3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Airsoft (1600 fps)
Airsoft (1600 fps)
OK so for about 30 dollars and ~2 hours, you can have your own super accurate butane powered air soft gun, wrist mounted shooting at 1600fps. Its an attachment to the hidden blade and it can also be used by itself.
Youtube is having troubles with the audio =(
Step 1Materials and tools!!!
All of the parts were avb. at my local hardware store
You'll need
1 Male NPT quick release
1 Female npt valve
1 9/32 brass pipe (No Bigger or smaller!!!)
13/32 brass pipe (adapts and fit to most standard butane bottles, check to make sure ti fits first)
1 butane bottle
plastic bb's
metal putty!
5/16's cork
light load 1/4 od spring
1/4 npt to 1/4 inch hose barb
2 feet of 1/4 hose
Hot glue
Dremel!!!
Cresent wrench
42 comments
1-40 of 42next »
Mar 27, 2012. 2:19 PMcrmartin says:
I really doubt people play air soft with you i mean really that could go straight through a mask or googles
Mar 21, 2011. 9:59 PMvulcan13 says:
you shot youre freinds with this gun there is no way it shoots at 1400 fps you could go hunting with that thing the 22. 250 can kill a goat at 200yards shoots that fast there is no way it goes that fast i have even shot the 22. 250
stop over exagerating
Dec 29, 2011. 10:52 AMiperrin says:
Despite your consistent claim that a .2 gram, .23 gram, or .25 gram bb would do nothing to damage you, you are incorrect. The standard airsoft gun fires bb's somewhere between 250 and 450 FPS. Increasing this by some 5 fold does drastically increase the chances that you will break the skin, and embed a plastic pellet deep into someone's skin. The convenient thing about your design, as mentioned on another comment, is that the pellet is traveling no where near this speed. On Butane, which as also mentioned above is unsafe, you'll be pushing somewhere between 300 and 350. On HFC134a, also known as duster gas, or compressed air, you'll be pushing somewhere between 200 and 250. This is also assuming you have a perfectly pressure tight seal on the entire design, and I would doubt that with the components that the every day person has access to.
Your manner of measuring, the number of sheets the pellets travel through, is also not accurate. There are several threads posted on the forum Michigan Airsoft (MIA) that have reliable, tested methods of determining the general speed of a projectile. I suggest you take a Google search over there, and see what you can find. You might get a better, more accurate reading of your FPS.
Aug 23, 2011. 1:05 PMMultipleParadox says:
Ok we'll do this nicely and quickly:
Most airsoft gas-guns works on propane/greengas right?
The high-range of these airsoft guns will reach about 550 fps, rarely 600 fps, at about 25ºC. And that is considered a lot, as 400 fps is enough to cause tissue damage. All this using 0.2g BBs.
Now, the propane is used in the same way as you use the butane; the gas expansion propels the BB.
Let's go check what's the Critical Pressure of both gas (that means the MAX pressure you could theoretically get no matter the temperature, not the pressure you actual have in your canister, which is much lower for security reasons)
Butane: 3.8 MPa
Propane: 4.257 MPa
Conclusion? You speak bullsh*t
I doubt butane would even give you more than 350.
Still not bad at all actually, but 1600fps? Come on. It's clear you don't even know what that means
Aug 23, 2011. 1:11 PMMultipleParadox says:
Try this, it's been a proven empiric way of measuring fps, and is likely to be much much more accurate that your paper thing (that one made me laugh so hard, thanks for that)
http://www.instructables.com/id/Poor-mans-airsoft-chrono/
Dec 29, 2011. 10:42 AMiperrin says:
You're completely right. 1600 FPS is a Class D firearm as well, and ranges inside the firing potential of a .22LR.
In addition, do NOT use butane in ANY form of cycling, projectile firing device. Butane is VERY unstable - this is why you can throw a lighter at the ground, and it will explode - so running around with a pressurized container of butane, which feeds into a chamber to fire pellets is unbelievably dangerous. Consider switching the gas to propane, a more stable gas used for other pressurized gas airsoft guns.
Sep 21, 2011. 10:38 AMilpug says:
okay, this is A) not shooting that fast on can pressure alone, and B) give me better directions, so i actually know what the heck to do.
Mar 21, 2011. 9:54 PMvulcan13 says:
1400 fps can half way through a deer
a can of butane or propane is not going to do something like that
Aug 19, 2011. 8:28 PMbroper says:
actual take this hole situation logicly i dout it is realy 1600 fps like nehi beacos you said light travels fast but its so small a bullet travels slower but its bigger it like the difrence if some one throu a cell at you and a rock at you but on the mater of y i dont think it 1600 fps is beacaus i have a stor bot bb gun that shot apr 1200 fps and it can shout thro 4 and a half cans lined up in a row what vulcan13 said might be true i have never actualy shot a deer beafor so i cant tell but a can of butane cant shot 1600 fps it might reach 900 fps tops but a good gun non the less
Feb 12, 2011. 7:47 PMmikemurph says:
your math isn't even based on any velocity calculations...
Aug 19, 2011. 12:48 AMsoccer-5 says:
You are absolutely correct. Look at his units and you will see that he is going on a tangent.
Aug 19, 2011. 12:49 AMsoccer-5 says:
Please state the exact equation you used and where you received your constants from. Stop being so vague please.
Aug 19, 2011. 12:42 AMsoccer-5 says:
Why don't you chronograph this "1598 fps" gun to test your work.. You bring up basic high school equations, but I'm pretty sure they tell you to test your results? I am sure you will find your error
Aug 14, 2011. 12:41 PMnehi says:
Umm I dont think that it could shoot at 1600 fps. An old pistol shoots at about 850 fps and that can kill you if it hits you in the right area. A paintball gun can shoot about a fifth of that and it can bruise you pretty badly. One person was shot by a paintball gun and it hit him on the side of the knee cap cracking it through the middle. I seriously doubt that it can shoot as fast as you say it can.
Feb 26, 2011. 10:25 AMsabladask says:
I did exactly the same mat as you. The only difference was that mine went through 17 sheets of paper instead. With your calculations it would have gone 2200fps. As I do not believe at all!
by the way god build
Feb 20, 2011. 4:35 PMTrace II says:
Constant of paper/FPS conversion? What are you even talking about? Are you trolling?
Feb 21, 2011. 3:26 PMTrace II says:
That doesn't explain how you got that constant. It seems like you just made it up.
Feb 12, 2011. 7:45 PMmikemurph says:
there's literally not a chance in the world that your gun shoots at any supersonic speeds. Its a nice project despite the gross miscalculation of the FPS
Feb 7, 2011. 1:32 PMsabladask says:
(removed by author or community request)
Feb 5, 2011. 6:59 PMkve23 says:
itd be sweet if you added a crystal igniter and use combustion to ignite the butane as propellant
Dec 11, 2010. 9:48 AMspark2FLAME says:
Wow! If this thing really shoots as fast as you said then (while it is an airsoft bb) shoots just as fast (or faster) than a Glock 18. While the G 18 has to shoot a round 60 times heavier than your bb (assuming its a .12 gram) that is still a scary idea! Nice job and be careful!
Dec 27, 2010. 10:10 PMosirisov says:
Tell that to my hand, which has a .12 gram BB from a pellet gun at 480fps.
Feb 5, 2011. 7:06 PMkve23 says:
he could have thin skin or softer skin
Jan 19, 2011. 10:12 AMilpug says:
so where does the combustion occur?
Jan 19, 2011. 9:11 PMilpug says:
yeah, im sorry, i misread something and thought it said combustion. badass gun though, if a bit dangerous... okay, ALOT dangerous :P
Dec 8, 2010. 6:32 AMTSC says:
Sweet!
1-40 of 42next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
29
Author:itsthatsguy
