3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Advanced Batch
Step 8GOTO Command
GOTO Command
The GOTO Command. It does exactly what it says; it GOes TO a label in the batch file script.
To use this command, you must first have a label in place. Labels look like this:
:Label1
It's simply a colon before a non-spaced series of letters and/or numbers.
The GOTO command is structured like this:
GOTO Label1
It's That Easy!
Come to think of it, I'm not really sure why I didn't put this in the Slightly Advanced Batch.
In any case, this command can be used to repeat a batch file by simply GOTO a label that executes the GOTO command again.
@ECHO OFF:RepeatMeECHO This will be repeated unless you hit "CTRL-C"GOTO RepeatMe
The batch file speaks the truth, by the way. CTRL-C is the universal Pause and Prompt for Termination. CTRL-S is simply Pause. But Closing the window works just as well.
The GOTO can skip, or reorder your code as well.
GOTO TurnEOffGOTO MultipleGotoECHO This ECHO is going to be skipped.:MultipleGotoGOTO 3:ENDPAUSEEXIT:1ECHO The EndGOTO END:3ECHO This will be displayed firstGOTO 2:TurnEOff@ECHO OFFGOTO MultipleGoto:2ECHO This is second, even though it's last in the code.GOTO 1
The above code was structured confusingly on purpose to emphasize the GOTO's ability to jump around in the code.
1 comment
Jul 16, 2010. 11:55 AMteh_pwnage says:
@ECHO OFF color 29 :hmm? Echo Chose the right number or get PWNED! echo. echo. set /p lol=Choose or ELSE!!!))) if %lol%== 8 good... if not %lol%== 8 goto pwn :pwn start http://www.youtube.com/watch?v=oHg5SJYRHA0&feature=related/ exit :good... echo You got lucky... pause >nul
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
22
Author:Neodudeman
