3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Airgun with eXplosive air-Release Valve
Forget amateurish sprinkler valves. Look no further than this type of valve for making airguns or anything where you need the air released explosively. This is my own design inspired by the valve inside an airbrush.
This instructable shows you how to make what I call the XRV (explosive release valve), which can be attached to a bicycle pump. This in turn allows you to turn an ordinary blowgun or pea-shooter into something a bit more serious.
The video does a lot of explaining, but for more detail including how it works, see the next steps.
Step 1Materials and Tools
Materials and Tools
To make the XRV, you need a handful of easy-to-find components:
Materials
1. Flexible bike pump hose - comes with most bicycle pumps)
2. Brass or aluminium tubing (about 1-2mm) - available from hobby stores
3. O-Rings (tiny) - available from hardware stores
4. Small spring - also from hardware stores
5. Tiny screw that fits into the end of the 1-2mm tubing
6. Tiny nut or washer that fits onto the brass tubing (see video)
Tools
1. Hand drill & very small drill bit
2. Fine file
3. Blade
4. Precision screwdriver
5. Pliers or multi-grips (pictured)
6. Hand clamp
7. Superglue
243 comments
1-40 of 243next »
Feb 21, 2012. 4:20 PMmerchantofdeath says:
PLZ RESPOND can a larger version be created with this design obviously stronger materials though. and i was wondering if instead of a bike pumb could i use a co2 cartridge. the cartridge wont be hook up directly to your device but will instead be put on a reservoir with a shut of valve and all that good stuff. btw never made a air gun but know how and what to make a gun the shoots 5 canadian quarters attached together. hopefully somewhere around 700+fps. something that will put a hole through a wall and another wall and so on. by the way AWESOME DESIGN
Feb 4, 2012. 11:36 AMtinker234 says:
could i modify this gun to be automatic http://www.amazon.com/Crosman-1377C-PC77-Black-pistol/dp/B006QVTBVG/ref=pd_sim_hi_85 to shoot darts
May 11, 2011. 4:08 AMmilamber says:
i machined a much larger version of this for my air rifle would anyone like to see a slideshow or ible??? credit to chluaid
of course
Nov 28, 2011. 6:37 PMhbelanger says:
I would love to see what you have
huguesb.1968@gmail.com
Aug 15, 2011. 8:27 PMbiolethal says:
yeh a slideshow would be nice.
Aug 11, 2009. 7:58 PMpyrotech25 says:
I have been looking for this video for years. im making an automatic bb gun (pistol) and this is perfect for the trigger. thanks a lot man!
Oct 31, 2009. 10:33 AMzipzapper859 says:
if you make the automatic bb gun please post it on instructables because i have been also trying to make one...the hard part is making it automatic
Nov 28, 2011. 6:47 AMhbelanger says:
Got to start by saying thank you for this instructable the best I've seen so far.
I haven't settles on what I will build yet, BBMG or single shoot, but one thing is for sure I will be using your valve ins some fashion.
for you gents that are looking for an automatic simple design I found the following a while back and it seems to be a nice fit for this valve.
automatic BB gun
http://www.swanstrom.net/petes/shoot/autobb.htm
Have fun and stay safe...!
Sep 30, 2011. 4:11 PMTimmyMiller says:
how big of a pellet can this shoot?
Sep 30, 2011. 4:01 PMTimmyMiller says:
where did u get the hand drill?
i really,really,really, REALLY WANT ONE!!!
May 23, 2011. 7:57 AMpdub77 says:
This is a wonderful design and your video was awesome as well! Good job!
Mar 18, 2011. 7:57 AMsabladask says:
i want all the tubes in step 3.....
where did you get them?
Mar 18, 2011. 7:52 AMsabladask says:
finaly!! i found somone who actualy knows what hes doing,.'
Grate woork!
i made a simulare gun som years back:) i have made very many air guns, and the valve you made is very good :):)
see my channel i if you are intrested in a springpowerd airpistion gun.
keep up the good woork!
Nov 15, 2010. 12:33 PMostomesto says:
hey im planning to make this but dont have the bike tube for it. could i use a ball inflation needle to do the same thing as it. i lost my old bike tub and hope this will work
Feb 9, 2011. 12:20 PMatomicwaterstudios says:
why dont you just go out and buy the tube then there probly no more then 5 bucks?
Feb 9, 2011. 12:26 PMostomesto says:
i didnt know where to find them. but i got it. I made one well not really. I made one that is a trigger for my spudgun, it's the pilot on my sprinkler valve.it about 5 in long and never leaks air. It has a huge airflow too. I will post a pic of it and how to build it if you want me to
Nov 15, 2010. 1:06 PMostomesto says:
ahahahahaha i found my old tube. it was in my air compressor parts box. i looked in there hundreds of times and it was right in front of me. hahahhaha im so happy :)
Nov 16, 2010. 12:06 PMostomesto says:
one last thing. i made this and it worked great. i am going to try to make a larger scale one for a trigger on my sprinkler valve in my spud gun. any ideas on what materials i would need to make a larger scale one. oh and would a large scale one hold around 60-70 psi maybe 80
Jan 7, 2011. 2:52 PMMadBricoleur says:
Happy late christmas. http://nerfhaven.com/forums/index.php?showtopic=19073
Dec 19, 2010. 1:50 AMCheeseduck says:
Rather than going through the hassle of hand-drilling, you could just use the small round hand file to make the holes. If you file perpendicular to the pipe, it'll make a good path for the air to escape.
Nov 23, 2010. 10:49 PMwellbankj says:
Do you have any idea how much pressure you think this little valve can take? I'm thinking of making a gobstopper gun that I can kill squirrels with and I'd like to maximize my energy output. I'm thinking of using a compressed air or CO2 tank as a power source and a regulator to tone down the pressure that's behind the valve.
Nov 13, 2010. 5:20 PMfreerunnin1 says:
i'm going to make one of these tomorrow and im using a piece of pipe from a telescopic antenna :P, they come in loads of different sizes
Nov 18, 2010. 3:00 PMostomesto says:
ya antenna works great. just take out each pipe form it and u have lots of choices. it is a can bend and is a little flimsy though :(
Nov 13, 2010. 5:06 PMfreerunnin1 says:
great vid! lol, how long did it take you to come up with the valve? oh and how many pumps would it take to propel a bb over say, 75 foot?
Oct 30, 2010. 10:17 AMmoGuyver says:
Excellent animation in the video - also great valve design.
Oct 23, 2010. 6:27 AMquirxi says:
Cool vid - you should go to the film industry ! :)
Oct 7, 2010. 4:08 PMTopunisher says:
Can the hose(on the pumping stick) take on the pressurized air with-out getting it explode?
Aug 23, 2010. 8:02 AMFredock says:
nice vid
Aug 16, 2010. 6:56 PMmilamber says:
no chance youd make my life easy and sell me one would u ?
Aug 16, 2010. 3:10 PMEnigmaMax says:
Suspension pumps are not cheap! Would an tire pump suffice?
Jul 6, 2010. 5:35 PMbrum says:
It think adapted with a harmer or something like that with a reasonable pvc tank or something and you might have yourself a multi-shot bb gun. You could potentially up size into a paint ball gun (uses almost the same principal)
Sep 15, 2008. 1:46 PMMattrox says:
this is very cool for a blowgun or dart gun but sprinkler valves are used for their quick release of air which this wont let out enough air fast enough unless you supersize it. no offense intended very cool design by the way
Sep 17, 2008. 12:46 PMAnarchistAsian says:
but sprinkler valves are big, bulky, un-stylish and over-priced! this one is small, and looks good with all the brass and other metal parts.
Sep 17, 2008. 12:52 PMMattrox says:
true but, they let tons of out because they have big openings. this has a tiny opening have a longer realese time
Nov 13, 2008. 1:47 PMthejrb says:
How would you know? Have you modded your sprinkler valve or does it still use battery's? This valve is probably faster than an unmodded sprinkler valve.
Nov 19, 2008. 11:21 PMblugyblug says:
UNmodded sprinkler valve. If you are comparing the XRV to an unmodded sprinkler valve thats just...stupid
Jun 10, 2009. 6:21 PMultimachris says:
that's true, but this valve was intended for shooting bbs, not potatoes. thats why it is so small.
Dec 23, 2009. 3:37 PMfork me3 says:
guys all you need to do is supersize the XRV!!!! i almost did it yesterday... i used 9/16th brass tubing some pvc a larger spring... larger orings... larger everything! just remember. its not im possible. all i need to do is make it air tight and im pretty much set. good luck, and wish me luck. If i get it to work im gonna hook it up to my nerf longshot :D so when i pull the trigger it released the air.
Jul 6, 2010. 5:21 PMbrum says:
Depending on how big it is dude it may not work that well. Because when you release this valve you a pushing in back against the stored pressure it may be quite a difficult task pushing a bolt back against 90psi of pressure. I have made a marble gun using a modified sprinkler valve and the advantage of that is you have a trigger and no effort required (if u dont know how they work: diaphragm and difference of pressures) and blugyblug, ur not talking much sense when your comparing it to an unmoded sprinkler valve because an unmodded sprinkler valve is useless for making any kind of gun (do some research and learn how they work). I do think this is ideal for something like a bb gun. I went to china as a student a few years back and bought a bb gun (illeagal in australia) and had to pull it apart and fix it once and basically when you cocked it, that was the pumping action and then i think it may have used a valve similar to this to release. GREAT VID!
Sep 17, 2008. 1:18 PMAnarchistAsian says:
it's a small valve... the barrel is small, so it doesn't matter much how small the opening is. and about that release time... if you look inside a sprinkler valve, there is a big loss of power, since the air has to take several sharp turns before it even reaches the barrel. sprinkler valves suck! they're made to actuate the sprinklers on your lawn! even with modification, nothing beats a custom made one!!!
1-40 of 243next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
56
Author:chluaid
I make stuff!
