Introduction: Aesthetically Pleasing Gaming Coffee Table
After completing my TV Ledge, AV Equipment Shelves, and Media Shelves... I needed one last piece of furniture to complete my living room entertainment extravaganza. I needed somewhere to store all video game accessories like controller, headsets, etc.
We had this pretty cool looking coffee table that we liked. We also had end tables that matched it. After doing some calculations I figured out a way to use the table and fulfill my gaming needs.
While you might not have the same table, you could fairly easily reproduce what I have done here from scratch.
Step 1: Tools and Materials
Tools:
Pencil
Tape Measure
Dremel
Hair Dryer
Iron
Towel
Flat head screw driver
Miter Saw
3" C-Clamp
Drill
Bar Clamps
Table Saw
Sawhorses
Kreg Pocket Screw Jig Kit
Square Driver Bit
Sanding block
Metal Chop Saw
Grinding wheel
Materials:
Paper (for design and sketching)
Glass Hinges and Pulls
Masking Tape
2' x 4' x 1/2" MDF Board (For cubbies)
2' x 4' x 3/4" MDF Board (For new base)
150 Grit Sandpaper
1 1/2" Coarse Pocket Screws
Glass Frosting Spray Paint
Pencil
Tape Measure
Dremel
Hair Dryer
Iron
Towel
Miter Saw
3" C-Clamp
Drill
Bar Clamps
Table Saw
Sawhorses
Square Driver Bit
Sanding block
Metal Chop Saw
Grinding wheel
Materials:
Masking Tape
150 Grit Sandpaper
Step 2: Original Table and Design
Tools:
Pencil
Tape Measure
Materials:
Original Coffee Table
We got this table several years ago from a European style furniture store in the area. The table had two platforms. The one on top has a glass insert the one on bottom was a solid piece. The are laminated particle boards. The glass was just resting in the opening on some coated steel pegs. The legs were hollow metal tubs with threaded steel rod on the inside.
To keep the aesthetics of the table I was going to use the bottom platform to build the sides of the box that was to hold all the gaming accessories. It worked out perfectly to cut it into three boards at 8" high each (accounting for blade cutting loss). This just happened to be the same height of the second platform, so the over all height of the table was going to stay the same.
The cubbyholes are 4" high and about 8" long by 10 3/16" deep. This got me 10 cubbyholes (I currently have 9 consoles hooked up).
As you can see from my original designs I was going to bevel cut the edges of the box and notch out the bottom for the sides to rest on the bottom MDF board. After I figured out how to do pocket screws, I just decided to pocket screw it all together.
Pencil
Tape Measure
Materials:
Step 3: Deconstruction
Tools:
Tape Measure
Dremel
Hair Dryer
Iron
Towel
Materials:
I started by test fitting the hinges and pulls. The first thing I realized is that they were not going to fit without removing some material from the top board. I cut the edging that was on the inside of the table (where the glass was) and then heated it up with the hair dryer and pried it off with a flat head screw driver. I then had to Dremel out the wood just a little bit more to fit the hinges. To make sure there was enough support I decided to put in three hinges.
Next I needed to remove the edging from the long edges of the board (but leave on the end caps). The Iron + towel served this job much better than the hair dryer. There was a little over hang from the edging on the short side that I just zipped off with the Dremel.
Tape Measure
Dremel
Hair Dryer
Iron
Towel
Materials:
Step 4: Cutting
Tools:
Pencil
Tape Measure
Miter Saw
Table Saw
Materials:
Masking Tape
Bottom board of Table
I cut the MDF and Bottom board of table down to size just using the table saw and fence. Make sure to use Masking Tape. Would actually be better to use the blue painting tape, but I did not have any at the time.
For cutting the one particle board in half and the cubbyhole dividers I used the miter push on the table saw. The cubbyhole dividers I decided to do an overlapping joint (not sure what it is actually called). I just used the miter push then would slide the board down 1/8" and make another pass. Did this until it was the correct width.
Pencil
Tape Measure
Miter Saw
Table Saw
Materials:
Masking Tape
Step 5: Pocket Screws, Pocket Screws, POCKET SCREWS!!!
Tools:
Pencil
Tape Measure
Drill
Table Saw
Sawhorses
3" C-Clamp
Materials:
The four cut particle board pieces
Ok, so a went a bit nuts with the pocket screws. There are 76 of them in this table... I really did not know how far to space them apart, and I was not going to be able to glue the wood because of the laminate. Doing this many in the future I would get one of the nicer Kreg sets. I will save that for next time.
The Kreg Jig I got was pretty easy to use. It comes with directions so you know to put it for what thickness material you have. I was going from 3/4" MDF into 1" Particle Board, or 1" Particle Board to 1" Particle Board. The one modification I would have to the directions is... it says to drill in one smooth motion. The problem that I see with this (actually my brother clued me into it) is that the bit heats up too much and will wear faster. I go about halfway in then bring the bit out a little to clean it up then press it in the rest of the way. I tried both methods, the two push method definitely keeps the bit cooler, and makes it easier.
Pencil
Tape Measure
Drill
Table Saw
Sawhorses
3" C-Clamp
Materials:
Step 6: Assembly of the Box to the Table.
Tools:
Pencil
Tape Measure
Sanding Block
Miter Saw
Drill
Square Driver Bit
Bar Clamps
Materials:
150 Grit sandpaper
I loose fit everything together make sure it worked. Had to hand sand some stuff down (Home Depot panel saw was not very accurate).
Then I took the new 3/4" MDF bottom board and screw it to the table top. I did this because I wanted to be sure that the sides were installed in the correct location and I did not care about the small holes as they would not be visible. Also the Particle boards were slightly warped after 3 years without a center support and would need to be clamped. I put the corner pocket screws in then removed the bottom MDF piece. Make sure you clamp the board in place because the pocket screw will try and pull the piece in the direction it is pointing.
After getting all the pocket screws install on the side boards I put in the cubbyhole dividers. I also put in spacers at the four corners to hold the 3/4" MDF board in place while I put in the pocket screws. I then removed the spacers after everything was screwed in.
Pencil
Tape Measure
Sanding Block
Miter Saw
Drill
Square Driver Bit
Bar Clamps
Materials:
150 Grit sandpaper
Step 7: Spray Glass and Install Legs
Tools:
Pencil
Tape Measure
Metal Chop Saw
Grinding wheel
Dremel
Materials:
Masking Tape
I decided to spray the glass so I could finish up the piece while waiting for it to dry. I put masking on the edges of the glass just in case (probably was not necessary since it had a frosted look already). I did three light coats.
The way the legs worked was a black plastic piece with a nut is screwed to the bottom of the table, and a threaded rod is screwed into the nut on the black plastic piece on the bottom of the table. The rod is then covered with a black plastic tube. Then you screw on the leg to the rod. I used metal chop saw and a grinding wheel to cut the threaded rod down then ran a nut from the other end (it has to come from the uncut side) to smooth out the threads.
The plastic piece that mounts to the table sticks out a little where the rod and nut is located, so I had to Dremel the bottom of the table a little. After that just put everything together.
Pencil
Tape Measure
Metal Chop Saw
Grinding wheel
Dremel
Materials:
Masking Tape
Step 8: Finishing the Construction.
Really the only thing left to do was install the glass top, and put on the metal pulls that allow you to open it.
This table is pretty darn heavy not, which is not a huge deal, but will make it a little harder to move.
The only thing I might tweak is put in something that would keep the glass top open without having to flip it all the way over.
The only thing I would have changed in construction was to buy a router. I needed to cut down the 3/4" MDF to 42 1/8" which I did not feel comfortable doing on my table saw, so I had Home Depot cut it on their Panel Saw, and it was not a straight cut. Because of this on one of the corners the board is a bit separated. Not horrible, but it bothers me.
