Air-freshener based mechanical laser shutter
 by pranavrathi
Featured
I have constructed a cost-effective mechanical laser shutter system for our 1064 IR-laser. System contains a mechanical shutter, a control box and a power supply. There are many shutter systems available commercially; mechanical, semi-mechanical, electromagnetic and optical. Most of the systems are expensive and above $1000. These systems are fast (msecs to micro secs) and precise. In our case we needed a shutter which is precise and cost effective but not so fast. So here it is. Some of the specifications of the system:
Another link:http://openwetware.org/wiki/User:Pranav_Rathi/Notebook/OT/2010/10/31/Laser_Shutter_.1
Type mechanical with electronic control. Can also be controlled by a micro controller.
Aperture 10mm.
Open time 1.5 second, .3 second over the beam waist.
Cost $ 30 excluding the power supply.
Operational voltage 3.3, 5 and 12 volts.
Laser intensity upto 10 W.
There might be many ways to make a mechanical shutter; I used eclipsing technique in which a shutter moves over and across an aperture through which the beam passes. To move the shutter I used an electric motor and a gear box. This method is relatively hard because of the motor timing (build all the electronics is not easy). While working on this I got couple of ideas of achieving the same goal in 1/10 of the work and time: A 6 inches audio speaker with/without a micro controller can be converted in to a shutter (I will use this method if I plan to make a shutter for He-Ne) OR simply an electromagnet with a cantilever can be used as a shutter. The advantages of such a systems are, easy to make and similar in speed to commercially available systems.
Step 1: Components
There are three major parts of the system.
Shutter.
Control box.
Power supply.
The components used:
Shutter
Glade automatic air spray: Air spray uses a motor and gearbox to mechanically operate the spray bottle, which i used to move shutter.
Thorlab Cage System Removable Filter Holders CFH1: To make shutter holder and shutter.
Two 3 inches cage assembly rods: To install the shutter holder on the skin of air spray.
Black aluminum foil: To make the shutter.
Control Box
2 3-pole on/off switch
1 Push on/off button
2 CD4013 4013 IC CMOS DUAL D FLIP FLOP IC
1 Resistor 100K Ohm
2 Resistor 10K Ohm
1 Resistor 100 Ohm trimmer (pot)
1 Resistor 1.5k Ohm
3 Resistor 240 Ohm
1 1N4148 diode
1 0.1uF 50V Ceramic Capacitor
1 222uF Radial Electrolytic Capacitor
1 npn KD-7B C1815 Y transistor
2 14 pin DIP IC Socket Adaptor Solder Type
2 RED LED 3mm
1 Yellow LED 3mm
1 A-5032 Prototyping Board 300x400 mm
1 12V relay
1.5m red, black, green and yellow wires
1 6X8 cm aluminum box.
3 Banana connectors M&F (yellow (+12V), red (+5V) and orange (+3.3V))
1 Powe Jack M&F
Power Supply
I used 300W desktop computer power supply which i salvaged from an old computer.
ajoyraman says: Nov 11, 2012. 8:37 PM
Wonderful of you to share a novel use for the air-freshener innards !
Why after so many years ?
pranavrathi (author) in reply to ajoyramanNov 17, 2012. 4:01 PM
Thanks Ajoy for liking it. I actually do open-science; means I put all my research work online on openwetware.org. And when I made this shutter I did not know about instructables. But all is well now I am going to start using it.
I have seen you also have some nice posts up there, keep up the fun!!!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
