Too hot or too cold? Make it just right (and make Goldilocks proud) by building this dual-purpose device.
Down here in Arizona, we've got some pretty hot summers, at around 120 degrees. And inside, it gets up to about 88, which is a bit hot for my taste, especially when I've got my computer on- then it's even worse.
Or, if you live somewhere cold and wish your room was warmer at night, just flip a switch and your wish will be granted with this air cooling and heating machine.
And it's cool looking too!
Step 1: Materials
Oh man. This project requires a bunch of stuff, but you probably have most of them lying around from old broken things.
You do keep old things you don't use any more in a parts closet, right? Good.
-2 80mm computer case fans: I used one of a normal thickness and one half-sized one with more blades. You'll see why later.
-A transformer: I got mine from an old speaker set that I converted to run on batteries. It steps 120VAC down to 13.5VAC.
-4 diodes for making a bridge rectifier: Also from the speaker set; converts AC to DC.
-A 4700 uf capacitor: That's all I know about it. It just came from the speaker set, but I only know that it's 4700 ohms. It filters the DC current so it doesn't pulse.
-A 60mm x 60mm heatsink: Mine's aluminum. Bought on eBay. Right after I got rid of a bad computer motherboard I could have taken it off of. Oh well.
-Thermal Tape/Compound: Used for attaching the heating device to the heatsink.
-52mm Peltier Cooler/Thermo-electric cooler: Bought on eBay, it's the heart of this project. It gets hot on one side and cold on the other. You could probably find one on an old camping cooler along with the heatsink.
-A 6"x4"x2" project box: A bit tight for this project, you could get one that's a little larger.
-3 SPDT toggle switches, or 2 SPST and 1 SPDT toggle switches: For switching things on and off.
-A general purpose PC board: Got it at RadioShack; it came with two boards with 213 holes each. Perfect for this.
-2 1.5K ohm resistors: For the LED's.
-2 LED's: Any color, I choose one green and one red.
-A piece of flexible plastic: I got mine from the bottom of a dead power supply, but you could use anything that's thin and non-conductive.
And some basic tools:
-Soldering Iron
-Rosin Core Solder
-Drill with bits
-Hole-Cutting Bit
-Dremel with Cut-off Discs (Best tool ever!)
-Insulated Wiring
-2-prong electrical plug with cord
-Heatshrink Tubing or Electrical Tape
-Hot Glue Gun: (Optional)
Step 2: Wiring the Circuit
For your benefit (and mine for not having to explain everything) I've included a schematic/wiring diagram of the circuit. I will, however explain the flow of electricity to you can get a better understanding.
The electricity flows from an electrical outlet into the two leads of the transformer (polarity does not matter, just make sure you know which side of the transformer is the input and which is the output). Then, converted from 120VAC to 13.5VAC, it flows through a bridge rectifier circuit with the capacitor (see the second image, courtesy of Wikipedia). The bridge rectifier changes the AC voltage into a pulsating DC voltage with a + and - , and the capacitor (wired as shown, make sure you wire the + to + and the - to -!!!!!) filters the current to smooth out the pulses into a constant flow of electricity. From here, the negative lead goes to the first switch's middle prong. One of the other prongs is then connected to the middle prong of the other two switches, as well as to an LED with a resistor (resistance will vary depending on your transformer). This LED is then connected directly to the + lead of the capacitor, making a circuit.
Moving on to the second switch. Wire one of the outer prongs of the switch to the - lead of the Peltier unit and wire the + lead directly to the + lead of the capacitor. Wire this same prong to another LED and resistor (make sure you've got the correct polarity on the LED: the notched or flat side is usually negative). Then wire the + lead of the LED to, you guessed it, the + lead of the capacitor. The center prong of this switch should be connected to the first switch.
Finally, the last switch. The middle prong is connected to the other two switches. Connect the - lead of one fan to an outer prong and the - lead of the other fan to the remaining prong. Then connect both of the + fan leads to the + lead of the capacitor.
Make sure everything's insulated with tape or heat-shrink tubing as well.
You're done wiring!
Step 3: Drilling & Cutting
Boys and girls, it's time to break out your drills and Dremels!
If your transformer is a wee bit too tall to fit in the project box, you're going to have to do what I did- Dremel a nice hole for it to stick out of. Look at the 2nd picture to see how it will fit. Try to put the transformer as close to the end of the box as possible.
I don't have a picture, but if you look at the 2nd picture, you can see how I cut a (really crappy) hole in the box for the fan. Just use the biggest hole saw you have and then slowly make it bigger by using smaller hole saw bits until it gets to be the size of the fan. Also, drill a couple smaller holes for screws to hold the fan in.
Cut a small hole in the back (opposite the transformer) of the box for the two leads of the thinner fan, then run them through and solder. Make sure you cut the hole BEFORE soldering, otherwise you'll just have to unsolder the connections to run it through. You could also cut a small slit in the box where the lid connects to just set the wires in, but it won't look as pretty.
Next, cut a rectangular hole JUST the size of the Peltier cooler in the top of the box (not the lid!). You might have to cut a couple slits for the leads to rest in as well. Make sure that the side that gets hot is facing away from the box and the cold side is facing in.
While you're looking at the top of the box, cut three holes for the toggle switches (mine were 1/4") and try to make them in a straight line, equidistant from each other. Drill a couple of smaller holes for the LED's as well. I put these holes next to the 1st and 2nd switch.
Drill a few holes in the transformer side of the box for some air flow past the components. That transformer and those diodes get hot, you know!
Finally, drill a few large holes on the side of the box with the Peltier unit. These holes will be the ones that cool air is blown out of.
Put away your tools, cause you're done with cutting!
Step 4: Various Things...
Some various things to do to complete the project.
First, attach the thicker fan. You want to place it so that it's blowing INTO the case (there should be some arrows in the plastic near where the wires connect to show you how the air flows. You might have to cut off all the other plastic tabs on the fan to make it fit against the side of the box and mesh with the component board. Using a couple small screws that fit in the holes in the fan (and in the holes you cut in the box), attach the fan and a fan grill. You'll probably only be able to attach 2 screws. Then, using some needle-nosed pliers, bend the two remaining "arms" on the fan grill 90 degrees to make little feet. These will hold the fan up off the surface its on so it will be able to get decent air flow.
Next!
Using some thermal tape or thermal compound, attach the heatsink to the top of the Peltier unit. The heatsink basically just rests on top of the case. I used thermal tape to hold things together, but if you use thermal compound, you'll probably have to engineer some sort of brace system to hold them together.
Cut a piece of thin plastic (3rd picture) to use (1) to prevent a short circuit between the transformer and a switch and (2) to prevent all your chilled air from blowing past the hot components and coming out hot. Some air will be blown past them to cool it a bit, but not as much as there would have if the plastic was not in place. You'll need to tinker around with cutting sections out of the plastic for the wires to go through.
Just sort of place the PC board as close to the side of the case as possible so that the fan will fit. Make sure there aren't any short circuits! You can add a bit of hot glue to keep it on the side, but I find that the fan pushing against it works well enough. Plus, I was out of hot glue.
And....
Finally, grab your AC plug with a cable, strip the wires inside as well as the wires to the transformer, insulate everything, and solder the one wire form the transformer to one wire of the plug. Do the same with the other wires.
Step 5: Close It Up!
After some careful maneuvering of the transformer, fan, wires, and circuit board, run the AC cable through the transformer hole and close up the lid. Just thumb tighten the screws to hold it on for now.
Plug it in, and flip the first switch. One of the LED's should light up, and a fan should start spinning. When you flip the third switch, the other fan should start spinning instead. Now flip the second switch. The other LED should light, and the first LED will probably dim. The fan will slow down as well. This lets you know that the Peltier unit is working. Place your hand on the heatsink. Within a minute, you should start to feel it get warm. If the bottom fan is running, you should feel cooler air blowing out the back of the case. Thus, the cooler.
If you place the smaller fan on top of the heatsink so that it's blowing down, and you align the front edge of the fan with the front of the heatsink, hot air will be blown into the room when that fan is on. Thus, the heater.
Oh, the reason I used the smaller fan with more blades here is because I discovered that you get more airflow than using the thicker fan.
I'm sure there are ways that this project could be enhanced or made to work better, so if you have suggestions, please comment! Thanks, and enjoy this useful project!
1-40 of 102Next »
autumnwind3 says: May 22, 2012. 10:03 AM
For the folks looking for parts, try American Science and Surplus. They had a Peltier junction in stock last time I looked. I always look for unusual parts there first.
TeslaBoy says: Mar 26, 2012. 9:32 PM
might want to clean up your schematics and why not just get a pc rectifier then bother with the whole diode setup
bowmaster says: May 30, 2011. 4:38 PM
About the fans: Lots of blades means lots of air, but also lots of noise. Fewer blades means less air, but also less noise. That's why fans you buy at the store fo cooling rooms have fewer blades, so they will be quieter.
lloydrmc in reply to bowmasterAug 4, 2011. 6:11 PM
With computer fans, it usually has more to do with RPM than blade configuration
_Scratch_ in reply to bowmasterJun 4, 2011. 7:11 PM
I always thought it was the other way. My 9 bladers pull maybe 35-40DBs alone, but I see 3 blades that pull about 65DB. Sure the 3 blades were moving about 150-200CFM, but for a 120mm fan, 60DB is a bit much.
bowmaster in reply to _Scratch_Jun 5, 2011. 7:19 PM
Yeah, if you have a bunch of different things it'll vary, but that's what I've noticed.
juan saab-rafful says: Apr 9, 2011. 2:03 AM
Yuor proyect is so practice. Some one Know how to maque a Peltier module.
Thanks to very much
SAludos
Juan Saab-Rafful
Rybka30 says: Mar 10, 2011. 12:40 PM
I think it´s only air heater - energy only make energy.
I think that energy what you put to it=heat, what you get from it.
It´s physical rule. you can chill some space, but in the fact, you will heat air in the room, but not all air...
I apologize for my English.
neodymio says: Feb 11, 2011. 11:15 PM
The module peltier needs a 6 amps power supply, diodes can dissipate high amp? diodes 400x dissipate 1 or 1.5 amps
fauge7 says: Jan 1, 2011. 2:05 PM
we in az just had snow in peoria!!! its too cold for us in the valley
fgonzales says: Sep 12, 2010. 10:20 PM
I think you wired your bridge rectifier wrongly. Take note of AC input and DC ground.
mr. clean says: Oct 9, 2009. 9:50 PM
how many watts is ur peltier unit and what happens if u reverse the polarity to the peltier unit?
dagenius in reply to mr. cleanSep 4, 2010. 9:08 AM
If you reverse the polarity, the side that is meant to get hot will get cold, and the side that is meant to get cold will get hot.
kretzlord says: Aug 12, 2008. 4:45 PM
I don't want to take away from the awesomeness of this at all, but to be really effective, the opposite side of the peltier that you aren't "using" should be exhausted into a room/outdoors where you are not. Just a thought, great Instructable!
Entropy512 in reply to kretzlordJul 12, 2010. 9:58 AM
Yup, without having one side connected to outdoor air (preferably also drawing in outdoor air), all this will do is heat the room it is in. It may cause local cooling within the room, but overall it will heat the room. 1) If being used as a heater, it will be a lot more expensive than just a set of resistors. (Things change a lot if it is pulling heat from the outside air.) 2) If being used as a cooler, it would only be good for keeping PC components cool, or cooling off a drink (or drinks). 3) It might work well as a dehumidifier if you run ducting such that air that passes over the cold heatsink then passes over the warm one. This will condense water out of the air on the cold HS, and then warm the air back up, providing warm dry air. (Good if the room is cold and humid, and the one case where it would be a better solution than a purely resistive heater.)
dagenius in reply to Entropy512Sep 4, 2010. 9:06 AM
The laws of thermodynamics FTW.
dagenius says: Sep 4, 2010. 9:05 AM
Ah, but you see, by the laws of thermodynamics, this will not work. What I mean by this is that although the peltier unit cools one side, it heats up the other, and because it does have internal resistance, the heat will inevitably overpower the cold. while it may cool down the air directly in front of it, it creates heat elsewhere. What the peltier unit does is absorb heat on one side, and release it on the other.
bowmaster says: Jul 9, 2010. 7:31 AM
This looks nice. Could it keep a 4'X8'X2' padded box at ~72 dregees F in 100 degree F weather for a few hours?
Mr. Potato Head in reply to bowmasterSep 3, 2010. 7:05 AM
Would this be a box of your native soil in which you take refuge during the daylight hours? It probably does get kinda stuffy in there, especially during the summer months.
bowmaster in reply to Mr. Potato HeadSep 3, 2010. 9:05 AM
No really, more of a closed up climate controlled bed.
Mr. Potato Head in reply to bowmasterSep 3, 2010. 9:20 AM
Same difference...
natester632 says: Aug 9, 2010. 8:26 AM
How many volts should the fans be??? please respond
videokid842 (author) in reply to natester632Aug 11, 2010. 2:44 PM
I used 12 VDC fans with the ~13 VDC transformer, but if you're using a different transformer, you may need to add resistors or get fans of a different voltage.
natester632 says: Jul 12, 2010. 5:48 PM
hey uh where do u get the peltier thingy? like wat thing can i take apart and find that thing inside of?, please respond
kington99 in reply to natester632Jul 13, 2010. 4:57 AM
those mini fridges you can get for keeping drinks cool have a Joule-Peltier effect system in them, which would be around the right size for this project
natester632 in reply to kington99Aug 9, 2010. 8:28 AM
Anything else lol I don't have a fridge I want to destroy lol
suza_phone says: Jun 9, 2009. 10:59 PM
Can you say where you got the thermal tape from? Thaaanx.
videokid842 (author) in reply to suza_phoneJun 10, 2009. 8:14 PM
I found it at Fry's Electronics.
zack247 in reply to videokid842Jul 12, 2010. 10:54 AM
what about in canada?
kalo02 says: Feb 3, 2010. 3:42 AM
potential for it to be solar powered?
zack247 in reply to kalo02Jul 12, 2010. 10:52 AM
maybe with one of those car battery charger solar panels, they have to put out about 13v to charge the battery
firechicken says: Jul 12, 2010. 6:45 AM
do you sell these portable air conditioner and will it cool an old car
tech-king says: May 4, 2008. 9:23 AM
that cap is 4700 uf, not 4700 ohms
videokid842 (author) in reply to tech-kingMay 4, 2008. 6:57 PM
Right, sorry. My bad; it's resistance that's measured in ohms. It's fixed now.
TogetherinParis in reply to videokid842Jul 11, 2010. 10:03 AM
Resistance is futile anyway.
lane29 says: Jun 6, 2010. 9:32 PM
do you live in atlanta
electronicdude says: Jan 3, 2010. 12:55 PM
Instead of going to the trouble of building the 120 volt AC to 13.5 Dc adapter, just use a 12 volt wall wart. Its safer to use than having 120 volts coming into your container. Its simpler, and saves time and money.I realy like the saving money part about it. I can go into RadioShack for a very simple and small project and spend $25. The main thing is use a wall wart.
uberdum05 says: Dec 4, 2009. 1:33 AM
You might want to use a centrifugal fan or a squirrel cage fan to get more airflow :)
mr. clean says: Oct 12, 2009. 7:23 PM
haha u sure have a mess going in the background in ur first pic.
ibuildcoolstuff says: Sep 30, 2009. 8:01 PM
would it be possible to do this with two project boxes. Have one housing two or so of these trasnformers and have the other hold two or three peltier units as well as the fan so you could get even more cooling.
1-40 of 102Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
