Introduction: Ak-47 Paper Prop
this is my first indestructible so it might not be the best but will the best I can do. so I am planing to make a easy but realistic as possible AK-47 prop for Halloween with simple paper mache
my camera does the prop no justice at all it looks much better in person you should bother looking at the images to help you make the prop
Step 1: Insperation
materials needed:
paper
card/ cereal box
cello tape
scissors
long tube 1 MM diameter or close or wooden spoon
paints
paint brushes
news paper for paper machea
P.V.A Polyvinyl Acetate
Step 2: Skelton of the Gun
firstly make 5 paper tubes
i found if you fold the side of the paper its easer to roll and have your tape at hand
this will be for the middle of the gun
now tape two tubes together do it 2 times and tape your last tube then tape all together
next make one more tube lengthways and 1 widthways
with the shorter tube cut a bit off this will be for the sight
fold some card i half draw sight the same thickness as you bit you cut and then cut 2cm off it like picture
now put the cut tube inside it and secure it with tape but don't tape it all the way to the bottom leave some so you can tape it to the tube
now screw up the end of the tupe and tape like the pic then insert it to 2nd last hole
now put a smaller tube at the end of the small tube to separate the two pieces
then cut two triangles tow put on the bit you've just done and cello tape them
for the stock
make 3 tubes length ways
put one tube in the bottom hole and another one to the second to bottom and cut the 3rd tube to desired size to get your perfert stock stize
Step 3: The Handle and Mag
making
for the the handle you need to role two tubes length ways and cut in half
you'll have one spare one so keep it spare but tape the rest together and cut down 2.5 cm down the middle
now tape handle at desired angle cut a bit of the spare tube at same width of the front tube on handle
the MAG
you what to grab one piece of card and draw you magazine about 6 cm wide and fold card in half and cut out identical pieces, cello tape it up like the picture make sure to leave tabs about 1.5 cm in size so you can glue it like the pictures.
then cello tap it the mag to the gun about 7 cm from handle
the trigger
firstly you get some paper cut a strip about 15 cm long 7 cm wide and position on the gun
to make a trigger guard and cut to size cell tape to gun
Step 4: Covering
this step you problably don't need any instructions because it is very easy
the stock
first get 2 sheets of paper and draw around the stock leaving enough space to cello tape the paper cut out and do this to both sides
the handle
now cut thin strips off paper and cover the handle so later you can paper mache
the body
now for the body cut the paper to size and around the mag and trigger and fold it over like the picture
Step 5: Paper Mache
paper mache
firstly you need to get half cup of glue and half a cup of water and mix this will be for the paste
dip or paint the paste on the news paper strips and lay on the gun nicely and neat, do a minimum of 3 layers of paper and let it dry
the best way to get news paper squares is to just cut the whole news paper with strong scissors and let it dry before painting
Step 6: Painting
painting
the camera does not do the prop any justice the wood affect looks much better in person
firstly you might want to draw which bits you want to be wood or metal like the picture
for the the bits you'll paint black i recommend adding a tiny bit of silver to make it slightly lighter so you can add detail with the darker paint later on
now we have done the black bits at this stage of painting lets focus on the wood get a thicker brush and paint the same same direction to get a grain affect use light brown and then dry brush with darker colour to get a wood affect
for the wood it needs to be a thick brush with hard bristles. you get some paint on a paint brush a wipe the paint off on some paper so there's little paint on the brush and paint the gun this is called dry brushing
now put non diluted P.V.A on the wood not metal to make the wood shine like real wood also to give it depth
now the wood is done
adding detail
for the front wood bit you want to paint two white lines like the picture
now you want to dry brush the black part with silver paint you what to use a fine flat brush for this step just to highlight the edges
and put more paint on parts which get more ware
now get a black pen and draw detail
6 Comments
Cool.do a M4.
OK i will i really like your captain America shield and i migt make some pistals with moveable pull thing on top off the gun and nija wepons
Thanks.looking forward to instructable:)
This is a great way to make custom props of any kind. Thanks for sharing.
thank you is there any tips you can give me for further instuctibles
Here is a collection of some really good guides that give advice on how to make great instructables:
https://www.instructables.com/id/how-to-write-a-great-instructable/
