Step 5Creating the Connecting tube
Make sure when cutting and measuring the fabric for the tunnel to account for a few inches of overlap when you glue the tube together. 2 to 3 inches should be more than enough overlap to make a strong bond, press and make sure the glue does not bond to the bottom part of the tube.
Now you need to measure the 4 corners in the hole of the tent and apply them to the tunnel to make flaps to connect to the tent. I used about 3 to 4 inches of flap length to secure the tunnel to the tent.
Once everything is done you can use bungee cords to secure the tunnel to the A/C unit and then roll the tunnel up to fit better, the tunnel should be stretched so it does not sag and reduce air flow but do not pull too tight.
EDIT: Once again the tube could be shorter since I ended up having the actual A/C unit poking into the tent (see picture).
Add Comment
