3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Airgun with eXplosive air-Release Valve
Step 11Attaching to a bicycle pump
As we made the XRV from a male connector, it will attach perfectly to any bicycle pump.
You will however, need a bicycle pump that doesn't allow air to go backwards. In other words, it needs to have its own built-in one-way valve. If you don't have this, you won't be able to compress more than one plunge of the pump.
Many pumps (bicycle pumps, sports ball pumps) come fitted with a one-way valve, but the 'BBB Airshock' pump that I use has a one-way valve PLUS a reinforced hose. When the end of this hose is blocked (with my XRV), it acts as a small air tank. Air will be compressed in that tiny space and will only be released when I open the XRV.
Opening the XRV into any type of blowgun (simple pea-shooter or deadly ninja blowgun) is the aim of the whole exercise :D
5 comments
Feb 21, 2012. 4:20 PMmerchantofdeath says:
PLZ RESPOND can a larger version be created with this design obviously stronger materials though. and i was wondering if instead of a bike pumb could i use a co2 cartridge. the cartridge wont be hook up directly to your device but will instead be put on a reservoir with a shut of valve and all that good stuff. btw never made a air gun but know how and what to make a gun the shoots 5 canadian quarters attached together. hopefully somewhere around 700+fps. something that will put a hole through a wall and another wall and so on. by the way AWESOME DESIGN
Aug 11, 2009. 7:58 PMpyrotech25 says:
I have been looking for this video for years. im making an automatic bb gun (pistol) and this is perfect for the trigger. thanks a lot man!
Oct 31, 2009. 10:33 AMzipzapper859 says:
if you make the automatic bb gun please post it on instructables because i have been also trying to make one...the hard part is making it automatic
Nov 28, 2011. 6:47 AMhbelanger says:
Got to start by saying thank you for this instructable the best I've seen so far.
I haven't settles on what I will build yet, BBMG or single shoot, but one thing is for sure I will be using your valve ins some fashion.
for you gents that are looking for an automatic simple design I found the following a while back and it seems to be a nice fit for this valve.
automatic BB gun
http://www.swanstrom.net/petes/shoot/autobb.htm
Have fun and stay safe...!
Oct 7, 2010. 4:08 PMTopunisher says:
Can the hose(on the pumping stick) take on the pressurized air with-out getting it explode?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
56
Author:chluaid
I make stuff!
