Step 9Seal it off
Now you can see why the head of the screw needed to be larger than the shaft. The head of the screw stops the O-Ring from slipping off.
And with that, the XRV is complete!
The spring is always holding the valve closed so air will not escape.
You can test this with your mouth. Seal your lips around the housing of the valve and blow.. build up a little air pressure in your cheeks then pull the washer/nut backwards (don't push it down your throat!) The air should escape through the tube.
Note: if air is leaking through the valve, then it could be that your O-Ring isn't sealing it too well. Try adding a second O-Ring.
comment
Add Comment
Add Comment
