Airsoft/Slingshot Target & Ammo Collector
Published
Introduction: Airsoft/Slingshot Target & Ammo Collector
About: I'm an engineering student and I'm interested in stuff, naturally.
I wanted to build something I could use as a target for my airsoft gun and my slingshot.
The problem was that my garden was getting littered with plastic BBs from the airsoft gun and steel ball bearings from the slingshot.
The slingshot ammo is very difficult to find once it falls in the grass, but it's the first thing the lawnmower will go over!
So I needed a target that would collect the ammo as well.
This is very easy to make, the only materials I needed were knex and some rubbish from the recycle bin.
Step 1: Building the Frame
All I did here was to make a frame from knex to hold the target and stop it from falling over.
Be aware that if your slingshot is as powerful as mine it will easily destroy the pieces, so only use if you don't mind breaking a few pieces or you're confident of your accuracy!
Step 2: The Target and Collector
I used a cereal box for the outer bit, then newspaper to fill up the middle.
Make sure that the box you're using is weak enough to be penetrated by the airsoft gun/slingshot.
When filling up the middle make sure to use the weakest stuff at the front, if you pack something hard up against the box nothing will be able to penetrate.
Basically you want the BBs to penetrate the first few layers so they get stuck, but not to penetrate through the entire box.
Ideally, the top picture is what you want.
Step 3: Target
Put the box in the knex frame, build the frame so that if the box recoils forward or backward it won't fall over.
This is more important if you're using a slingshot, it doesn't really happen with an airsoft gun.
Draw circles on it so you can pretend it's a professional target!
Step 4: Shoot!
Be aware of whatever is behind your target, if you miss you might be hitting something that shouldn't be hit:
In my case, if I aimed too high I would probably smash my neighbour's window,
but as you can probably tell from the photo, that's a shamefully close distance to miss...
Step 5: Collect
Some of the BBs will fall to the bottom of the box when you pull out the newspaper, but most of it will be stuck somewhere between the layers of newspaper.
Step 6: Recycle
the best part is that when you're done you can just throw it all into the recycle bin and save the knex frame for the next time you want to shoot.
    • Spotless Contest
      Spotless Contest
    • Woodworking Contest
      Woodworking Contest
    • Microcontroller Contest
    I am getting the barnet cobra, and cool instructable
