Air Pressure Rocket
555
4
5
Posted
Introduction: Air Pressure Rocket
Do you want to have a rocket which can fly about 20 meters high? In this instructable I show you how to make one without many tools and materials.
Notes: First I want to apologize for any spelling mistakes I might make since English is a second language for me. Also I want to point out that there is a similar rocket instructable ("homemade water rocket demon! boom!") which I only saw when I was done with building my rocket.
Step 1: Materials
To build the rocket you will need:
materials:
  • a bottle (preferably hard plastic and thick walls)
  • 3 skewers
  • 2-3 straws
  • a platform eg a piece of wood
  • a valve from a bike
  • a plug (rubber or cork)
tools:
  • a drill
  • a hot glue gun
  • a bicycle pump
  • (optional) some paint, paper or other decorations
Step 2: Launch Pad
To make the launch pad you first have to draw a circle the size of the bottle in the middle of the platform. Now you need to mark 3 equally spaced points on the circle. To do that easily you can draw a equilateral triangle in the circle.
After that you have to drill the holes the size of your straws.
Now you can stick the straws into the holes with a hot glue gun.
Step 3: Valve
To get the valve into the plug you have to drill a hole into the plug (it's harder to drill a hole into rubber than into cork). As long as the hole isn't too big you don't need to stick the valve in. (Don't forget to cut off the rests of the bicycle tube.)
Step 4: The Rocket
Before you can go on you have to decide if you want to decorate the bottle as a rocket. But be carefull the heavyer the bottle is the less high it flys.
After decorating you have to stick the skewers on the bottle so that they fit perfectly into the straws.
Step 5: How It Works
To start the rocket you have to go to a place where you have a lot of space eg a meadow. Then you fill a third of the bottle with water, push the plug-valve into the bottle as hard as you can, connect the bicycle pump with the valve and pump!
Step 6: Bevore and After
If you want to see how robust your rocket was you can make before and after pictures.
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    3 Comments
    Shared with my son. I hope he and his buds try it.
    Pretty cool!
    Does it just launch on its own once a certain pressure is reached?
    I've made rockets like that and yes they do launch by themselves once the pressure reaches the point where the cork gets popped out. I like the idea of the three sticks and straws to hold it straight during the launch.
    Most rockets like this are water rockets, but I see no mention of water in this tutorial. You make them exactly the same way as described but before launching, you fill it about on third full of water before pushing in the cork. The reaction of the water being expelled makes the rocket go much higher than air alone would do, Just be aware that when it lifts off, the person operating the pump will get soaked!
