oct 9, 2008. 11:35 AMDr. Monkey says:
Good one, thanks!
Sep 14, 2008. 3:48 AMelliot81 says:
I put XP on my brothers as soon as i got it using a bootable XP from a usb i made
Jun 19, 2008. 1:40 PMKiteman says:
In what way is the advanced mode advanced?
Sep 6, 2008. 9:21 PMpeach_fart says:
it has a desktop
Jun 5, 2008. 11:48 PMhobbyman says:
hello and thanks for the info. I'll go and switch to advanced mode right away. the simple mode seems so childish and gives the sensation of not having full control on your eeepc. I need to run proteus electronics design package (labcenter.co.uk) and the CCS C compiler (for microcontrollers ccsinfo.com) to my EEEPC 900. For this i've tried to install XP yesterday. It took me 6 hours trying two different methods foun on th enet and none were successful. it was good to be able to at least revert to the original linux OS in 5 minutes. I want to install the wine for linux. I've downloaded some packages don't know how to install them. Any links of "how to?" or any recommendations ? thanks
May 30, 2008. 10:51 PMac1D says:
if i had know we could switch to the normal linux gui, i would never had downgraded to windows!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Gavabc123
Hi!
