3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Air Cannon
Air Cannon
  • last photo ←
This is an air cannon that I built this summer to shoot mini tennis balls to my dogs. Of course I also shoot other things like potatoes, tomatoes, apples, etc. Hope that you enjoy the slide show.
36 comments
Jan 18, 2011. 3:39 PMDumchicken says:
here's mine you just duct tape it to an air compreser aim and fire
Feb 9, 2011. 7:57 AMComputothought says:
An Ideo!
Mar 23, 2010. 12:44 PMComputothought says:
My first burrito blaster that I am in the process of building.
Sep 13, 2008. 5:56 PMcowscankill says:
Interesting gun, though if you build another, give it a better design so it is easier to hold, carry, and then shoot. My firsdt air gun had no stock, my second had too big of a stock, and my last gunI built is sooo freaking huge, I put my arm through the stock so I can get some support. So just keep in ming, any gun design that is preferably compact, small, easy to wield, and shoots well is great. Nice gun for a first though ;-)
Feb 6, 2010. 1:22 PMstephenniall says:
Yeah  ! thats good advice My best gun so far i took a bb gun pistol apart and used the handle from that as a Grip and mounted the piezo behind the trigger so i can use that !
Always a good idea to have a Sling and a stock !  A good idea for a stock is to cut a slot down  a piece of pipe Heat it up and push the pipe together and tape it .
Works great
Aug 22, 2009. 7:39 AMclemsonguy1125 says:
I tested it and what works great is 2 90 degree elbows next to the tee
Sep 19, 2008. 4:18 PMcowscankill says:
I just finished version 5 Air rifle, and is is mostly S shaped. the top of the s is extended into a barrel, the middle of the S has a trigger, and the bottom of the S has a 2 wide chamber. That is how mine is compast ;-)
Sep 25, 2008. 2:24 PMcowscankill says:
One problem: The tests I've done so far let it only shoot 20 ft at 30 psi :( My other gun goes like 100 ft at 30 psi... I might need to do some more tests.
Sep 27, 2008. 8:20 AMcowscankill says:
Um... a tight wad of aluminum foil works well, but not in my compact gun... They both have the same trigger, a modded sprinkler valve.
Aug 22, 2009. 7:40 AMclemsonguy1125 says:
Try a piston valve
Aug 23, 2009. 5:43 PMcowscankill says:
Oh haha... I know this is an old post, but I found out that only half of one of the end caps was glued on. I applied glue all the way around, and it works fine.
Aug 25, 2009. 6:51 PMcowscankill says:
I think so. The compact version.
Aug 27, 2009. 5:44 PMcowscankill says:
Should I like try a video? or slideshow?
Aug 28, 2009. 6:03 PMcowscankill says:
Sorry, Currently working on an 'ible :D Remind me after I post it :P
Aug 20, 2009. 2:36 PMclemsonguy1125 says:
What size is the barrel
Jul 24, 2009. 7:56 PMalejosbin says:
(removed by author or community request)
Jul 17, 2009. 6:16 AMtots says:
How much did it cost to build and how long did it take.
Jul 2, 2009. 1:52 PMaahutner says:
what is the diameter of the barrel?
Feb 2, 2009. 12:51 PMFUNKEY_DUNKEY_MONKEY says:
I tried it and found you can use two 9 volts instead of three.
Jun 10, 2009. 10:53 AMcovey12 says:
i would pneumatically mod the sprinkler if i were you
Jan 26, 2009. 11:22 PMFUNKEY_DUNKEY_MONKEY says:
how do you power the sprinkler valve ?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:rock climber(Austin's Stuff)
