iImage Information
How to make a water bottle launcher out of pieces of pvc. Can shoot Very long distances. What you need is: About 2 feet of 1/2 inch piping, two 1/2 inch threaded to 3/4 inch corners, two 1/2 inch threaded joiners, 2 feet of 3/4 piping, a 3/4 inch end cap, a popped bycicle tube, and a 1/2 inch threaded ball release valve thing. Tools you will need are, a drill, and pipe glue. Optional parts are, a soda can for a blast deflector. If all that just confused you, just look at the picture.
Step 1The end Cap
iImage Information
This is important to make carefully because you do not want any leaks here. What you do is cut the plug piece out of the bike tube. Then drill a hole in the end cap that is just smaller than the tube piece. then use some kind of glue (I Used Loctite extreme repair)and put it on the tube piece. then hammer it into the hole you made on the end cap.
