Aeroplane from an Aluminium Can (and it flies too) by awesomecreations
Featured
This aeroplane can definitely be improved by measuring before cutting. I didn't do this and it ended up looking a little bit uneven. This aeroplane will fly, but only if you make it from an ALUMINIUM can. Most canned energy drinks use all-Aluminium cans. This model is not a scale version of any real aircraft. This is my first ever aluminium-built model aeroplane and it was quite satisfying to see it fly.
Materials needed:
An aluminium can
glue
some kind of ballast (use putty or wire or anything else that seems to work)
Tools:
Tin snips or scissors
Pliers
Step 1: The wings
Cut the top and bottom off of the can and cut vertically between the top and bottom to reveal a decent sheet of aluminium. Flatten it out.
Now, for the wings, cut the sheet about 2 fifths across so that you have enough material for the wings and enough left over for the fuselage and tail. If this was the original sheet: I___I it should now look like this: I_I I__I
Bend it in half, but don't crease the edge like you would paper. We want the leading edge to be realistic-looking, not flat.
 DON'T cut the leading edge. Cut 2 slits in the top piece of the wing, each one about 2mm from the centre line.
Now "roll" the top of the wing further back. This will make the leading edge move from one part of the sheet to another. The wings should now appear somewhat swept-back.
Cut the back of the wing and the wingtips to the shape you want them to be.
Because it was requested, I included a template page which I made on Microsoft Paint so that you can click on it, download the full-resolution picture and print it from paint. Then, cut the parts out and trace them onto your can. I used a 16FL. OZ. 473ml Monster can, so If you have a smaller can it may not fit. I apologise if it isn't perfect, but I hope it helps you if you need it.
1-40 of 59Next »
awesomecreations (author) says: Jan 18, 2013. 11:26 AM
I made this cool MiG 21 after I made this instructable;
http://www.instructables.com/id/MiG-21-from-a-Monster-Can/
PapaHex says: Jan 31, 2013. 4:24 PM
My great grandpa used to make old biplanes like this back before i was born. I went into his attic and found about 5 of them and just fell in love. thanks for the instructable. I hope I make some as well.
spark master says: Jan 15, 2013. 6:02 AM
please redo with a page to print out and glue to can material so they come out nicer.
nose of plane is open?
consider crazy glue to build it. I seem to remember it was claimed o be used to laminate materials to build plane wings on het fighters. How true I do not know but here it would be nice. Clamp materials down tight one drop and capillary action sucks it up.
nice concept I've made Pepsi-G alky stoves, and used soda cans to make other things
thanks, but please make another with a print so they all come out really nice.
awesomecreations (author) says: Jan 15, 2013. 11:44 AM
Okay, I will make an MS paint version which can be printed and stuck/traced onto the sheetmetal. It may take a day or two though to get it all correct so it can fit all on one can.
spark master says: Jan 15, 2013. 4:44 PM
That is why they call you (cue drumroll and fanfare)......THE AWESOME ONE!!!!!
truely nice project, if ther a cover on the front of the planes nose?
If you anted to make a lot of them make a mandrel then heavily wax it, or use silicone release, that would allow you to make a really taut shell, the crazy clue would work nicely
but that is just a suggestion.
After you print the plane parts you use rubber cent to glue it on the the flat metal then use Xacto kife to cut out the plane parts,better edges then shears (well usually).
thanks so much for your instructable, glad to see you follow up with prints.
after that a bi-plane-triplane!!! well perhaps not , but we can wish!
sparkie
awesomecreations (author) says: Jan 16, 2013. 8:52 AM
I added a template.
awesomecreations (author) says: Jan 16, 2013. 5:52 AM
Thanks. No, the nose isn't covered by anything and this does affect stability a bit.
I wouldn't suggest gluing paper plans to the metal permanently because paper is quite dense and increases the weight considerably.Glue also adds quite a bit of mass.
One could cut a semicircle out of the can-sheet and roll it to form a cone which can be glued inside the nose and stick out a bit to reduce drag and look like a propeller cone, if somebody does this then please post some pictures of the finished product and some steps along the way.
I wish I could make another model different to this one but I don't have any aluminium cans.
spark master says: Jan 16, 2013. 7:35 AM
You live in a plce with not cans, I am now even more impressed! All I need do is go past a school/park and can pick up a dozen all aluminum. We have deposits oncarbonated beverage cans here in NY State, but nothing else, so a person who wants to play can find "stuff" easily. I am sure the postage from me to you plus governmental agencies would stop anything I sent you or make it ludicrously expensive.
Isuggest if there is / are health lubs near by you ask if they sell any of the stuff that uses those cans then ask them to save a few empties. Service stations and parks are another place to look to get'm fer free.
good luck
awesomecreations (author) says: Jan 16, 2013. 8:36 AM
I have aquired another empty Monster can from my brother now and I will start making a Mikoyan & Gurevich 21 Fishbed.
awesomecreations (author) says: Jan 16, 2013. 8:26 AM
Finding steel cans is easy, but aluminium ones are difficult because not everybody drinks expensive energy drinks all the time.
spark master says: Jan 16, 2013. 7:28 AM
use Cyanoacrylate glue (nasty stuff if you make an error really can be nasty), will add almost no weight . you might add a hook to the bottom so you can rubber band lauch it.
or gut an old balsa flyer for the plastic prop and add rubberband flying. Your concept has a few nice variables. You could get a simple electric batt system and the motors (they are very very powerful for weight and size. I do not fly planes so I don't know how they would work out.
awesomecreations (author) says: Jan 16, 2013. 8:32 AM
I also make my own parts for rubber-band conversions for some other gliders I have made. This is basically the propeller, friction reduction and parts to hold everything in place. Usually I use old plastic containers and pen-lids.
awesomecreations (author) says: Jan 16, 2013. 8:29 AM
I also use mostly cheap Cyanoacrylate adhesive which is difficult to correct and it also it leaves white marks from the chemical reaction with the air.
spark master says: Jan 16, 2013. 7:16 AM
I appologise for not expounding ,by using rubber cemet you can peel it right off then rub it clean, Do this on hard flat surface like a sheet of glass/plexiglass/formica tabletop, and it comes right off. Hobby store might have a nicer version of the stuff (easier to remove). But I use the rubber cement and paper print to do wood carving sometimes. It works great, you an glue 4 faces of a cube/rectanglethen, triangulate in your head as you rough out the item. (roughout/hogout same thing, remove gross amounts of wood to allow you to carve).
awesomecreations (author) says: Jan 16, 2013. 5:53 AM
*The nose should look like this when done: " _I> "
travistoler says: Jan 14, 2013. 9:57 AM
hey do you have a template to use to cut out all the pieces from the aluminum can? That would be a great help in duplicating this.
Great instructable, thanks for sharing!
awesomecreations (author) says: Jan 14, 2013. 10:25 PM
Maybe I could draw one up and post it so that it can be printed.
awesomecreations (author) says: Jan 16, 2013. 8:51 AM
There! a template is available in Step 1
Edgar says: Jan 15, 2013. 2:18 PM
This is a new twist to Papercraft, Tincraft! :D
Went to the Blog:
http://faz-voce-mesmo.blogspot.pt/2013/01/nanotecnologia-para-motores-cubo-de.html
awesomecreations (author) says: Jan 16, 2013. 5:58 AM
Wow, I didn't realise how far this Instructable has spread!
Edgar says: Jan 16, 2013. 7:48 AM
Yup, you're big in Brazil, now... :)
Thergox says: Jan 14, 2013. 4:32 PM
AWESOME! This is PERFECT for a Sunday evening where I have nothing to do ^_^ Thanks!
t2design says: Jan 13, 2013. 6:16 AM
Looks a little like one of these, but without the prominebt fixed landing gear: http://www.avionslegendaires.net/mitsubishi-a5m-claude.php
awesomecreations (author) says: Jan 13, 2013. 11:47 AM
Hey, it does! I'm building a one two-hundredth scale A6M5 Zero-sen right now. I'll make an 'ible of it tomorrow...
awesomecreations (author) says: Jan 14, 2013. 4:59 AM
OK, Here is the link to it:
http://www.instructables.com/id/One-inch-scale-Mitsubishi-Zero-sen/
tobyker says: Jan 13, 2013. 9:04 AM
Great fun. But it would be easier to see what's happeningif you could find a clear surface to rest the model on while you take pics.
awesomecreations (author) says: Jan 13, 2013. 11:34 AM
I know, I wish I had more space in which to work and a better camera. I apologise and hope that what I have posted here is detailed enough.
milesfromneihu says: Jan 14, 2013. 1:44 AM
I like your work space. Looks well used.
awesomecreations (author) says: Jan 14, 2013. 3:21 AM
Thanks, It sure is.
sabr686 says: Jan 13, 2013. 4:34 PM
That's fun. It'll keep me busy for hours making all sorts of crazy and unnecessary mods. Thanks for the great ible!
awesomecreations (author) says: Jan 14, 2013. 12:36 AM
My pleasure!
agis68 says: Jan 13, 2013. 9:44 AM
excellent work...once i fixed a locomotive of tins....now u need an engine.....lol
awesomecreations (author) says: Jan 13, 2013. 11:32 AM
Is it an instructable? I think I have seen it if so.
agis68 says: Jan 13, 2013. 11:37 PM
no! you know middle of the week i do several things and iam boring to write about them in instructable. :( Anyway take a pic and maybe one day i will write about it....
Cool!
germeten says: Jan 13, 2013. 6:02 AM
I could see an RC plane being built like this, using AL can panels just like the full size versions that are riveted together. If the fuselage were a hollow tube, an engine inside would cause air to flow through. We forget what can be done with humble materials, thanks for reminding us.
awesomecreations (author) says: Jan 13, 2013. 11:38 AM
Thanks, but I think I'll pass on building bigger aircraft with panels and rivets, It would probably become very time consuming and probably a little bit on the heavy side when compared to good old-fashioned balsa.
eelco_g says: Jan 13, 2013. 6:47 AM
That is an awesome idea! If anyone can build it, it's the creator of this instructable. Let's hope he's into RC :D Air doesn't even have to flow through the fuselage. The shape of this airplane reminds me of a spitfire. You can stick a large propeller on it.
awesomecreations (author) says: Jan 13, 2013. 11:43 AM
If you'd like to see my (hopefully) RC Supermarine Spitfire, please click the link below:
http://www.instructables.com/id/Balsa-Spitfire-model-small-scale/
awesomecreations (author) says: Jan 13, 2013. 11:42 AM
I made this aeroplane with the intent that it should look like a record-breaking open-cockpit aircraft from the 1920s and 30s, and with its short wings and wide body it reminds me of the GeeBee.
1-40 of 59Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
