Step 4Fitting it all together
The longer lengths of tube are for the reservoir (2l bottle) and for the filler stem post. Ideally, everything should be in the same plane except for the gauge post. Therefore, I recommend you make attaching the reservoir the last thing you cement together. I find an angle of about 45 degrees is ideal for the gauge post - this allows your hand to naturally hold it and allows easy viewing of the gauge while refilling.
If a part has threads, do not cement. Instead - wait until after you paint (if you choose to do so) and use the Teflon tape to seal everything.
The last picture is with the optional add on. Everything AFTER the ball valve was not cemented in place. It will not be holding pressure and allows me to change my mind on what should go there (ie another 2l bottle). If anyone needs a better description, let me know and I'll take the time to go more in detail.
4
comments
Add Comment
Deathcapt
says:
Add Comment
