Airsoft Remote Detonation Mine/ Present Trap
Introduction: Airsoft Remote Detonation Mine/ Present Trap
An easy to build and cheap mine for airsoft that is quick to deploy with a wireless remote switch and can be filled with cheap BBs and a small bike pump. My first one has a trigger range of 50 yards or better and has an effective blast radius of about 15 feet. With the change of the barrel, you can fill it with confetti, place it inside a gift and have an exploding gift as well. I have some flower and BBs loaded in the first set of firing photos. The ones with the white barrel has flower only being shot out of a confetti barrel.
Step 1: Items Needed.
1) 5" section 1" sch40 pvc
2) 2" sec. 1" sch40 pvc
2) 90 degree 1" elbows slip to slip (s/s)
1) 1" coupler s/s
1) 1" thread adapter slip to thread female (s/tf)
1) 1" threaded male plug
1) 1" s to 1/2" tf reducer
1) 5 1/2" sec. 1/2" sch40 pvc
1) 1 1/2" sec. 1/2" sch40 pvc
1) 90 deg. 1/2" elbow s/s
1) 90 deg. 1/2" elbow s/tf
1) 1/2" end cap
3) ball point pens like the ones shown
1) 8 AA battery holder
1) shrader valve (I like the metal ones)
1) 1/2" 12volt solenoid valve (straight ports)
1) piezo buzzer rated around 12 volts
1) SPST rocker switch
1) 12volt single channel remote switch
1) 9volt battery plug
2) crimp on plugs
Some light gauge wire
Spray paint of your choice
8) AA batteries
Pvc cement and primer
Pvc cutters
9/16 wrench
Wire cutters/strippers
Wire end crimpers
Teflon tape
Electrical tape
Soldering iron and wire
Super glue
Drill bits
Tape measure
Heat gun
Silicone sealant
Razor blade
Step 2: Air Tank
Gather all of your 1" pvc parts. Prime and glue them together in the order shown in first photo (threaded plug, plug adapter, 5" pipe, 90, 2"pipe, 90, 2" pipe, coupler, reducer). Carful not to get glue on the threads.
Take the threaded plug and drill a hole to fit the shrader valve. Apply silicone sealant to the stem of the valve and insert it into the hole from the inside of the plug. If your valve has a nut, tighten.
Wrap Teflon tape around the threads of the plug and screw on the plug to the air tank. Paint and set aside.
Step 3: Barrel
Assemble the 1/2" pvc parts as shown in the first photo (90 s/tf, 1 1/2" pipe, 90 s/s, 5 1/2" pipe, end cap). You do not need to glue these parts together.
Heat the 5 1/2" pipe section and slightly bend the pipe.
On the outer curve of the pipe, mark a line down the center. Mark off 6 equal sections along the center line. The marks I made on the side of the pipe are reference lines to show what angle to drill each hole. The outer most holes get drilled at the most extreme angles. Notice the angle of the tubes in the last photo. These are the angles to drill the holes at. The angle lessens as you move inward. Drill the 6 holes in the pipe to fit the pen tubes.
Disassemble 3 pens and cut off the closed ends and cut the tubes in half. Take the writing end part and cut off the straight part, cut that into 4 short sections till you have 6 pieces. Put one short cut off into one end of each tube and super glue them in place.
Insert a tube, glued piece first, into each hole you drilled earlier.
Use super glue around the base of each tube to hold them in place.
The barrel is made this way to cover as much area as possible while still remaining compact.
Step 4: Electronics
Gather the wire, remote switch, battery pack, 9volt plug, SPST switch and piezo buzzer.
I have 2 types of remote switches shown. We will use the +, -, NO (normally open), and the COM (common). The first one is a two channel switch (I'm using that one for this instructable, not for any reason) so NO2 and COM2 will not be used. The second switch shown is s single channel switch. NC (normally closed) is not used. If you hook this up, when the mine is turned on, it will go off immediately and turn off when the remote button is pressed. You don't want that unless you want to blow yourself up!
To start, take the 9volt plug and solder the red wire to one post of the SPST switch and another red wire to the other post. On the end of the second red wire, splice in another short price of red to it for a jumper wire. The end with the splice goes into the + port, then the short jumper wire goes into the COM port.
Get the piezo buzzer and spice in a piece of wire (I'm using green wire) on the red wire of the buzzer or the positive side if there are no wires (if no wires, run a wire to it). Crimp a plug on the end of the green wire. At the splice of this, put in the NO port of the remote switch.
Take a piece of wire (I'm using black) and crimp on a plug to one end. Splice the other end with the black wire of the 9volt plug and the black wire from the buzzer. Insert the splice into the - port.
The wiring is done. Put the remote switch into it's enclosure and twist the wires together to keep things neat and clean as shown.
Step 5: Final Assembly
Get the 1/2" 12volt valve. On one end there may be a filter. If there is, remove it with some pliers. Wrap the threaded ends with some Teflon tape. Somewhere on the valve should be an arrow (<--). This shows the flow of the valve.
Screw on the air tank on the side the arrow points away from (<-- air tank). Now would be a good time to pressurize the tank and check for leaks in a bucket of water. If you have leaks at the pvc joints, try applying super glue to the joint, wrap some type of fabric thread around the joint and apply more super glue and let dry. If leaking happens at any screw joint, apply more Teflon tape or seal with some silicone sealant.
Take the 1/2" 90deg s/tf elbow and screw it to the other side of the valve (elbow <-- air tank). Assemble the rest of the barrel.
Hook up the crimp on plugs to the 1/2" valve (it does not matter which plug goes to which post, it just needs power to it)
Put batteries in the power pack and tape it on the mine in a tight space. Plug in the power with the 9volt plug.
Find a spot for the remote switch,master switch (SPST) and buzzer.
Adjust the barrel to an angle you think will shoot well.
Step 6: How to Use
Make sure unit is off before loading.
Load bbs into the tubes and tape over the ends the keep the bbs in place.
Pressurize the air tank (for bbs, I fill to 100psi. I use a shock pump for mountain bike shocks).
The unit is ready to be deployed.
Find a hidden spot that has a clear place to shoot into. Place the mine with the tubes pointing in the direction of the opponent. Remove the tape covering the tubes and turn on the unit. Cover with camouflage if desired.
Move to a position overlooking the trapped area but still in range of the remote (test range before using).
When an opponent is in the blast radius, press the button and the mine will be triggered, spraying bbs at them and buzzing.
Hit the button again to stop the buzzing and save battery life.
If you hid the mine so well that you can't find it, hit the button and follow the buzzing sound.
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    • Paper Contest 2018
      Paper Contest 2018
    Can you add some sort of snsor so when enemy comes close enough it will fire on its own (like a claymore)
    I'm thinking of making an airsoft grenade launcher and this looks like it has all the info I'll need. Awesome work!
    Can you post links to where we can buy the electronics? I cant find the remote for as cheap as you did.
    You have to find it on eBay, Amazon, ... I have 4-channel version for ca same price. There can be some bargains, You just need to be patient and go through some listings, then You will definitely find some. I wish You luck!
    I bet you could also wire a pressure plate to the circuit.
    Good job!
    Pretty sweet concept.
