3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Airsoft RPG
Airsoft RPG
airsoft rpg great accessory and its cheap and easy if you choose to make one yours may come out different because i made mine like 3 different times due to leeks and other problems. i will make another on how to make a rocket for it.
- about 3ft of 1/2" pvc
- 2 1/2" T connector
- 1 or 2 1/2" end caps
- 1 1/2" ball valve
- 1 1/2" 45 degree angle connector
- 1 to 2 feet of 1 1/2" pvc
- 1 1 1/2" end cap
- rubber tire valve
- pvc cleaner and cement
- saw
- ask the person at the hardware store on how to get from 1/2" to 1 1/2"
Step 1
(Left to right) extra handle for running.............main handle..........trigger (camera made trigger on wrong side its a right handed rpg)........barrel.
Glue in this order or customize to fit you
26 comments
Sep 20, 2009. 6:34 PMstruckbyanarrow says:
rpg stands for ROCKET PROPELLED GRENADE, i dont seee any rockets or grenades...
Jan 13, 2012. 6:58 PMhalogirl says:
no it does not. RPG stands for "Ruchnoy Protivotankovy Granatomyot" meaning "hand-held anti-tank grenade launcher"
May 25, 2012. 9:46 PMmechaninja says:
OOOHHHHH!!! Need some aloe vera for that burn?!
May 5, 2010. 6:03 PMbrickman93 says:
i made one where you sleve a coke bottle over the barrel and fire it that wa.works pretty well
Apr 27, 2010. 1:14 PMsilver362 says:
i think it was only made to look like the rpg7
May 1, 2012. 6:05 PMalex2345 says:
take a bottle rocket and pour bbs over duct tape until its filled with them. then wrap around rocket, put in a piece of 1 1/2 or 2 in plastic/aluminium pipe, ligt the fuse, and watch the other team freak out. my favorite airsoft weapon.
Jul 4, 2010. 7:07 PMtoxicwolf says:
last i checked RPGs were ambidextrius (means you could use either hand)
Feb 5, 2010. 7:59 PMmad magoo says:
      I wouldn't reccomend using model rocket motors (and gunpowder) for an airsoft RPG.  That's pretty dangerous, and pretty hard to control.  Something soft and water-pressure-based would be much safer, in my opinion (I saw a great instructable for an airsoft grenade made out of surgical tubing on here.  Just add airsoft pellets to the water in the tubing).  The whole point of airsoft is that it's "military-simulation", NOT ACTUAL BOMBS.
Jun 27, 2010. 10:55 AMtoxicwolf says:
well if u use a model rocket motor to propell it is fine just so long as u do not shoot it directly at someone but rather near by them and do not use the rocket motor to spread the pellets but rather to propell a vessle that contains a small charge that releases the pellets from the vessle at least thats what ive done and so far no one has been hurt real bad the worst injury was when my cusin tried to catch the rocket it blew up in his hands and when th vessle exploded it burned his hands a bit oh and there not bombs there rockets a bomb is droped a rocket or missile is luanch from a position
Apr 28, 2010. 11:51 AMsilver362 says:
would it be possible to make this in the shape of a shotgun?
Jan 5, 2010. 5:47 AMpyrorower says:
I like ilplug's idea for the rpg, and with some modification to one of the rocket bodies that you normally buy the estes rocket motors for, you could make it more accurate and take advantage of the charge at the end of the motor that would normally blow off the nosecone to propel the BB's out of certian parts of the body. The only issue I could see here is that 1. since it's a model rocket motor you are using, it goes very fast and would hurt a great deal to get hit by it, and it would be timed to go off rather than impact triggered so if ti hits something it will keep going until the fuel runs out then detonate and by that time it could be far away from the target. I am going to see if I can modify a motor and rocket body to be impact detonated and maybe have just enough fuel to that it goes a decent distance at a safer speed. perhaps with just a brief period of thrust when initially launched rather than constant thrust throughout it's flight.
Jun 30, 2009. 10:01 AMilpug says:
i made a full ojn rocket launcher out of some 3 inch drainpipe, a screw, a tin can, and an estes rocket motor ignitor.. whole deal was like 20 bucks, the rockets are just rocket motors with a black powder extension stuck into a 20 oz. soda bottle half full of bbs... you can make time fuze attachements, and smoke grenades for it. the thing shoots about 1000 feet with size D motors, but i usually use smaller engines to avoid messing people up... the only tatical disadvantage is that its large, loud, and is rather innacurate, but it is great for blitzing bases, or taking out groups of people... the bbs shoot about 50 feet from the explosion, so this would kinda qualify as a "super weapon" any more Qs? message me if so
Apr 28, 2009. 4:09 PMgx27470 says:
u can put like 20 BBs in there and shot it will be just like a shotgun i tryed it and also plz make the instructable a little more descriptive and i know i sound like a teacher
Jun 17, 2009. 12:39 AMblugyblug says:
Nice, Love the copper bit, the little bent part makes it look pretty cool. Dont think it would shoot well though, its a ball valve...Could probably explain better though, a fully newb airsoft guy wouldnt really get it...
Apr 29, 2009. 11:03 AMfinfan7 says:
This is more of a rifle/shotgun than an RPG and you can buy those much better and easier than making this. You could use a larger barrel and make some airsoft grenades to fire out of it and call it a cannon. Or you could eliminate the air power system entirely, stick a bottle rocket and a tail into the airsoft grenades and a sparker from a grill into the back end and it really would be an airsoft rpg. Whatever you do make sure you get pictures during the process and if you can't do that get a copy of inkscape and draw up some diagrams.
Apr 28, 2009. 6:27 PMChefZombie says:
You should add how to build it instead of pictures.
Apr 26, 2009. 12:37 PMBiopyro says:
This instructable has such potential. 2*
Apr 26, 2009. 8:09 PMHolden_vy_s says:
I agree, there is no real Instructions other than look at this image then do it.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:Airsoft_Maniac_96
i know some german
