Afghan Camera E Faori
Introduction: Afghan Camera E Faori
The aim of the Afghan Box Camera Project is to provide a record of the kamra-e-faoree which as a living form of photography is on the brink of disappearing in Afghanistan.
Step 1: First of All:
Just like photography, building a box camera is not rocket science. There are a few elements which have to be carefully executed but for the most parts it is easy and not very exact. Obviously the more precise you work and the bigger your understanding of the topic the easier it will be to take good photographs.
Step 2: Cover and Protection:
In order to protect the wood and make the camera more resistant the carpenter either covered the camera with a vinyl fabric or applied thick layers or paint on all sides of the box and the tripod. They also used small pieces of sheet metal to protect the corners of the box.
Step 3: The Box:
The box should be 50 cm in length, 30 cm in height, and 30 cm wide. If the box is bigger it will be easier to place all your materials inside but more difficult to carry around; it also makes balancing the box on the tripod easier. All the measurements below are for a 50x30x30 cm ( 19.5x11.8x11.8 in.) size box.
Step 4: Compact Model:
typically measuring approximately 36x28x28cm (14x11x11 in.).
Step 5: Compact Box
You have to be able to open the box to get inside, so make sure to have good hinges in the back and some sort of locking mechanism in the front.
Step 6: Very Important!
The box needs to be light-tight as the photographic paper requires absolute darkness (except for red light) otherwise you won’t be able to take a picture. The floor part of the box should be stable as you will need to put chemicals and photographic paper inside. The floor should also be flat otherwise you will spill the chemicals. In addition, you will you need to screw a tripod mount into the floor. For this the floor should have at least 5mm - 1cm (0.4 in.) thickness. If the material of the box is not thick enough you can also construct a platform between the tripod and the box - but information on that will be provided further down.
Step 7: Rods:
You need three metal rods each with a length of 50cm anda diameter of about 1 cm (0.4 in.).
One of these rods should have some sort of handle on one end to pull and push. In the illustration we put a round piece of wood around the the rod. The two plain rods are used to stabilize your focusing plate and the rod with the “handle” on one end will be your focusing rode connected to the focusing plate.
Step 8: Focusing Plate:
The focusing plate is located inside the box and connected to three metal rods. To make sure the plate is stable and can be moved steadily we suggest y make it out of wood. It should measure 27 cm (10.6 in.) in width, 21 cm (8.2 in.) in height and about 1 cm (0.4 in.) thickness.
In the center of the wooden plate is a glass on which you put the photographic paper. This doesn’t need to be real glass; it could also be Plexiglas or an acrylic board. In the illustration we cut out a round hole and added the glass plate in the center. This is just an extra feature which will allow you to rotate the glass plate in horizontal or vertical position for landscape or group photos.
Step 9: Lens Hole:
The front requires a hole the same size as your lens. Depending on what lens you use it might be up to 8 cm in diameter. This hole should be aligned with the center of the focusing plate.
Step 10: Arm Hole:
The hole on the side is through which you later access the paper and chemicals with your arm. It should be between 8 and 10 cm (4 in.) in diameter. In our illustrated example with is a little door made around the side hole. This is an extra feature which allows you to put your chemicals and papers in and out through the side. It is not really needed as you can also do this via the lid of the box.
Step 11: Back Door:
You will need to make a small lockable door in the back of the box. This will be your viewfinder later on. It doesn't need to be big. Around 8x12 cm (3.1x4.7 inch) is enough. Parts of the door need to be cut out and replaced with red glass, Plexiglas or simple red plastic. This will allow red light into the box which does not harm the photographic paper. This light is needed for you to later check the developing process through the eye hole.
Step 12: Eye Hole:
The eye hole on the top of the box allows you to check on the developing process of the photographic paper. It should be small, with the diameter not exceeding 4 cm. On top of the hole you can put any kind of material on which you can press your eye and stop light from entering the box. There are many ways of covering the hole while you are not looking inside. In our example we use a small shutter attached to the inside of the lid. With a pin this shutter can be accessed from outside the box.
Step 13: Connecting Rods and Focusing Plate:
The rods and the focus plate as seen in the illustration are now put together. The holes in the focus plate through which the rods are inserted should be a little bit bigger than the rods themselves so that you can move the plate. The end of the focusing rod is the only one attached to the focusing plate. This will allow you to move the plate from outside.
Step 14: Paper Box:
It makes working a lot easier if you make your own customized paper box to fit the dimensions of your box camera. This paper box has to be light tight and easy to open as you will access it with only one hand while the box is closed. The paper box should be able to fit under the focusing plate once it is installed with the rods in the camera.
The box we used for our camera is 18 cm (7 in.) wide 12 cm ( 4.7 in.) deep and 4 cm (1.5 in.) high. It has a divider in the center to store different sized paper. It could be made out of wood or cardboard or any other solid material.
Step 15: Trays:
You will need two trays: one for the developer chemical and one for the fixer chemical.They can be big or small depending on how big your images will be. For example 10x12cm (4x4.7 in.).
Step 16: Lens:
If you don’t want to use a lens or do not have the budget for a lens make a pinhole box camera (see the next page).
The kind of lens you use will determine the size of your image. If you use a lens from a 35mm camera your image size will only be 24x36 mm (0.9x1.1 in.). The ideal lens would be a large format camera lens. You can get relative cheap ones in second hand markets or online auctions. You could also use the lens of a photographic enlarger. The advantage of using a large format camera lens is the adjustability of aperture and shutter speed. Enlarger lenses can only adjust the aperture. You would also need to make a lens cap/cover if using an enlarger lens. Removing this cap for a certain amount of time serves as your shutter speed. The lens we illustrate here is a enlarger lens without shutter control.
Step 17: Note on Making a Pinhole:
Use a strong black paper or thin metal and attach this to a bigger hole cut out in the center of the front of the box.The glass plate on the inside of the box should be about 7-15 cm (2.7x6 in.) away from the pinhole. The pinhole should have an opening of about 0.5 mm. That would give you a good result. To get this opening you can use a No.10 sewing needle to push through the metal or paper (push it halfway in). The more circular the whole the better for a detailed focus.
Step 18: Tripod:
You will need to make sure that the box is stable. The tripod should be strong enough to guarantee this. Either buy a professional tripod mount and attach it to the box or replace the pin in the tripod with a long screw. Drill a hole into the bottom of the box, then stick the screw through and tighten it up with the right nut. To enforce this construction glue thin circular metal plates on both sides of the box. If your box is not made out of thick material you could also connect a base (e.g. wooden board) to your tripod and place the camera on top of that. Original Afghan cameras have very big wooden tripods allowing great stability; these tripods like the cameras are made by carpenters and weigh a lot.
Step 19: 20 Negative Holder:
In order to get a positive picture you will need a negative holder which hangs in front of the lens. Later on you will place your negative onto this holder and photograph it to create a positive image. This construction can be made of wood or light metal. The distance from the lens to the negative depends on how big you want your positive image to be. All you need are two pieces of wood or metal at a right angel (90°) to one another and attach this to the front or bottom of the camera. In our example camera we used a hinge to which the negative holder is connected in the front of the camera.
If you don’t want to build a separate construction for this last part of the process, stick the negative to a wall or any other flat vertical surface and take a picture of it.
Step 20: Display:
Many of the box cameras in Afghanistan have displays on the side of the camera. The photographers use this display to show examples of their work. Essentially the display is a framed plate of glass on hinges. And behind this photographs are attached to the box.
Step 21: Tools Drawer:
Another extra feature you might want to add to your camera is a drawer for tools such as scissors or finished photographs. The drawer is located underneath the paper box. It has to be relatively small otherwise there won’t be enough space inside the box for the paper box and the focusing plate.
Step 22: 23 Sleeve:
As a last step you have to put a light-tight cloth around the side hole through with you will later access the inside of the box. The fabric which should be formed like a sleeve and be able to cover your arm at least up to the elbow. You could also use an old jacket if it is made of a suitable material. Most cameras in Afghanistan have old jacket sleeves attached to them.
Step 23: ​Complete View
Complete View
Step 24: Decoration:
The carpenters who build the cameras as well as the photographers using them applied their own aesthetic sense in beautifying the kamra-e-faoree. Strong colours, curved wood, photographs, mirrors and stickers can be found on many cameras.
Step 25: Lens Shield, Compact Disc
The carpenters who build the cameras as well as the photographers using them applied their own aesthetic sense in beautifying the kamra-e-faoree. Strong colors, curved wood, photographs, mirrors and stickers can be found on many cameras.
Step 26:
Step 27:
Step 28:
Step 29:
Step 30:
Step 31:
    • Paper Contest 2018
      Paper Contest 2018
    • Trash to Treasure
      Trash to Treasure
    • Science of Cooking
      Science of Cooking
    I love all forms of cameras! I'd love to see what pictures you take with your E Faori Camera!
    It will take a black and white picture as black and white picture was using at that time back in 1990s, but now I'm working to take a color picture with this camera :) . anyway thanks for comment!
