3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Airsoft field guide #001
This is a simple guide on how to build your own airsoft battlefield (Pay attention, this is a small arena setup, it houses up to 4 people a team, but i suggest no more than 3 per team)
I take no responsibility whatsoever about what use the following information is put to.
Step 1Building your walls
Building your walls
First insert four poles into the ground to build a support, then (Pay attention to picture #2) insert wooden planks or logs into the gap between your poles, to make a decent wall (Try to make the support posts about 7 ft. high and the planks should go up to about 4 1/2-5 ft.) The red represents where you should place these walls.
5 comments
Nov 9, 2009. 11:57 AMMRazor says:
This is perfect! My buddies and I was looking for ideas to build our own Airsoft field and just so happen to find this "how-to".
Quick question:
I play as a sniper on my Airsoft team, I was wondering how would YOU implement that aspect in to building a field for Airsoft snipers?
Either way, I'll post up pictures of the build on my blog (TopAirsoftSniperRifles.com) once we have it up an running!
Thanks again for this!
Nov 8, 2009. 2:02 PMlemonie says:
How did you mount 13 foot poles in cement (specifically)?
L
Nov 8, 2009. 11:35 PMlemonie says:
You set the steel box then added the wood, that makes sense. Can you get the use of someone's camera on this?
L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Joyayas
You have no reason to know this information. Or do you!?
