3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Airsoft M72 LAW rocket launcher
Using an airsoft 40mm grenade shell for the reservoir and valve system, build a nerf launching LAW for about 60 dollars plus the cost of one airsoft 40 mm grenade shell.
WATCH THE VIDEO!!! - It explains how the launcher works.
Edit: People keep asking about the Strap/Sling. it is a 1 inch wide cotton webbing strap purchased at a local fabric store. Buy about 1-2 yards. Also buy velcro and 1 inch plastic buckles.
Edit 2: People STILL keep asking about the "Locking Mechanism". Seriously, it is nothing but a piece of plastic. But since I get questions on youtube, here, forums, private messages and email, I decided to make a video. WATCH the video in STEP 7.
EDIT #3: If others have a method to use a DIFFERENT GRENADE, Please Post a comment. Then we can Collaborate on making an instructable for using a DIFFERENT GRENADE. I have brainstormed methods of using other grenades but they all BREAK my Rule OF K.I.S.S. With that said, I ONLY RECOMMEND THE MAD BULL XMPB4 or the S-THUNDER GRENADE. Don't Ask me about other grenades.
Step 1How it works
How it works
Illustration of what is happening inside.
My sorry excuse of a drawing of what is going on side the launcher.
Pictures are in sequence.
Color Code
Red = Grenade, 40mm type
Orange = Nerf Mini Vortex
Green = Green Gas
Blue = Valve
Black "T" = firing pin.
Picture 1 = Launcher ready
Picture 2 = Pin presses Valve
Picture 3 = Valve Open and Gas Explodes Out.
Picture 4-5 = etc....
298 comments
1-40 of 298next »
Apr 8, 2012. 6:54 AMHitman227 says:
I live in Canada and I cant see to find part no. 3001-215. Part no. 3000-215 is avalible but Im not going to purchase the grenade unless the grenade fits in that coupler. On the fernco website it says that part no. 3001-215 is 2" CI, PL. or ST. to 1-1/2" Copper or 1-1/4" PL while part no. 3000-215 is 2" CI, PL or ST to 1-1/2" CI, PL, or ST. I assume that the grenade will fit in part no. 3000-215 becuase the 1.5" end is 38.099999999999994mm's and should fit the 40mm grenade snugly. Thoughts?
Apr 14, 2012. 6:03 AMHitman227 says:
OK Thanks.
Apr 3, 2012. 4:13 AMHitman227 says:
How much did this cost in total?
Apr 7, 2012. 12:46 PMHitman227 says:
OK. Thanks!
Mar 22, 2012. 1:48 PMRango19 says:
Ive finished my law, and it turned out great. one problem i have is that the grenade (Mad Bull XM-PB4 Dummy Round BB Grenade Shell) will jam. after firing it once ore twice, the valve that is pleased does not come back out all the way. this makes it unable to be filled. i had my friend bring his mad-bull shell over and it did the same thing. did you have this problem? if so, how did you fix it?
Mar 26, 2012. 6:40 PMthecrow117 says:
on airsoft grenades you need to push the button in until you hear a click with a pen or something similar and release this resets the grenade.
Nov 4, 2011. 5:57 AMgnazaire says:
Is there any substitute to fiber glass???
Mar 9, 2012. 8:03 AMtheRx says:
If we wanted to go for carbon fiber, what would you recommend? Multiple layers like you did with the fiber glass? Single layer with a thicker sheet? I understand that using the fiber will probably make the build more expensive no matter what, but I'm just trying to minimize cost while making the outer tube (hopefully) more durable.
Nov 1, 2011. 8:29 AMcdaniel2 says:
Just out of curiosity, would the launcher be able to fire loaded 40mm grenades instead of nerf balls? Like, if I loaded the grenade and left the nerf ball out, would it damage the weapon?
Nov 1, 2011. 8:37 PMcdaniel2 says:
This is still me. I've also noticed that it uses a different type of grenade. So, if I loaded a bb-type 40mm grenade, instead of the multipurpose grenade and Nerf rocket, would it damage the fiberglass tube?
Aug 21, 2011. 3:38 PMboredom99 says:
Hey where do you find nerf balls I already checked walmart they didn't have it and I don't know if toys r us has it. I know that Toys r us and everything discontinued their sale of nerf vortexes for some reason so where could you find those?
Jul 28, 2011. 8:14 PMawesomesauce24 says:
how many times do u wrap the wax paper and mylar around the pvc
Jul 4, 2011. 5:35 PMyish1919 says:
where did you get the gas can or online? cuz i buy things online more then in the stores
Jul 4, 2011. 5:25 PMyish1919 says:
Which air grenade is better, or is all of them are the same and have the valve on the back?
Apr 21, 2011. 11:01 AMblslespaul says:
what is yours or anyones average range with the S-Thunder grenade? Im building several LAWS for friends and some of my contacts throught the airsoft manufacturers have stated that the XMPB4 has been discontinued through Mad Bull... Im only getting about 20yds with the S-Thunder grenades as the power source, yet we played 2 weeks ago with my LAW and I got a 175yd launch with the XMPB4 :)
Apr 9, 2011. 9:30 PMsearl2 says:
I used an ignition system of a BBQ sparker and static-guard. It seams to ga farther that the green gas and it dosent take time to warm up. Just out of curiosity, why did you use green gas?
Apr 5, 2011. 1:30 PMInverted_Spectrum says:
Cool! If only nerf wasn't so restrictive of power, then kids will be shooting each other with stuff like this (although injury can occur more, hmm...).
Mar 31, 2011. 7:25 PMThe3rdPunch says:
I'm confused does it shoot bbs or a NERF ball?
Jan 14, 2011. 5:15 PMPJPEEJ says:
is the grenade reusable? i don't wanna spend another $80 on only 1 grenade. And also, are there cheaper ones? I plan on making this instuctable. Its totally awesome :D
Apr 3, 2011. 5:38 PMThe3rdPunch says:
Hey could you use 40mm PVC or CPVC instead of an expensive airsoft gernade?
Jan 15, 2011. 7:30 AMPJPEEJ says:
sorry if im being annoying but how much would it cost in total and when u fire, does the grenade thing launch too?
Feb 20, 2011. 8:23 AMairsoftchase says:
ok so I want to make your launcher but i want to use the s- thunder multipurpose grenade ,but i want to be able to shoot bbs and nerf rockets..any suggestions on making the grenade able to be taken out during battle so i can reload
Feb 20, 2011. 7:37 AMairsoftchase says:
what is the greenish tape stuff?and where can i find it?
Feb 20, 2011. 7:35 AMairsoftchase says:
will the s-thunder fit as well as the mad bull in the coupler?
Jan 9, 2011. 7:52 AMpablotheillegaltaco says:
What is the locking mechanism for is it to hold the metal bar in place?
1-40 of 298next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
139
Author:MrTinkerer(ODST)
I like making stuff when I have the time. But It is soooo hard to find TIME...
