3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Alcohol-Fueled Blowtorch
An alcohol-fueled blowtorch that is very simple to make and burns very hot. please note that this is a prototype and just to prove the concept. And yes mark 2 is on the way.
Step 1Safety Note
This instructable includes fire. I think (and hope) that everyone knows that when dealing with fire, be careful and have some water, an extinguisher, wool blanket, or all of those handy in case you spill flaming alcohol on yourself. Also remember that this is a prototype and flashbacks may happen so be careful if you do make it. with that put aside, lets make a blowtorch.
10 comments
Jan 11, 2011. 11:47 AMHmff says:
I love it!!
so much in fact that im reenginering the consept to make my own inproved one.
Oct 1, 2009. 12:59 PMKiteman says:
You're blowing compressed air through the alcohol, and lighting the spray / vapour? It would probably be safer, and more controllable, to direct a spray of alcohol into a stream of air, then light the result.
Oct 1, 2009. 1:23 PMKiteman says:
Using separate supplies of fuel and air, you can "tune" your flame from a low-temperature yellow flicker to an intense blue cutting flame. It's like a Bunsen burner - a stream of air is added to a stream of fuel in just the right ratio to get the hottest flame.
Oct 1, 2009. 1:05 PMlemonie says:
Blow lamps used to run on paraffin, you pumped up the can and is sprayed mist which burned. These days they're ornaments like copper-kettles. I'd suggest version 2.0 goes for an aerosol design?
This is surprisingly effective though, definitely does the job, but I'd imagine your soldered joints melting with prolonged use.
L
(Barley is a cereal crop, you want "barely")
Oct 1, 2009. 5:27 AMPKM says:
Wow, that's... the least safe thing I've ever seen, and that inlcudes the accidental jet engine/flamethrower we made out of a fire extinguisher.
You could probably make a lot of improvements to the design but this looks like a sound proof of concept, low pressure compressed air + alcohol = vapour you can use for a blowtorch flame.
I would like to second the concerns about the lack of flashback protection, I've seen what happens with confined gas explosions both through my chemistry education and my playing.
Any plans for a Mark 2?
Sep 30, 2009. 10:35 PMironsmiter says:
There's a whole lot of the construction that isn't at all clear, as it stands. Where's the fuel go? where's the compressed air introduced? Best as I can guess, it's a U shaped piece of piece (straight plus 2 elbows), with the fule in the straight, and air introduced into the non-flame end. Seems VERY risky as there's no flash suppression whatsoever. One picture of the ENTIRE finished product may answer all these issues(other than the flashback problem. placing a sink aerator screen into the coper elbow should handle that fairly well. Doesn't take much. Also, please, oh please, don't use electrical tape to "seal" the tubes. If you're only looking for a 30 second usage, it'll work, but you really should solder those joints. I'd even say go with a silver solder, as it may get warm enough to melt lead solder, if the flame stays down in the elbow, like in your video. .
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Ben.land101
