An Infantry Support Gunner is a unit consisting of one or two people. Their mission is to support their team's attacking infantry with heavy gun fire from a covered-up position, like behind rocks or from inside foxholes. They fire at defenders in enemy positions or counter-attacking enemy troops. They need heavy guns, like Electric Classic Army M249, Hobbytron.com, .12gram or .20gram (it's under the gunner area, get to it by clicking on the airsoft button). Look for a gun you can deploy a bipod or tripod on, and for a good one, get one that has a ammunition box.
Your job: When the infantry is moving, your firing at the enemy from a protected area.
Remove these ads by
Signing UpStep 1Training
The troops have to set both feet down into the first tires, then make their way to the end. Their feet always need to be in the tire all the way to the end, then run in S-like shapes back. Sitting to the side, you have a four-foor wide by eleven foot long by at least 8-inch deep hole, filled with water and mud. Support fence wire above the muddy hole and have the soldier army-crawl through it. Second picture.
After he gets out of that, 20 jumpingjacks. Then, he needs to get down on his knees and shuffle like that at least 9 feet. Then he has to crawl, swim, & wade through a water-filled trench at least three feet deep, two feet wide, and at least 4 feet long. Put wire/fencing or any type of barrier on the sides. This part's only nessesary if troops will have to cross a river. Make him do this a couple of times.
After this, he has to run a lot, do plenty push-ups, jumpingjacks, & sit-ups. Once he's proven his physical worthness, put him through combat practice with other team members.
Also, I don't see anything related to airsoft here. Forgive me if I'm wrong, but isn't airsoft a small 6mm plastic pellet projected with compressed air, CO2 or a spring?
You're going to put someone's eye out with that kid...
