Airsoft Tiger Stripe Camo
 by airsoft4ever
This will show you how to paint an airsoft gun tiger stripe camouflage, using only paint and masking tape. This is a way to spice up those solid black guns, or make a clear gun, look awesome.
Step 1: General info and supplies
Please know that you probably won't want to paint your $250 airsoft gun on your first try. If you mess up, it could look bad. So please try it on a lower quality gun first unless you are positive you can do a good job.
The supplies
- Two colors of paint. (Unless you want black stripes. Then you only need one color.)
- A roll of masking or painters tape.
- A gun to paint.
P.I. Kitty says: Apr 29, 2011. 6:40 AM
where did you get your m16
jabbathegut1 says: Nov 6, 2010. 1:10 PM
ive been looking through this , it looks pretty awesome but do you think it'l work for my gun?
ive never painted my guns ( properly ) so i have no idea how to :L
( picture and stuff )
cause of the orange detail im not sure if the paint will look tacky, should i clear coat it and use a primer?
if you could reply i would be very greatfull :D
airsoft4ever (author) in reply to jabbathegut1Nov 30, 2010. 8:43 PM
Sorry for the late reply! What I would do is paint the whole gun over with a flat black first and make sure it all looks the same and then go through the camo process.
jabbathegut1 in reply to airsoft4everDec 7, 2010. 1:03 PM
ahaa no worries regarding timing ,
thanks for the advice :)
cdousley says: Jul 13, 2010. 3:39 PM
do you ever use a clear coat?
airsoft4ever (author) in reply to cdousleyAug 16, 2010. 7:27 PM
I use clear coat when I hand paint guns for example, my M1 garand has clear coat. It really doesn't do a lot for spray paint though.
cdousley in reply to airsoft4everAug 17, 2010. 6:43 PM
i like it for some guns becuse it makes it really shiny
airsoft4ever (author) in reply to cdousleyAug 19, 2010. 2:53 PM
Yes it does have a good effect sometimes. I just prefer not to use it.
cdousley in reply to airsoft4everAug 20, 2010. 6:39 PM
yep i understand but i had some paint peeling today i guess it depends on the project
Musicman41 says: Jul 27, 2010. 11:53 AM
Do you ever have problems with jamming any of the moving parts with the paint? How would I avoid this?
airsoft4ever (author) in reply to Musicman41Aug 16, 2010. 7:25 PM
Well, I have never had any problems with this, but if you want to be extra careful, then cover up anything that you think might be damaged by the paint. As I said earlier, I have never had any problems.
thing 2 says: Sep 7, 2009. 6:50 PM
isn't that a colt m IV? My friend has one like that!
airsoft4ever (author) in reply to thing 2Jul 13, 2010. 3:15 PM
I don't remember what it is called, but I have a colt mk iv, and it is different. I got this gun at walmart.
joshfedo says: May 21, 2010. 4:29 PM
epic
airsoft4ever (author) in reply to joshfedoJul 13, 2010. 3:14 PM
Thanks. This one was a quicky, so I didn't expect much from it, but it turned out great!
sharlston says: Aug 29, 2009. 11:01 AM
om gonna do this with m p329 and my a1.a
airsoft4ever (author) in reply to sharlstonJul 13, 2010. 3:12 PM
How did it turn out?
Gage987 says: Dec 14, 2009. 3:54 PM
if you can put it back together i would suggest taking your gun apart and painting the casing and putting it back together when your done so you cant mess it up in any way
Colonel88 says: Nov 3, 2009. 6:02 PM
But if the paint gets in the cracks, such as the mag release button and you push it, then the paint will flake off or the button will jam.
Nice!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
