PLEASE DIRECT ANY QUESTIONS YOU MAY HAVE TO MY BLOG:
http://tamsanh.com/blog/2008/07/11/batch-tutorial-3-advanced-batch/
I do not visit instructables anymore, and you will get a faster response that way.
Hey Guys! Tam Nguyen here. It's been a long time coming, but it's here now! I present to you the next instalment of my Batch Tutorials!
You may (or may not) have read my other instructables:
Basics of Batch
Slightly More Advanded Batch
This Instructable borrows some elements from the first two Instructables. Namely:
ECHO Command
CD Command
DIR Command
If you have not read the other two, I suggest looking over those commands right-quick. I'll wait here.
Ok!
By the end of this Instructable, you will be intimate with:
START Command
SET Command
IF Command
GOTO Command
and
> and >> Parameters
With these commands, you will be able to make dynamic batch files which can change according to user input, and create and expand.
So let's open up that good 'ol Command Prompt and get started!
Run -> cmd
Alternatively, you can go to:
Start->Program Files->Accessories->Command Prompt
My explainations in this instructable got a little long, so I've split up some commands into more than one page mainly for aesthetic purposes; I liked seeing the pictures while reading the text without having to scroll up and down.
Rule of thumb for picture viewing; Usually after every Code Snippet, there is a picture.
Enjoy!
Step 1: START Command
The START Command is a nice little command which starts stuff!
It's a simple command, and will help us warm up before we get to the harder commands.
The parameters of the command are exactly what you think they are.
START ThingToBeStarted.exe
Pretty simple.
START WMPlayer.exe
Not only can you START .exe's, you can also type a website in, and it will open up in your default browser!
START www.Instructables.com
Pretty easy, eh? Ok. Now let's move on to the real meat of the Instructable: SET Command.
1-40 of 154Next »
nasir geelani says: Mar 26, 2013. 8:12 PM
thanx pro neodudeman and all programmers thanx for all these instructibles
el-xavi26 says: Sep 8, 2012. 2:41 PM
How do i make a line so then somebody could write on batch please answer
Prof. Pickle in reply to el-xavi26Dec 19, 2012. 8:04 PM
ATTRIB +R Script.bat
The above should work, but it's not hole proof and any slightly technically savvy person can undo it.
Gonads says: Feb 12, 2010. 1:20 AM
 hey for the %random% you can change the range.. try this:
set /a random=%random%/327.67
now range is between 1 - 100
Prof. Pickle in reply to GonadsDec 13, 2012. 9:51 PM
Well, actually, there is a much easier way to do that.
In the Command Prompt: set /a number=%random% % max + min
Example: set /a dice=%random% % 6 + 1
In a batch script: set /a number=%random% %% max + min
Example: set /a dice=%random% %% 6 + 1
Oh, and setting the variable named "random" as %random% is not wise, as it will stop you using "%random%" again, as it would just be calling the pre-set variable.
TehTechnicalGuy says: Jun 18, 2012. 6:11 AM
Hem hem. Here it is an animation box, thank you.
@echo off
setlocal enabledelayedexpansion
set Counter=0
set Schalter=2
set Width=0
:: The weird symbols are replaced by lines in the CMD-window
:: All options that are marked by a little point are finite
:: --- All the others are unfinite, the program has to be closed by X to
:: view another animation
:: --- "c4: Star Wars" is not infinite, but it takes quite a lot time
:Start
call :ResetVariables
title Animation Box
mode con cols=80 lines=25
echo ÉÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍËÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍËÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ»
echo ºú1: Installation ³ú 9: Arrow left ºúc1: 1min º
echo º 2: Slow loading ³ú10: Arrow right ºúc2: 2009 º
echo º 3: Fast loading ³ 11: Skull º c3: Bat disco º
echo º 4: Big loading ³ú12: Dos Techno Virusº c4: Star Wars º
echo ÌÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÎÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄĹ
echo º 5: Matrix ³ú13: Winhound ºúm1: Matrix part 1 º
echo º 6: Epilepsy ³ú14: Expand window ºúm2: Matrix part 2 º
echo ºú7: Naked woman ³ ºúm3: Matrix part 3 º
echo º 8: Fill window ³ ºúm4: Matrix part 4 º
echo ÈÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÊÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÊÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍͼ
set /p choice=--^>
cls
if "%choice%" == "5" set Schalter=
call :%choice%
goto :Start
:: "Counter" is the amount of finished %, yet (at last 100%)
:: "Display" is the progress bar
:: --- This bar consists of the half of the %-amount (at last 50)
:: --- The bar moves from left to right
:1
title Animation Box - Installation
set /a Counter=%Counter% + 1
set /a Display=%Counter% / 2
FOR /L %%A IN (1,1,%Display%) DO (
set Display=!Display!²
cls
echo New files are copied... %Counter%%%
echo ²!Display:~2,47!
ping localhost -n 1 >nul
if "%Counter%" == "100" goto :1-End
goto :1
:1-End
echo.
echo Installation complete.
pause >nul
EXIT /B
:2
cls
title Animation Box - Slow loading
echo Opening file.
echo.
echo I I
cls
echo Opening file.
echo.
echo I² I
cls
echo Opening file.
echo.
echo I ² I
cls
echo Opening file.
echo.
echo I² ² I
cls
echo Opening file.
echo.
echo I ² ² I
cls
echo Opening file.
echo.
echo I² ² ² I
cls
echo Opening file.
echo.
echo I ² ² ² I
cls
echo Opening file.
echo.
echo I ² ² ² I
cls
echo Opening file.
echo.
echo I ² ² ² I
cls
echo Opening file.
echo.
echo I ² ² ² I
cls
echo Opening file.
echo.
echo I ² ² ² I
cls
echo Opening file.
echo.
echo I ² ² ² I
cls
echo Opening file.
echo.
echo I ² ² ² I
cls
echo Opening file.
echo.
echo I ² ² ²I
cls
echo Opening file.
echo.
echo I ² ² I
cls
echo Opening file.
echo.
echo I ² ²I
cls
echo Opening file.
echo.
echo I ² I
cls
echo Opening file.
echo.
echo I ²I
cls
goto :2
:: "Counter" determines the length of the row
:: "Display" is the row
:: "Schalter 1" = From left to right
:: "Schalter 2" = From right to left
:3
title Animation Box - Fast loading
cls
echo [!Display!]
set Display=
if "%Counter%" == "0" set Schalter=1
if "!Schalter!" == "1" set /a Counter=%Counter% + 1
if "%Counter%" == "41" set Schalter=2
if "!Schalter!" == "2" set /a Counter=%Counter% - 1
if "!Schalter!" == "1" FOR /L %%A IN (1,1,%Counter%) DO set Display=!Display!±
if "!Schalter!" == "1" FOR /L %%A IN (%Counter%,1,40) DO set Display=!Display!
if "!Schalter!" == "2" FOR /L %%A IN (1,1,%Counter%) DO set Display=!Display!
if "!Schalter!" == "2" FOR /L %%A IN (%Counter%,1,40) DO set Display=!Display!±
goto :3
:: The subpoint "4_DisplaySpace" is used to compress the animation's size in the file.
:: The FOR-part in the middle of the animation is used for the same reason.
:: --- It counts the amount of spaces between the left stars and the loadbar, and
:: between the right stars and the loadbar.
:: --- There are at last 65 spaces.
:: --- The entire animation counts 79 columns. The loadbar is 11 columns wide.
:: From the left 68 columns, 2 are the stars at the left and the right.
:: 66 columns left, 65 of them spaces (79 - 11 - 2 = 66)
:: The variable "line" is used to compress the animation's size in the file, too.
:4
title Animation Box - Big loading
mode con lines=15
goto :4_DisplayBars
:4_DisplaySpace
echo *******************************************************************************
cls
echo.
echo.
echo.
echo.
exit /b
:4_DisplayBars
call :4_DisplaySpace
echo * *
echo * *
echo * *
echo *8 *
echo *8 *
echo *8 *
echo *88 *
echo *88 *
echo *88 *
echo *888 *
echo *888 *
echo *888 *
echo * 888 *
echo * 888 *
echo * 888 *
echo *8 888 *
echo *8 888 *
echo *8 888 *
echo *88 888 *
echo *88 888 *
echo *88 888 *
echo *888 888 *
echo *888 888 *
echo *888 888 *
echo * 888 888 *
echo * 888 888 *
echo * 888 888 *
echo *8 888 888 *
echo *8 888 888 *
echo *8 888 888 *
echo *88 888 888 *
echo *88 888 888 *
echo *88 888 888 *
FOR /L %%A IN (0,1,66) DO (
set Length=
set Width=
FOR /L %%D IN (1,1,%%A) DO set Length=!Length!
FOR /L %%E IN (%%A,1,65) DO set Width=!Width!
set Line=*!Length!888 888 888!Width!*
FOR /L %%R IN (1,1,3) DO echo !Line!
echo * 888 888 88*
echo * 888 888 88*
echo * 888 888 88*
echo * 888 888 8*
echo * 888 888 8*
echo * 888 888 8*
echo * 888 888 *
echo * 888 888 *
echo * 888 888 *
echo * 888 888*
echo * 888 888*
echo * 888 888*
echo * 888 88*
echo * 888 88*
echo * 888 88*
echo * 888 8*
echo * 888 8*
echo * 888 8*
echo * 888 *
echo * 888 *
echo * 888 *
echo * 888*
echo * 888*
echo * 888*
echo * 88*
echo * 88*
echo * 88*
echo * 8*
echo * 8*
echo * 8*
goto :4_DisplayBars
:: Matrix effect coming from below
:: If "Schalter" equals a space (" "), then the figures are moved one space to the right
:: If "Schalter" equals nothing (""), then the figures aren't moved.
:: %%A equals the last line, yet (the one at the top)
:: %%B equals the new line (%%A moved one line towards the top)
:: --- %%B equals the last %%A
:: In the last FOR-command, all lines are displayed. In case if the screen isn't filled, yet,
:: the program will put a blank (echo.)
:5
title Animation Box - Matrix
color 0a
cls
if "%Schalter%" == "" (set Schalter= ) ELSE (set Schalter=)
FOR /L %%A IN (1,1,23) DO (
set /a B=%%A + 1
FOR %%B IN (!B!) DO set Line%%A=!Line%%B!
set Line24=%Schalter%%random:~0,1% %random:~0,1% %random:~0,1% %random:~0,1% %random:~0,1% %random:~0,1% %random:~0,1% %random:~0,1% %random:~0,1% %random:~0,1% %random:~0,1% %random:~0,1% %random:~0,1% %random:~0,1% %random:~0,1% %random:~0,1% %random:~0,1% %random:~0,1% %random:~0,1% %random:~0,1% %random:~0,1% %random:~0,1% %random:~0,1% %random:~0,1% %random:~0,1% %random:~0,1% %random:~0,1% %random:~0,1% %random:~0,1% %random:~0,1% %random:~0,1% %random:~0,1% %random:~0,1% %random:~0,1% %random:~0,1% %random:~0,1% %random:~0,1% %random:~0,1% %random:~0,1%
FOR /L %%A IN (1,1,24) DO if defined Line%%A (echo !Line%%A!) ELSE (echo.)
goto :5
:: Flickering CMD-window in "white-black" "black-white" (background-font)
:6
title Animation Box - Epilepsy
cls
if "%color%" == "0f" (set color=f0) ELSE (set color=0f)
color %color%
FOR /L %%A IN (1,1,9) DO echo.
echo 88888888 88 88 88 88
echo 88 88 88 88 88
echo 88 888888 88
echo 88 88 88888888 888888 88 888888 888888 88 888888
echo 88 88 88 88 88 88__88 88 88 88 88 88 88 88__88
echo 88 88 88 88 88 88____ 888888 888888 888888 88 88____
FOR /L %%A IN (1,1,8) DO echo.
goto :6
:7
title Animation Box - Naked woman
color 05
mode con lines=180
echo .,,,,,..
echo _.zJ??c,J$hhhhh:::::??c,
echo ,J?:::::J99?????h::?h:::::?h
echo z”::::::$9999??h::::??h:?h:::?$.
echo J:::J$?::6;hh:::::??i:::?h::$::::$
echo J::9F::hhh6T??h:??h:::?$:::?h::$:::$
echo J::9?h?:::$:?$C:??h:??h:::9h::?h:?$::$
echo ;F:JF9?:J?:$h::?h:::?h::?h::?h::?$::h::h
echo $::C:CjF:j?$9h::?h:::?h:::9h::?h::$::9:9?
echo $:$:$9?:C9?$:$:::?h::::$:::?h:::$::$::$:$.
echo CJ?9:C:$:$:9::$:::?h::::?h:::$:::$::9::$:$
echo $$:$J:9:9J$:$::$:::?h::::?h:::?h::$::$:?h:,
echo C:F$:9:$$’”?$::$:::?h::::?h:::?h::$::h:?:9
echo :9:C::C?$’.`.$::h:::?h::::9::::$::9::?h:::
echo J:$:C::$:$’.`.`”"”?:::?h::::$::::$::$::$:::$
echo $:9:C:::$’`.`.`.`.“hjj?h::::$:::?h::h::::$
echo $:9::::hc?Jccc`.`.`.`z$??h:::h:::$::9::9::9
echo ?:9:9:::i’,cccJ”`.`.`J’Plcc$h::::::$:?C:::9
echo $:C:$:9'J$?$$$FP’.`jF3F`$$$ 3?h::::?:h::$:J
echo :$::$”‘”?c?$CJ`.`.$’.`?+??”`.`h::::$::X:::
echo h?C:9`.`.`.`.`.`.`$’.`.`.`.`.“h:::9h:C:::
echo `h$:9`.`.`.`.`.`.`??`.`.`.`.`.`?h:::C:C:J
echo `hh?h.`.`.`.`.`.`.`L’`.`.`.`.`.3::hC:F:F
echo 3:$$,`.`.`.`.`.`;3`.`.`.`.`.:C:9:9:$
echo ?h:?c`.`.`.`”"??”`.`.`.`.`.`.3::$:$:F
echo ??h`.`.`.`.`.`.`.`.`.`.`.`.$??:$:P
echo ?,.`.`.cJ?????QI$?.`.`.`.$::$:$
echo $,`.`.3?hc,c??$’`.`.`.`$:::P
echo $9,.`.`?hCCCJ”`.`.`.`.z?9:J”
echo ?h?h`.`.`.`.`.`.`.`.,$;;;,
echo ”"?,`.`.`.`.`.`.,$?;;;;9.
echo ?i.`.`.`.`.,J?;;;;;;;?c_
echo $h,.`.`,cc?;;;;;;;;;;;;?c,
echo $;;???;;;;;;;;;;;;;;;;;;;;?hc,
echo 3;;;;;;’`.`.`.`.`.`;;;;;;;;;;;???hhhccc,,_
echo ;;;;’`.`.`.`.`.`.`;;;;;;;;;;;’.`.`.`.`.`”?h .
echo ;;;’.`.`.`.`.`.`;;;;;’.`.`.`.`.`;;;’.`.`.`.`?
echo $;;’`.`.;.`.,;;;;;’.`.`.`.`.,;;;;;’.`.`.`.`.`.
echo C;;’`.`,;;;;;;;’`.`.`.,;;;;;;’`.`.`.`.`.`.`.`.
echo ,$?;;’`.`;;;;;’.`.`.`;;;;;’.`.`.`.`.`.`.`.`.`.`.
echo ,,cJ??;$;;;’`.;;’.`.`.`,;;;;’.`.`.`.`.`.`.`.`.`.`.`.`.
echo ,=”`.`.;;;;;;’.`.;;’.`.`,;;;;’.`.`.`.`.`.`.`.`.`.`.`.`.`.
echo ,P’`.`.`.`.`.`.`.`.;;;;;;;;’.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.
echo ,P’`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.
echo J”`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.
echo J’.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.
echo F`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.
echo F`.`.`?`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.
echo $’.`,J.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`ccc,.`.`.
echo $’.`J’.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`;;;;;;;?$,.`.
echo ?`.;F`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.;;;;;;;;;;?i`.
echo `L.P’`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.;;;;;;;;;;;?h.
echo hP’.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`:;;;;;;;;;;;;;$
echo P’`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`;;;;;;;;;;;;;$’
echo ,P’.`.`.`.`.`.`.`.`.;;`.`.`.`.`.`.`.`.`.`.`.`.`.`j;;;;;;;;;;;”
echo ,P’`.`.`.`.`.`.`.`.`;;;:’`.`.`.`.`.`.`.`.`.`.`.`.`;;;;;;;;;;F
echo J”`.`.`.`.`.`.`.`.`.;;;;:’`.`.`.`.`.`.`.`.`.`.`.`.`3;;;;;;;;;$
echo d’.`.`.`.`.`.`.`.`.`.;;;;:’`.,J??hc`.`.`.`.`.`.`.`.`9;;;;;;;;;F
echo d?h.`.`.`.`.`.`.`.`.`;;9;;:’`;$;jj;?h.`.`.`.`.`.`.`.;$;;;;;;;;9'
echo Jj;9,`.`.`.`.`.`.`.`.`;j$;;’.`3CJ;$;;$.`.`.`.`.`.`.;C;;;;;;;;$
echo C$;9'`.`.`.`.`.`.`.`.;3C;;’.`?C;T;;;$’.`.`.`.`.`.`.;j;;;;;;;;F
echo ?;;$.`.`.`.`.`.`.`..;;;3C;;’.`.?hjjUP’.`.`.`.`.`.`.;;3;;;;;;;;$
echo ?9F;’.`.`.`.`.`.`.;;j;9C;;’.`.`.`.`.`.`.`.`.`.`.`;;;F;;;;;;;;;
echo h;;;.`.`.`.`.`..;;;$`;h;;;’`.`.`.`.`.`.`.`.`.`.;;;F;;;;;;;;$
echo $;;;;.`.`.`.,;;;;9':;9;;;;`.`.`.`.`.`.`.`.`.;;;;F;;;;;’.`;F
echo $;;;;,.`.`;;;;;9F`.;;$;;;;,`.`.`.`.`.`.,;;;;j$;;’`.`.`.`$
echo ?;;;;;;;;;;;;JF.`.;;;?h;;;;;;;;;;;;;;;;;;j?;;;`.`.`.`.,F
echo ?;;;;;;;;;$”`.`.`;;;;$i;;;;;;;;;;;;;jj??;;;.`.`.`.“J
echo `?h;;;;J?`.`.`.`.`;;;;???Jjjjjjjj??;;;;`.`.`.`.`.“F
echo ”3?‘`.`.`.`.;;’.`.`.;;;;;;;;;;;;’.`.`.`.`.`.`.`;F
echo 3`.`.`.`.`.;;’.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`$’
echo 3`.`.`.`.`.;;’.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.,F
echo ?`.`.`.`.`.;;’.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.$’
echo `h.`.`.`.`.;;’.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.F
echo h.`.`.`.`.;;;.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`3'
echo $.`.`.`.`.;;;’`.`.`.`.`.`.`.`.`.`.`.`.`.`.`$
echo $.`.`.`.`.;;;’`.`.`.`.`.`.`.`.`.`.`.`.`.`.,F
echo .F.`.`.`.`.`;’.`.`.`.`.`.`.`.`.`.`.`.`.`.`.3'
echo j`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.3
echo F`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`,;cc????ci,3,
echo J.`.`.`.`.`.`.`.`.`.`.`.`.`.`.,J?`.`.`.`.`.`.?L
echo J’.`.`.`.`.`.`.`.`.`.`.`.`.`.`3?`.`.`__…`.`.`?c
echo .,jF`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.?c??”"“”"h,.` .`.??
echo .F’`h`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.uc??????.`.`.`?h
echo F`.$’.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`zP’.`.`.`.`.`.`.`.`?c
echo 3?`$’.`.`.`.`.`.`.`.`.`.`.`.`.`.c=”`.`.`.`.`.`.`.`.`.`.`?c_,
echo J?’”‘”.`.`.`.`.`.`.`$h.`.`.`.`.`.J?`.`._uc=”"” `.`.`.`.`.`.`.`.`.
echo ?`.`3?.`.`.`.`.`.`.`$$:`.`.`.`.`?h_.,;P”`.`.`.`.`.`.`.`.`.`.`.`.`
echo $’.`?,`.`.`.`.`.`.:$$’`.`.`.`.`.`;P”`.`.`.`.`._,zJ?`.`.`.`.`.`.`
echo J??$’.`h`.`.`.`.`.`.`?P’`.`.`.`.`.`$’.`.,,ccc+?”"`.`.`.`.`.`.`.`.`
echo $’.`?J?.`.`.`.`.`.`.`.`.`.`.`.`.`.`.”=”3?`.`.`.`.`.`.`.`. `.`.`.`.
echo .$i`.`h.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`??`.`.`.,uc”"cu,_.`.`.` .`.
echo $’??”"`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`”????”`.`.` .`.`?h_`.`.`.
echo h`.3,.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`”??$P
echo `?cP’.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.?,
echo C`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`h
echo C`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`3,
echo F`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.“h
echo F`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.$
echo F`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.3,
echo h`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`h
echo h`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`$
echo $’.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`,/.`.`.`.`.`.`.`.`.`.`.`.`3
echo $’.`.`.`.`.\.`.`.`.`.`.`.`.`.`.`.`.j”`.`.`.`.`.`.`.`.`.`.`.`.`?
echo $’.`.`.`.`.`?,.`.`.`.`,,,;;;;;;;;;J’.`.`.`.`.`.`.`.`.`.`.`.`.`.
echo 3`.`.`.`.`.`.?’;;;;;;;;;;;;;;;;;;J’`.`.`.`.`.`.`.`.`.`.`.`.`.`.
echo 3`.`.`.`.`.`.`?;;;;;;;;;;;;;;;;;$’.`.`.`.`.`.`.`.`.`.`.`.`.`.`,
echo ?`.`.`.`.`.`.`.?;;;;;;;;;;;;;;;P’`.`.`.`.`.`.`.`.`.`.`.`.`.`.`j
echo ?,.`.`.`.`.`.`.`?;;;;;;;;;;;;j?`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`3
echo `h.`.`.`.`.`.`.`.L;;;;;;;;;;J’.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`$
echo $’`.`.`.`.`.`.`.`L;;;;;;;;J’`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`$
echo $’`.`.`.`.`.`.`.`.$;;;;;;;F.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`$
echo $’`.`.`.`.`.`.`.`.`?L;;;;P’.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.,F
echo $’`.`.`.`.`.`.`.`.`.`?L;$’`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.$’
echo 3.`.`.`.`.`.`.`.`.`.`.`?F.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`,F
echo ?.`.`.`.`.`.`.`.`.`.`.,F`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`$’
echo `h`.`.`.`.`.`.`.`.`.`,P’`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`$
echo h`.`.`.`.`.`.`.`.`.`J`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`F
echo $’.`.`.`.`.`.`.`.`.,P’.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.,F
echo ?`.`.`.`.`.`.`.`.`.J.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.j’
echo `h.`.`.`.`.`.`.`.`.F.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.$
echo h.`.`.`.`.`.`.`.`,F.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`.`
echo.
pause >nul
color 07
exit /b
:: "Counter" determines the heigth of the last row (no matter if from below or above)
:: "Width" determines the width of each line (from left to right)
:: "Line%%A" are the lines 1 to 24, undepending from their length or width
:: "Schalter1" = From above to below
:: "Schalter2" = From below to above
:: :: ----Line1-------------------------------------
:: :: -C--Line2----------W-i-d-t-h------------------
:: :: -o--Line3-------------------------------------
:: :: -u--Line4---------|---------Schalter 2--------
:: :: -n--Line5---------|---------------------------
:: :: -t--Line...-------V-------------A-------------
:: :: -e--Line23----------------------|-------------
:: :: -r--Line24----Schalter 1--------|-------------
:: :: ----Line25------------------------------------
:8
title Animation Box - Fill window
cls
if "%Counter%" == "0" (
set Schalter=1
set /a Width=!Width! + 1
if "%Counter%" == "25" (
set Schalter=2
if "!Schalter!" == "1" FOR /L %%A IN (1,1,%Counter%) DO set Line%%A=
if "!Schalter!" == "1" FOR /L %%A IN (1,1,%Counter%) DO FOR /L %%B IN (1,1,!Width!) DO set Line%%A=!Line%%A!±
if "!Schalter!" == "2" FOR /L %%A IN (24,-1,%Counter%) DO set Line%%A=
if "!Schalter!" == "2" FOR /L %%A IN (24,-1,%Counter%) DO FOR /L %%B IN (1,1,!Width!) DO set Line%%A=!Line%%A!±
FOR /L %%A IN (1,1,24) DO if defined Line%%A echo !Line%%A!
goto :8
:9
title Animation Box - Arrow left
mode con lines=25
echo.
echo.
echo.
echo.
echo 8888
echo 8888
echo 8888
echo 8888
echo 8888
echo 8888
echo 8888888888888888888888888888888888888888888888
echo _88888888888888888888888888888888888888888888888
echo 88888888888888888888888888888888888888888888888
echo 8888
echo 8888
echo 8888
echo 8888
echo 8888
echo 8888
pause >nul
exit /b
:10
title Animation Box - Arrow right
mode con lines=25
echo.
echo.
echo.
echo.
echo 8888
echo 8888
echo 8888
echo 8888
echo 8888
echo 8888
echo 88888888888888888888888888888888888888888888888_
echo 8888
echo 8888
echo 8888
echo 8888
echo 8888
echo 8888
pause >nul
exit /b
:: Blinking skull in "black-red" "darkred-grey" (background-font)
:11
title Animation Box - Skull
mode con lines=54
echo.
echo _________ _________
echo / \ / \
echo / \ / \
echo I OOO I I OOO I
echo \ / \ /
echo \__ __/ \__ __/
echo \ \ / /
echo \ \ ___________________ / /
echo \ \ _/ \_ / /
echo \ \ _/ \_ / /
echo \ \ _/ \_ / /
echo \ / ,adPba, ,adPba, \ /
echo \ / a8"""""8a a8"""""8a \ /
echo \/ Y8888888Y Y8888888Y \/
echo / \@@@@@@@/ \@@@@@@@/ \
echo I @@@@@ @@@@@ I
echo I ,aAa, I
echo I a"""""a I
echo I 8YYYYY8 I
echo I 9888887 I
echo I @@@@@ I
echo I I
echo \ ___________________ /
echo / \ ² ² / \
echo / \ _____²_________²___ / \
echo / /\_ _/\ \
echo / / \_ _/ \ \
echo / / \_ _/ \ \
echo / / \___________________/ \ \
echo / / \ \
echo __/ (_ _) \__
echo / \ / \
echo / \ / \
echo \ / \ /
echo \_________/ \_________/
echo.
echo.
echo 888888 88 88 88
echo 8888888 88 88 88
echo 88 88 88 88 88
echo 88 88 aa88aa 88 88
echo 88 88 YY88PY 88 88
echo 88 88 88888888 88888888 88 88888888 88
echo 88 88 88 88 88PYYY88 88 88888888 88
echo 88 88 88888888 88 88 88 88 88
echo 8888888 88 88aaaa88 88aaaaa 88 88 88
echo 888888 88888888 888888888 88888888 88 88 88
:11_Colour
color 0c
FOR /L %%A IN (1,1,6) DO ping localhost -n 1 >nul
color 47
goto :11_Colour
:: Dos Techno Virus from the MS-DOS-times. It displays "TECHNO" all over again.
:: This animation stops after 25 lines (25 * 80 = 2000)
:: --- 25 = total amount of visible lines in one CMD-window
:: --- 80 = total amount of columns in one CMD-window
:: It sets the variable "M" to the entire code
:: There are 3 spaces between each "TECHNO"
:: When "C" equals 2,3 or 4, "L" is always a space
:: --- Else if "C" equals "0", the next letter is added to "M"
:: --- Either T,E,C,H,N or O (= TECHNO)
:: L = Letter
:: C = Changed
:: M = Message
:12
title Animation Box - Dos Techno Virus
set L=
set M=
set C=0
FOR /L %%A IN (1,1,2000) DO (
if "!C!" == "1" set C=0
if "!C!" == "2" (
set L=
set C=1
if "!C!" == "3" (
set L=
set C=2
if "!C!" == "4" (
set L=
set C=3
if "!C!" == "0" if "!L!" == "N" (
set L=O
set C=4
if "!C!" == "0" if "!L!" == "H" (
set L=N
set C=1
if "!C!" == "0" if "!L!" == "C" (
set L=H
set C=1
if "!C!" == "0" if "!L!" == "E" (
set L=C
set C=1
if "!C!" == "0" if "!L!" == "T" (
set L=E
set C=1
if "!C!" == "0" if "!L!" == " " (
set L=T
set C=1
if "!Cursor!" == "ß" (set Cursor=Ü) ELSE (set Cursor=ß)
set M=!M:~0,-1!!L!!Cursor!
echo !M!
cls
pause >nul
exit /b
:: Animation of a tiger's head
:: ^ are used to allow | in the animation
:13
title Animation Box - Winhound
color 0c
echo $$$$ $$$$$$'
echo $$$$.$$$ $$$$$$$$.
echo $$$$$$'$$$$$$$$$$$$$$$$$$$$$$$$$
echo $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
echo $$$$$$$$$$....0ø)`$$;$$$$$....0ø) , ,
echo $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ / /
echo $$$$$$$$$$_$$$$$$$$$$$$$$$$$$$$$$./ /
echo $$$$$$$$$_$$$$$'$$$$$$$$.$$.$$$`$$./
echo $$$$$$$$$_$$$$$$$'$$$$$.$$$$.$$$`$$---"
echo $$$$$$$$$$_$$$$$$$$$$$$$$____$$$$$$`
echo $$$$$$$$$$$$_$$$$$$$$$$$$$_$$$$$$
echo $$$$$$$$$$$$$$$$___^| /'___^| /$
echo $$$$$$$$$$$$$$_____^| /_____^| /$
echo $$$$$$$$$$$$$__eeee^|/____$$^|/
echo $$$$$$$$$$$$$__,___,____$$
echo $$$$$$$$$$$$$$__,___,____$$
echo $$$$$$$$$$$$ $$___/^|___,__$/^|
echo $$$$$$$$$$$ $$_/ ^|,_____/ ^|
echo $$$$$$$$$$ $/ ^|_____/ ^|$
echo $$$$$$$$$ $$$$$$$$$$$$$
echo $$$$$$$$ $$$$$$$$$$$
pause >nul
color 07
exit /b
:: Expands the window
:: "Lines" is always 55 less than "columns"
:14
FOR /L %%A IN (81,1,160) DO (
set /a lines=%%A - 55
mode con cols=%%A lines=!lines!
pause
exit /b
:: "(60,-1,0)" counts backwards
:C1
title Animation Box - 1 min
FOR /L %%A IN (60, -1,0) DO (
echo %%A
ping localhost -n 2 >nul
msg %username% One minute is over. 2>nul || pause >nul
exit /b
:: The "2009" written in zeros is shown longer than the others
:: --- Still no reasonable explanation for that
:C2
title Animation Box - 2009
echo __//////____///////____///////_____///////__
echo _////////__/////////__/////////___//_____//_
echo _//____//__//_____//__//_____//___//_____//_
echo ______//___//_____//__//_____//____////////_
echo _____//____//_____//__//_____//__________//_
echo ____//_____//_____//__//_____//__________//_
echo ___//______//_____//__//_____//___//_____//_
echo //////////__///////____///////_____///////__
cls
echo __000000____0000000____0000000_____0000000__
echo _00000000__000000000__000000000___00_____00_
echo _00____00__00_____00__00_____00___00_____00_
echo ______00___00_____00__00_____00____00000000_
echo _____00____00_____00__00_____00__________00_
echo ____00_____00_____00__00_____00__________00_
echo ___00______00_____00__00_____00___00_____00_
echo 0000000000__0000000____0000000_____0000000__
ping localhost-n 2 >nul
cls
echo __888888____8888888____8888888_____8888888__
echo _88888888__888888888__888888888___88_____88_
echo _88____88__88_____88__88_____88___88_____88_
echo ______88___88_____88__88_____88____88888888_
echo _____88____88_____88__88_____88__________88_
echo ____88_____88_____88__88_____88__________88_
echo ___88______88_____88__88_____88___88_____88_
echo 8888888888__8888888____8888888_____8888888__
cls
echo __@@@@@@____@@@@@@@____@@@@@@@_____@@@@@@@__
echo _@@@@@@@@__@@@@@@@@@__@@@@@@@@@___@@_____@@_
echo _@@____@@__@@_____@@__@@_____@@___@@_____@@_
echo ______@@___@@_____@@__@@_____@@____@@@@@@@@_
echo _____@@____@@_____@@__@@_____@@__________@@_
echo ____@@_____@@_____@@__@@_____@@__________@@_
echo ___@@______@@_____@@__@@_____@@___@@_____@@_
echo @@@@@@@@@@__@@@@@@@____@@@@@@@_____@@@@@@@__
exit /b
:: Background and font changing their colors
:C3
color 6a
color 8f
color 3e
color f9
color 01
color 09
color 67
color 43
color d4
color a7
color c1
color f0
color b0
color ab
color ce
color 9e
color a3
color 1e
color fd
color c7
color c4
color 91
color 61
color 6f
color 01
goto :C3
:: Using "telnet" to connect to a website that shows Star Wars 3 in batch
:C4
telnet towel.blinkenlights.nl
exit /b
:: Matrix animations from a random picture found in google
:: --- There are 7 animations, 4 have been finished, yet
:: --- The animations are from the Linux command prompt
:M1
title File System - File Manager
color 0a
mode con cols=110 lines=50
echo File Edit View Go Help
echo î î î î î
echo ÚÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ¿ ÉÍÍÍ»ÚÄÄÄÄ¿ÚÄÄÄÄÄÄÄ¿
echo ³ ÜÜÜ ³ ºÛÛ º³home³³Û shaun³
echo ³ [ ] shaun ³ ÈÍÍͼÀÄÄÄÄÙÀÄÄÄÄÄÄÄÙ
echo ³ ßßß ³
echo ³ ³ ÚÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ¿
echo ³ -^> ³ ³ ³
echo ³ Trash ³ ³ ³
echo ³ Ä ³ ³ ÛÛÜ ÛÛÜ ÛÛÜ ÛÛÜ ÛÛÜ ÛÛÜ ÛÛÜ ³
echo ³ ³ ³ ÛÛÛ ÛÛÛ ÛÛÛ ÛÛÛ ÛÛÛ ÛÛÛ ÛÛÛ ³
echo ³ ÚÄÄÄÄÄ¿ ³ ³ ÛÛÛ ÛÛÛ ÛÛÛ ÛÛÛ ÛÛÛ ÛÛÛ ÛÛÛ ³
echo ³ ³ ³ Desktop ³ ³ ÛÛß ÛÛß ÛÛß ÛÛß ÛÛß ÛÛß ÛÛß ³
echo ³ ÀÄÄÄÄÄÙ ³ ³ ³
echo ³ ³ ³ bin boot dev etc home lib lost+found ³
echo ³úúúÛÛÜúúúúúúúúúúúúúúúúúúúúúú³ ³ ³
echo ³úúúÛÛÛúúúúFileúsystemúúúúúúú³ ³ ³
echo ³úúúÛÛßúúúúúúúúúúúúúúúúúúúúúú³ ³ ÛÛÜ ÛÛÜ ÛÛÜ ÛÛÜ ÛÛÜ ÛÛÜ ÛÛÜ ³
echo ³ ³ ³ ÛÛß ÛÛß ÛÛß ÛÛß ÛÛß ÛÛß ÛÛß ³
echo ³ ³ ³ ³
echo ³ ³ ³ media mnt opt proc root sbin srv ³
echo ³ ³ ³ ³
echo ³ ³ ³ ³
echo ³ ³ ³ ÛÛÜ ÛÛÜ ÛÛÜ ÛÛÜ ³
echo ³ ³ ³ ÛÛÛ ÛÛÛ ÛÛÛ ÛÛÛ ³
echo ³ ³ ³ ÛÛß ÛÛß ÛÛß ÛÛß ³
echo ³ ³ ³ ³
echo ³ ³ ³ sys tmp usr var ³
echo ³ ³ ³ ³
echo ³ ³ ³ ³
echo ³ ³ ³ ³
echo ³ ³ ³ ³
echo ³ ³ ³ ³
echo ³ ³ ³ ³
echo ³ ³ ³ ³
echo ³ ³ ³ ³
echo ³ ³ ³ ³
echo ³ ³ ³ ³
echo ÀÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÙ ÀÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÙ
pause >nul
color 07
exit /b
:M2
title Animation Box - Matrix part 2 - shaun@hacktop: cmatrix
color 0a
mode con cols=89 lines=33
echo e Y ^| - g ' ^| ? x 9 3 : $ S Q 7 / i
echo s I $ 3 ! o 2 } 7 L E 2 H I n 0 G ^( n ^^
echo Q : ; : 9 + { " 3 A R 8 + A > > y ] u j %%
echo + A ^) 7 B v M / \ " 6 / # Z 5 t j F # s 0
echo F ? _ { Z + N y K ^& C ? n l b Y l \ X T c Y ^|
echo B @ r I m [ E C ? I Q 5 , { h W p y 7 @ B . 6 c
echo Z _ e X 3 " V A V ` T h G r : s f 0 ` * , U
echo H Z I ^) x $ 5 1 q @ S = J R 9 B c ^& + r S
echo $ S # $ E d D ] Y \ h t 0 S " i y N Q ^| J
echo s P , C G h R = 7 W \ ^> M ^& 9 %% m x q ` b
echo ^> j s s Q ) _ e C : \ \ ! . b X ^< z - V w '
echo $ R U ! D b J t ^> P ^| ' ^^ ^> ^& P i K k f _ N 0
echo : Y 1 A # e ! ^( , / C 4 h , ? P P v n z ? 2 b 0
echo u q z $ v s p ; ; 2 w ' ] R \ 4 M o _ ? %% z H
echo r $ N # g S j K ; D z J C z 5 9 \ 4 A { c y * X p
echo _ S 0 k K = c B ^^ : J V P A { 2 ^( ' : I q R u 8
echo C . 2 j = X \ . l L Y f $ q 3 C = D t g D _ b /
echo { ^< %% 9 i - y a { F V u j X _ 3 v ^( 2 ^& 9 - \ 3
echo e 7 n v I " V F 5 Q ? B + k , 5 e 4 _
echo S : t ? D W 8 y D K ` @ U = @ 6 5 4 -
echo J ? t ' ) I ^^ n $ f * D c k r L Q J x e b
echo q ^^ u Q b 3 " 0 \ x 0 6 %% ` n [ c 8 - m
echo + $ i L ? L Y P q Z Z f i 8 b w W f c t q
echo @ Z L d q ` V a [ ; S c p 6 o X 1 4 F i
echo / 4 ^> : v ! q " P " d M c X 2 - ^> t 5 i R
echo : ? o 9 c B / ? * 0 ^^ e S 1 r O N ^( x ? * E
echo 8 D # ^| L q 8 V / i 9 a k { ^) n A y 8 o { `
echo 3 ? \ V t Y { ^< G ^& # } 5 c J e h p t Y = X $ \
echo N ; @ ] 2 e ^( u U + y 7 v S Z k S { p x C ^& ? T c 3
echo K 1 z ^& a F n 0 ' H m v F ; . b k b g o V ^|
echo " F ( d k { - I r # D T ( ; T N 3 { G Q * H
pause >nul
color 07
exit /b
:M3
title Animation Box - Matrix part 2 - shaun@hacktop: scrot -c -d 3
color 0a
echo ÚÄ[shaun@hacktop][~]
echo ÀÄþ packer -Syu
echo Password:
echo :: Synchronizing package databases...
echo core is up to date
echo extra is up to date
echo community is up to date
echo :: Starting full system upgrade...
echo local database is up to date
echo :: Synchronizing aur database...
echo aur 6 6 [#############################] 100%%
echo :: Starting full aur upgrade...
echo ÀÄþ uptime
echo 03:16:23 up 5:10, 1 user, load average: 0.02, 0.08, 0.08
echo ÀÄþ acpi
echo Battery 0: Full, 100%%
echo ÀÄþ uname -a
echo Linux hacktop 2.6.32-ARCH #1 SMP REEMPT Tue Feb 9 14:46:08 UTC 2010 i686 Intel(R) Pentium(R) M processor 1.73GHz Genuine Intel GNU /Linux
echo ÀÄþ scrot -c -d 3
echo Taking shot in 3.. 2.. 1.. Û
pause >nul
color 07
exit /b
:M4
title Animation Box - Matrix part 2 - shaun@hacktop: ~
color 0a
echo ÀÄþ archey
echo.
echo +
echo # OS: Arch Linux i686
echo ### Hostname: hacktop
echo ##### Kernel: 2.6.32-ARCH
echo ####### Uptime: 5:10
echo ;#######; Window Manager: wmii
echo ######### Desktop Environment: None found
echo ########### Packaged: 364
echo ############# RAM: 274 MB / 2017 MB
echo ############### CPU: Intel(R) Pentium(R) M Processor 1,73 GHz
echo ####### ####### Shell: Zsh
echo .######; ;######. Root FS: 1.9G / 70G (ext3)
echo .#######; ;#######.
echo #########. .#########
echo ######' '######
echo ;#### ####;
echo ##' '##
echo #' '#
echo.
echo ÀÄþ []
pause >nul
color 07
exit /b
:: Reset variables from all animations to prevent missexecution
:: "exit /b" quits the last used CALL-command
:ResetVariables
set choice=
set Color=
set Counter=0
set Height=
set Length=
set Line=
FOR /L %%A IN (1,1,25) DO set Line%%A=
set Schalter=2
set Weight=
exit /b
TehTechnicalGuy in reply to TehTechnicalGuyJun 18, 2012. 6:16 AM
Thoughts?
Broom says: Jun 4, 2012. 9:23 AM
This could have been a really great tutorial, but unfortunately all your code has been catenated onto single lines.
Try editing it, and separating each code line with a blank line.
Bladesofvengence says: Apr 26, 2012. 1:46 AM
I made a Number guessing game batch but i cant get it to work.
@ECHO OFF
title Guess what number i am thinking of!
color D0
if exist SAVEGAME.bat goto top
SET /a score1=10
SET /a score2=10
SET /a score3=10
SET /a score4=10
SET /a score5=10
SET name1=aaa
SET name2=bbb
SET name3=ccc
SET name4=ddd
SET name5=eee
Goto mum
:top
call SAVEGAME.bat
:mum
SET /a GuessLimit=100
:start
SET tries=11
cls
ECHO Guess what Number I'm thinking of. (0-100)
ECHO Be careful, you only have limited tries!
ECHO Press any key to continue.
pause>nul
SET /a GuessNum=0
:begin
SET /a Answer=%RANDOM%
if %Answer% gtr 100 goto begin
:Retry
cls
SET /a tries=%tries%-1
SET /a Left=11-%tries%
if %tries% equ 0 (goto penalty)
ECHO You have %tries% attempts left.
ECHO Please type your guess number then press enter.
SET /p Guess=
SET /a GuessNum=%GuessNum%+1
IF %Guess%==overlord goto END2
IF %Guess% LSS %Answer% ECHO My Number is Higher.
IF %Guess% GTR %Answer% ECHO My Number is Lower.
IF %Guess%==%Answer% GOTO END
pause>nul
ECHO.
GOTO Retry
:penalty
ECHO Sorry, you have run out of tries.
ECHO Better luck next time!
ECHO The Answer was %Answer%
ECHO Do you want to play again? Yes/No
SET /p Answer=
IF %Answer%==yes GOTO start
IF %Answer%==Yes GOTO start
IF %Answer%==no GOTO Exit
IF %Answer%==No GOTO Exit
:END
cls
ECHO You are Correct!
ECHO It took %GuessNum% Guesses.
ECHO Please write your name.
SET /p name=
IF %Left% LSS %score1% GOTO sub1
IF %Left% LSS %score2% GOTO Sub2
IF %Left% LSS %score3% GOTO Sub3
IF %Left% LSS %score4% GOTO Sub4
IF %Left% LSS %score5% GOTO Sub5
:overlord
SET /p Answer=
:END2
cls
SET /p Answer=
:Exit
exit
:sub1
SET /a score5=%score4%
SET /a score4=%score3%
SET /a score3=%score2%
SET /a score2=%score1%
SET /a score1=%Left%
SET name5=%name4%
SET name4=%name3%
SET name3=%name2%
SET name2=%name1%
SET name1=%name%
GOTO HiscoreList
:Sub2
SET /a score2=%Left%
SET name5=%name4%
SET name4=%name3%
SET name3=%name2%
SET name2=%name%
GOTO HiscoreList
:Sub3
SET /a score3=%Left%
SET name5=%name4%
SET name4=%name3%
SET name3=%name%
GOTO HiscoreList
:Sub4
SET /a score4=%Left%
SET name5=%name4%
SET name4=%name%
GOTO HiscoreList
:Sub5
SET /a score5=%Left%
SET name5=%name%
:HiscoreList
ECHO.
ECHO HISCORES
ECHO 1. %name1% %score1%
ECHO 2. %name2% %score2%
ECHO 3. %name3% %score3%
ECHO 4. %name4% %score4%
ECHO 5. %name5% %score5%
if exist SAVEGAME.bat del SAVEGAME.bat
ECHO @echo off>SAVEGAME.bat
ECHO set name1=%name1%>>SAVEGAME.bat
ECHO set name2=%name2%>>SAVEGAME.bat
ECHO set name3=%name3%>>SAVEGAME.bat
ECHO set name4=%name4%>>SAVEGAME.bat
ECHO set name5=%name5%>>SAVEGAME.bat
ECHO set score1=%score1%>>SAVEGAME.bat
ECHO set score2=%score2%>>SAVEGAME.bat
ECHO set score3=%score3%>>SAVEGAME.bat
ECHO set score4=%score4%>>SAVEGAME.bat
ECHO set score5=%score5%>>SAVEGAME.bat
pause>nul
GOTO overlord
fhkoekje says: May 18, 2010. 12:30 PM
i changed your code for the number guessing game
i added a simple cheat and made the game a little easier:
the number doesn't go higher than 100
@ECHO OFF
:start
cls
SET /a GuessNum=0
:begin
:Retry
SET /p Guess=
IF %Guess%==cheat goto END
ECHO.
pause>nul
cls
GOTO Retry
:END
cls
echo The Answer was %Answer%
ECHO.
pause
goto start
silvan9145jr in reply to fhkoekjeAug 18, 2011. 10:35 PM
I added on to yours.
@ECHO OFF
title Guess the Number!
color 0b
SET /a GuessLimit=15
:start
cls
SET /a GuessNum=0
:begin
:Retry
SET /p Guess=
IF %GuessNum% GTR %GuessLimit% (
start http://www.google.com/
ECHO.
GOTO Retry
:END
cls
ECHO.
echo Press any key to play again. :)
pause>nul
goto start
You can change the google.com to whatever you want so that if they dont guess in 15 tries they go to the designated website >:D
teh_pwnage in reply to fhkoekjeJul 16, 2010. 11:57 AM
@ECHO OFF color 29 :hmm? Echo Chose the right number or get PWNED! echo. echo. set /p lol=Choose or ELSE!!!))) if %lol%== 8 good... if not %lol%== 8 goto pwn :pwn start http://www.youtube.com/watch?v=oHg5SJYRHA0&feature=related/ exit :good... echo You got lucky... pause >nul
crazyman135790 says: Apr 21, 2011. 2:38 PM
cd..
cd..
cd..
cd..
cd..
dir /s
graboy says: Feb 9, 2010. 6:23 PM
^^ I think I'm the only person who got the IF's AND's or NOT's thing. "NOR" does anyone other than us know what were talking about.
Files in reply to graboyAug 17, 2010. 7:22 AM
:o I think I got it too. "IF" "AND" "NOT"
will421 in reply to FilesFeb 10, 2011. 1:22 PM
I GOT IT TOO!
IF you thought they were batch commands AND NOT just in regular old all caps, you got it!
Files says: Aug 17, 2010. 7:41 AM
I mine as well should add my variation.I got ideas from various people, but I mainly just edited and added in some new echo's and added some extra info.
@ECHO OFF
title Command Prompt - Made by NetworkNinja Editted by Mikeyy
color 20
echo Calculator V1.3
echo Made by NetworkNinja echo Editted by Mikeyy
echo ---------------------
echo LEARN:
echo * = Multiply
echo / = Divide
echo + = Addition
echo - = Subtracting
:blah
ECHO.
SET /p UDefine=
SET /a UDefine=
%UDefine%
ECHO =
ECHO
%UDefine%
ECHO.
PAUSE
ECHO.
echo THANK YOU FOR USING OUR CALCULATOR!
ECHO -------------------------------------------------------------------------------- ECHO.
goto blah
teh_pwnage says: Jul 16, 2010. 11:59 AM
You could do this: @echo off color 0a :lol echo %random%%random%%random%%random%%random%%random%%random%%random%%random% goto lol
teh_pwnage says: Jul 16, 2010. 11:55 AM
Evilthingamabober says: Jul 10, 2008. 12:52 PM
@echo off
color 29
SET /p doom1=
SET boom2=8
IF %doom1%NEQ%boom2% (
start http:/www.epicwinrar.com/
I tried this batch out but it didn't work. What did I do wrong?
teh_pwnage in reply to EvilthingamaboberJul 16, 2010. 11:54 AM
will421 in reply to EvilthingamaboberJun 25, 2009. 9:14 AM
EKKKK!!! Rick roll!
Neodudeman (author) in reply to EvilthingamaboberJul 11, 2008. 6:30 AM
@ECHO OFF
color 29
SET /p doom1=
SET boom2=8
IF %doom1% NEQ %boom2% (
start http:/www.wikipedia.org/
You didn't put spaces between %doom1%NEQ%boom2%
It should be %doom1% (SPACE) NEQ (SPACE) %boom2%
teh_pwnage in reply to NeodudemanJul 16, 2010. 11:54 AM
Evilthingamabober in reply to NeodudemanJul 11, 2008. 5:40 PM
Thanks. Time to own my parents...
tinkerC says: Jul 12, 2009. 10:16 AM
How do you read a file using Batch?
Guard13007 in reply to tinkerCApr 10, 2010. 8:55 PM
 It's really complex and long, don't bother unless you really need to.
Unless you're just trying to read one line, in which case:
set var=<"file"
echo %var%
But that only works in XP...
tinkerC in reply to Guard13007Apr 11, 2010. 5:27 AM
 No, I mean, read a file as in a configuration file.
MacDynamo in reply to tinkerCJun 26, 2010. 12:00 PM
::type Configure.Extension | find /i "Variable" > OutputFile.Extension ::set /p SetupVariable= < OutputFile.Extension ::set ProgramVariable=%SetupVariable:~X,Y% ::X and Y being the first and last character number eg. Variable=10 is x=10, y=11 ::PM me if you still need help (had to make this brief for some reason)
scienceguy says: Jul 15, 2009. 8:21 PM
HELP i want to create a line of code that will allow me to test my newest fork virus(s) and still allow me to regain control without having to reboot. It does not need to be its own program, just a line that i insert in the file. for example, i need a line that, when i press the "A" key in any of the fork windows, it will close all the fork windows, thereby not allowing it to duplicate anymore seen as it has stopped all instances running. so, more or less, an exit command for ALL DOS windows or all windows with a certain name. finally, if this is not fesable, a way to just stop it duplicating, without closing all the windows would work too. thanx
Guard13007 in reply to scienceguyApr 10, 2010. 8:53 PM
 Here's a way to do it.
set loop=0
:loop
(virus stuff)
set loop+=1
if "%loop%"=="13" goto end
goto loop
:end
pause
The line "set loop+=1" is a command to add 1 to the current value of the variable.
elmynase says: May 18, 2008. 8:36 AM
can you divide?
NetworkNinja in reply to elmynaseApr 16, 2009. 6:00 PM
yes, / is divide
ex. 9/3=3
DNR in reply to NetworkNinjaJul 17, 2009. 1:21 AM
how to solve decimal values
Guard13007 in reply to DNRApr 10, 2010. 8:50 PM
 Batch files mess up over decimals, blame Microsoft.
elmynase in reply to DNRJul 18, 2009. 1:48 PM
good question !!
Guard13007 in reply to elmynaseApr 10, 2010. 8:50 PM
NetworkNinja says: Apr 16, 2009. 6:00 PM
This is mine, has black letters on green background. Looks kool.
@ECHO OFF
color 20
:blah
ECHO Calculator Version 1.0
ECHO.
SET /p UDefine=
SET /a UDefine=%UDefine%
ECHO =
ECHO %UDefine%
ECHO.
PAUSE
goto blah
DNR in reply to NetworkNinjaJul 18, 2009. 11:54 PM
Guard13007 in reply to DNRApr 10, 2010. 8:49 PM
 Batch files don't like decimals, and screw up over them for some reason. Blame Microsoft.
1-40 of 154Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
