Air Pressure Regulator Stand
Published
Introduction: Air Pressure Regulator Stand
This a simple 3D-printable stand for an air pressure regulator and cleaner. Although you could use an in-line regulator to change the air pressure, there aren't many options for inline dust/oil filters. Air filters are typically designed to be wall-mounted, so I just designed a small stand that kept the filter upright on my bench.
Step 1: Print the Stand
Print out the attached STL. The geometry will work as-is on a FormOne (that what I used), so you'll probably have to make modifications to work on other 3D printers.
Step 2: Add the Pressure Regulator and Fittings.
The pressure regulator and fittings came from McMaster Carr.
The pressure regulator (McMaster 4989K101) is a combination regulator and filter. It removes oil and other particles down to 0.01 micron. The regulator adjusts from 7-120 psi.
The input fitting (McMaster 52115K202) is a push-to-connect fitting for 1/4" OD tube. You'll want to swap this part if you want a barbed or other type of connection. Just make sure it has a 1/8" NPT end to screw into the regulator body.
The output fitting (McMaster 5203K918) is a push-to-connect fitting for 1/8" tube. Again, if you need a different output, just make sure it has a 1/8" NPT end to screw into the regulator body.
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    5 Comments
    Your stand is pretty fancy. I'd usually just keep mine in a coffee can if I needed it remote.
    I'm sort of compulsive about neat work spaces. I love workshops that have outlines for all the tools on the wall where they go...
    My workshop might not look neat but even though I hadn't seen my
    regulator holder since I moved it over seven years ago now, it only took me
    a minute to find it.
    Thinking about it this morning I did eventually make a dedicated stand for my regulator. It has just been so long since I've used it that I forgot about it last night. Mine is made out of some scrap pallet wood glued up, and put together with pneumatic brads. I don't recall the project taking me a whole lot of time to knock together really. It certainly has a patina of dirt on it today. Anyhow here's a picture of my regulator stand that cost me just about nothing to make
    Cool. Thanks for sharing this.
