3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Airsoft BB Holder
Airsoft BB Holder
An easy airsoft bb holder made from a simple pill bottle and a straw to act as the spout.
Step 1The Materials
The Materials
All you'll need is a a couple of things you can find around your house.
1.Empty pill bottle
2.Straw (big enough for the bb's to fit through)
3.Airsoft bb's
4.Drill
5.Drill bit (the same size as the straw)
6.Scissors
7.Hot glue gun
8.Hot glue sticks
9.Popsicle sticks
20 comments
Feb 2, 2010. 5:24 PMknuckel says:
i will make one for my gun,
mp.7 500 clip. fully auto/ simi, and 200 psi
Dec 6, 2010. 8:17 PMCapt. Kidd says:
psi? or do you mean fps? (and "simi? you mean semi. (right?))
Dec 28, 2010. 9:40 AMknuckel says:
yep
Apr 8, 2010. 7:25 AMvan gog says:
 drill a hole in the bottom of the container and voala you got a homemade machine airsoft gun you just need to feel it with bbs and blow thru that hole that you just made and the bbs go flying out!!!enjoy!!!
Dec 4, 2009. 8:11 PMjonathan111 says:
Great idea. There are so many different things to hold pellets...it's ridiculous...but this is one of the better ones.
May 20, 2009. 5:42 PMtehgreatiam says:
(removed by author or community request)
Aug 2, 2009. 7:03 AMtoogers says:
he meant load the pelleets into the gun to fire later.
May 6, 2009. 3:09 PMcasman1 says:
like the one i made i got a glue stick and drilled a hole at the bottumn and it was a ring at the bottom and i put a bic pen tube in it and i can take the cap off to refill
Mar 28, 2009. 1:05 PMbeastieboy says:
all you need to do now is stick a pen tube through the bottom and you have a full auto airsoft gun!
Jan 27, 2009. 8:56 PMberky93 says:
to stop the bbs from falling out, try this- cut the straw to your desired legnth, plus the legnth of the pill bottle, plus 2 milimeters or so. then using something hot, bend the outside 2 milimeters of the straw outwards so its like a really tall top hat. or alternatively put a ring of hot glue around the outside of the straw and let it dry. now stick the straw through the hole in the cap so the stopper (hot glue or bent straw) is on the inside. this will prevent the straw from being pulled out but still allow it to slide in and out of the container. to close the container, push the straw all the way in untill the opening at the bottom is touching the bottom of the container. no bbs can get in that way. to open, pull the straw out untill it stops. now you can pour bbs as usual
Jan 26, 2009. 9:57 AMjhk30 says:
cool I made 2 but mine are a bit modded
Jan 24, 2009. 6:39 AMjhk30 says:
Cool, I am going to try it! nice job. but like they said bbs can fall out =(
Oct 17, 2008. 6:35 PMcowscankill says:
is there a way to keep the BBs from coming out?
Nov 30, 2008. 12:05 PMggiihh1 says:
maybe a pencil eraser stuffed into the straw will work??
Sep 11, 2008. 9:39 PMEnigmaMax says:
great, now my gun's a pill popper.
Sep 7, 2008. 5:24 PMmusic is my lfe2 says:
that works good
Mar 11, 2008. 4:47 PMGorillazMiko says:
Smart recycling idea. Maybe you could add in an LED light at the bottom, and the clear ones could light up and look so cool. Nice job!
Apr 14, 2008. 12:58 PMfldhkygoalie says:
but ifyour sneaking arond you dont want your pocket to be lighting up
Jun 30, 2008. 12:29 PMcodongolev says:
touche.
Jun 17, 2008. 8:32 AMCapnTac says:
Good idea! It'll be easier to walk around with a couple of these in your pocket than to be carrying a huge ammo canister.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:hunter88
