Adventure Time: Finn's Hat + Pattern
 by LegoBrickMaster7
Featured
Step 8: Bonus Step! - The Backpack
I was originally planning to do a separate Instructable for the backpack, but decided it was pretty easy to make, and it would be hard for me to accommodate the different sizes of people, and the different functionalities. The one I made in this step is fairly functionless. I still have the option of adding a zipper on top, but don't have one at school (where I made it). Other people might want it to function like it does in the show, as the light green part being a flap that has one large black button.
Either way, if you're interested in making one, you can skip through the pictures, and read some newly added steps(below) and probably get a decent idea of how I did it, and base yours off of that.
1. Cut out the pieces.
  • (x2) 14" circle (one of each color)
  • (x4) 22" x 4" strip (2 of each color)
2. Cut some more...
  • Cut each circle in half.
  • Cut one light green, and one dark green in half, so you will have (x4) 11" x 4" strips, and (x2) 22" x 4 " strips.
3. Start sewing.
  • Fold the smaller 11" strips in half (the long way) and sew along the edge. These will be parts of the straps.
  • Pin each of the long 22" strips to the corresponding colored round edge of the half circle, and sew along that edge.
4. Straps.
  • Flip the 11" strips, so they're "right-side out", and insert each light green tube into each dark green tube, and sew them into place, attaching them to each other.
5. Top piece.
  • Pin the straps onto the remaining half circle (I chose to start with the light green). Next, pin the other half of the light green top to the half circle with the straps you just pinned. Sew along the edge, finishing the top half of the pack.
6. Bottom piece.
  • Do the same for the bottom half. Pin the straps in (making sure they aren't twisted), and sew it up.
7. Finishing.
  • Now we need to sew across the middle of the pack, attaching the light and dark green parts. It's been inside out the whole time, so you need to leave about a 2 inch hole so you can flip the whole pack.
Hopefully those simply written steps and pictures can get you through it.
straw1880 says: Dec 13, 2012. 11:27 PM
Hello~ I was wondering if it was possible to actually make the backpack into a functioning bag, like with a zipper and all...
Any suggestions with that? I wanted to make this for my friend for her birthday
Thank you^^
LegoBrickMaster7 (author) in reply to straw1880Dec 14, 2012. 10:21 AM
Sure! I've got a few suggestions.
If you're going to be basing your bag off of my designs and dimensions, all you should need to do is modify the light green 22" x 4" strip (the one on the top of the backpack). Get a zipper that's no longer than 22 inches, and attach it to the light green strip by cutting a slit, the long ways in the piece (before you assemble the bag). That should give you a zippered bag.
Other than that, I would recommend taking a look at what other people have done to make functioning backpacks. Etsy is a good place to look, and there's a few tutorials on youtube, too.
There's a good chance that using one of the other designs out there would result in a better functioning bag, since I designed mine to be used as a prop. It's pretty floppy.
Hope that helps!
amwu says: Jul 11, 2012. 10:49 PM
this is lumpin awesome the pics and instructions are great, i wanted to make this for my boyfriend and it's turned out just perfect so thank you!
Numbuh1Nerd says: Apr 4, 2012. 4:13 PM
How much fabric did you use for the backpack?
LegoBrickMaster7 (author) in reply to Numbuh1NerdApr 4, 2012. 6:11 PM
I ended up buying 1 yard of each color, but I like having extra fleece around for various projects. If you don't want to pay more, and have extra, I'd recommend somewhere between 1/4 - 1/3 yard for each color.
For cutting the 14'' circles out, you'll have to make them into semi circles (since the fabric won't be wide enough), but you need to do that later in a later step anyway.
Hope that helps!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
