Step 5Close It Up!
Plug it in, and flip the first switch. One of the LED's should light up, and a fan should start spinning. When you flip the third switch, the other fan should start spinning instead. Now flip the second switch. The other LED should light, and the first LED will probably dim. The fan will slow down as well. This lets you know that the Peltier unit is working. Place your hand on the heatsink. Within a minute, you should start to feel it get warm. If the bottom fan is running, you should feel cooler air blowing out the back of the case. Thus, the cooler.
If you place the smaller fan on top of the heatsink so that it's blowing down, and you align the front edge of the fan with the front of the heatsink, hot air will be blown into the room when that fan is on. Thus, the heater.
Oh, the reason I used the smaller fan with more blades here is because I discovered that you get more airflow than using the thicker fan.
I'm sure there are ways that this project could be enhanced or made to work better, so if you have suggestions, please comment! Thanks, and enjoy this useful project!
This project would, however, be a great idea of a soda can cooler/coffee mug heater where the can/mug itself is the cooled/heated "environment" and the room would be the outside environment. I need one of these for my desk!!
