Step 14Splitting off the power switch
What you'll need to do is using the Solder Pump again, remove all or at least most of the solder from the leads and then carefully remove the switch from the circuit board. Then, immediately solder down 6 3 1'2 inch wires and then hot glue them down, so even if the switch gets pulled, it won't damage the soldered areas.
comment
Add Comment
skittlespider
says:
SHIFT! (author)
says:
Add Comment
