3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Adventure Time's BMO: GBC Mod Replica
Step 16The Start / Select buttons
Alright, now it's time to begin working on the buttons starting with Select and Start!
All of the Game Boy Color's buttons are on rubber pads which, after they make contact with the copper plates on the Game Boy, complete the circuit activating the switch.  Our goal is to split it off from the Game Boy so they can come out to BMO's front side.
Start and Select are connected by ground wires and normally you'd have to use the Volt Meter to see which ones are connected.  Lucky for you, however, I already marked which are the Signal Pads (those specific to the certain button) and left the Ground Pads (those already connected) unmarked.  The only thing you have to do is apply solder to each of the Signal Pads, connect one lead of the Momentary Push Button Switch to each, and connect the other leads to one another.  This will complete the circuit and allow us to use the Start and Select buttons on Beemo's front side.
Be sure to add Hot Glue to each of the wires at the end.
8 comments
Apr 18, 2012. 5:06 AMTreeboy21 says:
Hi first of all love the project.
Im just having trouble understanding the button wiring and was wondering if it was at all possible to have some help. If its not to much work i was wondering if you could draw some line between connections on this picture.
Thanks.
May 31, 2011. 3:50 AMpfleer says:
I was wondering why the buttons appear to be wired in series?
Maybe I'm reading the explanation incorrectly; could you please clarify the wiring?
p.s. Thanks for the great Instructable!
May 31, 2011. 7:16 PMpfleer says:
Pardon? I was hoping you could clarify how you wired up the Start and Select buttons.
May 31, 2011. 9:20 PMpfleer says:
Haha, sorry, I see how that could have been confusing.
Just to clarify, (for the Select button for example) you only need to attach a single wire from any one of the (marked) signal pads to the switch and then another wire running back to any of the ground pads? And then the same again for the Start button?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
133
Author:SHIFT!
"Almost Toast"
