Aging Paper
1,667
41
Published
Introduction: Aging Paper
In recent projects, to create the affect I was going for, I needed to make new paper looked aged. I went through a variety of different techniques to do so until I found one that is very effective in creating the look of age paper while still keeping the paper easy to work.
Step 1: Supplies
Here are the supplies I use to age my paper
Ground Coffee
Water
Pan
Cookie sheet
Step 2: Mix Coffee and Water
Start by filling up the pan with water and mix in a couple spoonfuls of ground coffee.
Stir the ground coffee and the water together and let it sit for a few minutes or until you can see the water changing to a light brown color.
Step 3: Place Paper in Water
The next step was to place the paper in the water mixture. I completely submerged the paper into the water and let it soak for about 5 minutes.
Step 4: Bake
After the paper soaks for five minutes, I pulled the paper out of the water mixture and set it on a cookie sheet for baking,
I set the oven to 200 degrees and bake the paper for about 10 minutes. At the end of 10 minutes the paper should be completely dry and peel up from the paper.
Step 5: Finished
Once I pull on the paper out of the oven it is ready for crafting!
Enjoy!
    • Slow Cooker Challenge
    • Flowers Challenge
      Flowers Challenge
    3 Comments
    This makes the paper get a water look. I instead use a teabag soaked in water. Just rub it across the sheet and bake. Green tea gives a milder look ...like it was in a library for a few years.
    nice idea for aging paper crafts! I dye manila tags in triple strength instant coffee for a few minutes then let them air dry (yes I wind up with cookie sheets of tags all over the house drying out). This is faster tho, I like it :)
    Will it go through an inkjet printer?
