Introduction: Airsoft Grenade
An airsoft grenade that can be made from household materials that requires no explosives and explodes in mid-air
Step 1: Materials
You will need:
A tube at least three inches long
Duct tape
A screw
Thin rod
Small weight (optional)
Spring a little longer than tube
String or fishing line
Rod the same width as the tube's hole
Step 2: Getting Started
Take a drill and drill a hole at least twice as wide as the thin rod on the side of the tube.
Step 3:
Insert the spring into the tube and secure it with a screw through the lower part of the tube. The place a cap of duct tape around the part of the screw sticing out. You should probably put some tape over the bottom end so bb's dont fall.
Step 4:
cut a small notch into the bigger rod. This will help you load the grenade and stick the key under the rod and over the spring.
The video's pretty bad, sorry about that. You shove the rod into the tube, and make sure the notch lines up with the hole. You will then put the thin rod into the hoe to lock the spring. Dont put the thin rod in too far. The thin rod can be replace by anything, preferably a hook. You can then attach a fishing line to the hook. Gently place (dont stick hard) duct tape on the opening after putting some bb's.
Now you are ready to launch. This is reusable if you could not figure that out on you own. When you throw this, hold on to the other end of the line. Once its far enough, it will lanch all of the bbs as the hook is yanked out. This is convenient since you dont have to buy an expensive reusable. Put some spin on it so the bb's dont all go in one direction. If the key doesn't pull out, add a weight and make sure it is not too far into the hole. I borrowed this concept from a land mine you tube video. I also made a multi bb launcher with a big spring and attached it to the side of my gun.
