Remove these ads by
Signing UpStep 1Gather Materials
- 5000 BTU Window Mounted Air Conditioner Arpox. (Cost Variable)
- 2 Yards of Ripstop Nylon which will be more than enough (Cost: Aprox. $14.00)
- 1 Bottle of Fabric Glue INSERT NAME OF GLUE HERE (Cost: $6-10)
- Bungee Cords (Cost: $3-5)
Note: Sundays a lot of the craft stores have 40% off coupons which can save you some money on the glue or fabric.
Links:
http://www.joann.com/joann/catalog.jsp?CATID=cat3071&PRODID=xprd560961
http://www.beacon1.com/cgfab.html
Im assuming the tent which is highly uninsulated get hot again as soon as you turn it of.
Running the air con all the time would shorten its life . A portable unit with a hose would be an easier install.
If your hot open the doors!, or better yet just use the mosquito mesh without the fly
never been to florida but i did spend 3 months in the amazon living in a hammock underneath a $2 tarp and slept like a baby.
I think this is a wonderful idea. I've been camping far too many times when the heat made it impossible to sleep, even with fans and such. An AC would have been a godsend.
And please, can we cool it with the global warming guilt stuff? Just because you tolerate heat better than I do doesn't give you carte blanche to run roughshod over me, any more than my ability to tolerate cold better than you (probably) and therefore don't run my heater for most of winter makes me better than you. We all do what we can. I'm VERY concerned about warming and other environmental concerns, and already do much more than 95% of the general population. There's no harm in running a modern efficient small ~5000 BTU AC that draws around 3 amps @ 117 VAC (351 watts, minus reactive losses because I compensate for this.) Resistive losses are due to actual work done. Reactive losses are due to phase shift caused by inductance (+ j) or capacitance (- j) and do no work. Reactive power losses can be "tuned" out of electric devices with magnetic type motors (refrigerators, air conditioners, etc.), saving significant electricity waste. Any electronics engineer or halfway decent tech can explain power factor, inductive/capacitive reactance, operator "j", and how Xc neutralizes Xl and vice versa. Whatever inductive or capacitive reactance (measured in ohms) is present can be tuned out with the same value of capacitive or inductive reactance.
If you're concerned about environmental problems, you'll do more by learning about stuff like this than playing energy-cop with those who don't know better. Physician, heal thyself.
Apologies to anyone I may have offended. That was not my intent. You'll make more converts leading by example than lecturing.
-Mike "Saving energy because I can't afford to waste it" Curtis
If I camp I use a tent hammock this is the best way to keep cool when you have no electricity reason this works is you are off the ground surrounded by air and can swing to induce a breeze if you have none.
If I had the luxury of camping with a AC I would loose the tent all together and build a panel structure that had UV protection on the outside. this would be a bit bulky but would be very cool almost frigid. Odds are if you are using a AC you are using a car/truck?
