3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Airsoft M72 LAW rocket launcher
Step 10Trigger rod
Trigger rod
  • last photo ←
I used a a 1/8 thick by 3/4 inch wide aluminum bar. Iron or steel bar will work too. So will a round rod of some sort. Do what ever is best for you.
Picture #1: Measure from the center of the XM PB4 grenade valve (the silver circle) to the top of the control box. Transfer that measurement to one end of the trigger rod. Bend the trigger rod 90 degrees or more. shape and bend the tip so that sliding the trigger rod forward will depress the grenade valve.
Picture #2: Cut the long end of the trigger rod/bar to match the lenght of the control box. Depending on the material used for the trigger bar/rod find a away to secure it to the control box. I used a flat bar so I used "L" brackets to hold the bar captive.
Picture #3: Attach something (screw, rod, d-ring, etc) to the bar so that you can grasp it and push the bar forward which will depress the back of the XM PB4 40 mm grenade shell.
Make sure that when you Extend the launcher the something above (screw, rod, d-ring, etc) has clearance to slide backwards unhindered. When the launcher is collapsed, you want something to hinder the something above from moving forward as a "safety".
Picture #4: *Optional*
Install a spring to prevent the trigger from accidentally pressing the valve.
Pictures #5-10 are to help visualize the whole mechanism.
7 comments
Aug 31, 2010. 2:51 PMairsofter4 says:
how did you get the end of the bar shaped like that inorder to press the m203 grenade?
Feb 4, 2010. 8:45 PMscscdude12 says:
 hey if u wana sell one of those practice laws tell me and put it on ebay
Oct 1, 2009. 4:55 PMWarPigs DFW says:
hello in pick 5..... the aluminum bar did you cut it, or can you keep it one long bar? Almost done with the LAW. just need to know. Thanks Alex
Oct 1, 2009. 4:56 PMWarPigs DFW says:
If I do need to cut it....how long are the cuts...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
139
Author:MrTinkerer(ODST)
I like making stuff when I have the time. But It is soooo hard to find TIME...
