Introduction: Advanced Hovercraft
Picture of Advanced Hovercraft
I took my basic Hovercraft model and the parts from a broken RC toy and repurposed them to make a new toy. This hovercraft will be able to float above water.
Please see the video link below.http://www.youtube.com/watch?v=lZnxrP-Sc0Q. Basic Hovercraft construction link
https://www.instructables.com/id/Basic-Hovercraft/
Step 1: Lift Motor Batteries and Switch
Picture of Lift Motor Batteries and Switch
I installed two 7 v RC Helicopter Batteries and hot glued them to the Lift Motor housing. I hooked them up in series to give me 14 volts. I added a single pole single throw switch to turn the lift motor on and off independent of the thrust motors.
Step 2: Installation of RC Electronics
Picture of Installation of RC Electronics
I hot glued the circuit board and battery housing on the Lift Motor housing. I did not install a power switch for this component. It is easy to remove the battery.
Step 3: Thruster Setup
Picture of Thruster Setup
I hot glued the gear drive motors from the RC toy and attached them to a wood dow. I had to use my Dremel tool to grind down the gear till it fit snug in the propeller. I cut the dow in half to attach to the Lift Motor.
Step 4: Thruster Calibration
Picture of Thruster Calibration
This part was a little more difficult. I had to solder the wires so that when I pressed the left control forward, it would turn motor in the direction of forward thrust. Next I had to do the same thing for the right thrust control. We now have wireless thrust control over hovercraft.
British Badger (author)2014-10-27
hi I'm starting a hovercraft group to share experience and designs to make the best hovercraft s possible I was wondering if you were interested
palombo5050 (author)2014-02-17
palombo5050 (author)palombo50502014-02-17
I added a small fin to help control the steering over water.
eryl (author)2014-02-09
You'll probably find that it hovers better, with less power, if you follow real hovercraft technique of forming a cylindrical curtain of air, by putting a smaller plate underneath and having the air blown into the gap between the two.
palombo5050 (author)eryl2014-02-09
True to that concept. This was the first one and I wanted something simple. The lift motor has I used has an air current flow corrector built into the housing. The thrust comes out straight without spiral turbulence. It came out of a decent hair dryer.
snakelips1 (author)2014-02-08
Pretty slick. If you look around on the Web at other hover craft, you will notice they have a flexible skirt on the bottom. mainly this helps with rough terrain. Also it helps transitioning different terrain. you could potentially use a plastic grocery bag and some tape. keep up the good work!
palombo5050 (author)snakelips12014-02-09
Thanks for sharing. I have a bicycle inner tube I may end up using. This is my first hovercraft project and I am just playing around. My next one will be a little bit more powerful. I have pulled out the components of a Shark cordless vacuum cleaner. I have tested the thrust and it is very powerful. I think I will use the bike tube for that project. Thanks for checking out my project.
palombo5050 (author)2014-02-08
Video
palombo5050 (author)palombo50502014-02-08
About This Instructable
2,487views
39favorites
License:
Bio: I like to tinker and build things that seem fun to do.
More by palombo5050:Make It Glow.... Safely!Mighty Mini PizzaSoda Stream Nuggets
Add instructable to:
