Airtight Self-Sealing Inflatable
1,255
22
Published
Introduction: Airtight Self-Sealing Inflatable
About: The HSCM Team is a small group of inflatables enthusiasts researching and exploring inflatables. We are: Che-Wei Wang (Pratt Undergraduate School of Architecture Adjunct Assistant Professor) Andreas Tellm...
Hello! We are the CNC HSCM (Heat Sealing and Cutting Machine) Team from Pratt Institute in Brooklyn, NY. We have created a large scale CNC machine for creating experimental inflatable structures. We developed a method for sealing our inflatables that we would like to share. Please check out our Patreon page to check out some of the awesome things we do: https://www.patreon.com/hscm
This is a method of sealing inflatables demonstrated on a simple bag. This closing system can be applied to a large variety of inflatables. The design is based on the patent for self sealing Mylar foil balloons. "Self-sealing valve, a self-sealing, non-latex balloon and a method for producing such a balloon EP 0356013 A2"
Materials to make the self sealing inflatable you will need:
Plastic sheeting (PET is used in this example)
Plastic tubing (of the same type of plastic as the sheeting)
Trace Paper or Wax Paper (any paper will work, but these are recommended)
Tools
Exacto (preferred cutting utensil)
Impulse sealer
Step 1: Cutting Out the Shape
The inflatable can come in any shape, but for this demonstration, a simple bag shape is used.
The most important aspect of this is to have the nozzle cut out of the shape which will seal the tube.
Step 2: Sealing
For this step, seal all edges except the valve end where the tube will be placed in.
Step 3: Preparing the Tube
Before sealing the tube, take your paper and cut it to the width of the tube so it can slide in with ease, but fill all of the tube. If it is too tight it will be difficult to remove later.
Once the paper is cut, place it into the tube.
Step 4: Final Seal
Take the tube with paper inside and place it inside the inflatable through the open valve.
The sealer will have to be at a higher setting to accommodate the extra material.
Seal across the inflatable valve with the tube sandwiched in the middle.
Once it is sealed, remove the paper.
Step 5: Inflate!
Inflate!
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    • Creative Misuse Contest
    3 Discussions
    I've been thinking about inflatables for a bit, but I see you are well ahead of the game.
    How hard would it be to transfer standard stuffed animal sewing patterns into inflatables? Do they translate 1-1, or would modifications need to be made? For instance, teddy bear patterns.
    The real question is if you can make farting noises with it... ;)
    That's pretty neat :)
