Step 4: Fly wheel - Preparing the casting
  • Cut runner off casting
  • Clamp and drill Ø6.8mm hole through the centre of the casting then tap a thread at M8
  • Take a large diameter aluminium or steel rod (Ø25mm or above). Centre drill it and then drill a Ø6.8mm x 30mm hole
  • Cut the head off a M8 x 50mm bolt, file the sawn edge and put into the rod
Ahmed2 says: Mar 6, 2012. 12:47 AM
vedry good
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
