This Instructable will detail the simple steps involved in covering a balsa structure with plastic wrap (or cellophane, or food wrap, or Saran wrap--whichever name you prefer). No, it's not as strong as Monokote or Ultracote, and probably not as strong as tissue. It certainly isn't as easy to patch as tissue. However, it's much lighter, cheaper, easier to find, and better at showing off the underlying structure.
My original attempt was to replicate the look of the SIG Rascal, which I find to be one of the nicest-looking covering jobs on a sport flyer. I wasn't sure how well I could combine tissue and plastic, so I went for a more basic approach. Pictured is my SIG Tiger, which has a similar design, but a longer nose (since there's no engine to balance it).
Some of you may remember the forum topic I posted quite awhile ago on this subject.
Step 1: Materials
You need:
-Frame The balsa aircraft, sans covering. Or with any tissue trim, if you want.
-Plastic wrap Plastic, Saran, food, or cellophane wrap. Call it what you want, find something in pretty colors. I raided this from the kitchen drawer a year ago, and I don't think Mom knows that it's gone yet.
-Glue stick Nothing fancy here. I raided this from the office. Aren't raids fun?
-Heat gun That is a manly-looking piece of equipment. The one in the basement didn't look nearly manly enough for me to photograph it, so I raided this from a garage. Raid!
-Scissors and razor blade (not pictured) Some scissors work better than others. I don't know why.
Step 2: Build your airframe...
This image shows the little frame I built to demonstrate this technique. It's just some scrap balsa I had, so don't start bugging me about the rhombicosidodecahedron I could have built instead. I also have a picture of the horizontal stabilizer of that SIG Tiger-I recovered one side of it at the same time (I...um...dropped a Dustbuster on the plane and tore it. Yeah, really.), but since the other side was already covered, it's harder to see.
Step 3: Prep the frame for covering
You'll notice that I'm using a blue glue stick. That allows me to see what I've already covered, and the color won't be visible because I'm also using blue film.
Step 4: Place the film covering
See Step 3 of this Instructable for another rundown on how to lay it out.
Step 5: Shrink it down...you're done!
As the film shrinks, you will see it stretch tight, and the texture will become shinier. As soon as you see this change, stop heating that area, because that's as shrunk as it gets. Don't even think about using an iron on this; all you'll get is dented covering. I used a big industrial-type 1700W heat gun, just because it's huge and awesome-looking, and made me feel like a lumberjack, but a hair dryer is plenty, and will probably work even better because of the lower temperature. Keep the heat gun/hair dryer fairly far away from the covering as you can, because it is so easy to melt through before you get used to it. With the big heat gun, it shrank nicely from about 18 inches away.
Once it's shrunk, place it covering-side-down on a smooth, clean surface (I used the glass top of my desk) and carefully run a razor blade along the edges of the frame to trim off the excess.
Step 6: Maintenance
Congratulations! You've just finished a nice-looking aircraft, and at the same time, you cheated Top Flite out of a $18 roll of Monokote.
Visit Our Store »
Go Pro Today »
http://www.stevensaero.com/AeroLITE-p-1-c-39.html
The Aero Film - AeroLite has got to be the best covering I've used for light weight, small balsa and tissue aircraft/airframes. In addition you can cover an entire plane for about $5-$10 depending if you use one or more colors. You did a GREAT job with your plane and the article.
