Step 11Attaching the Harness, Beacon
The amber beacon light was also mounted on top. The light originally used a high-intensity halogen 12V bulb, but wanting to use a small, light battery, I replaced the bulb with two yellow LEDs and ran those and the motor off a 9 volt battery.
I shortened the "beaver tail" feature in the back where all the hoses are supposed to attach. This made it easier to set down and easier to navigated a crowded party. From the back angle you can see how the head section mounts to the main body. There is a piece of threaded rod running across with an aluminum tube covering it.
With the harness attached, it was finally time for "Ripley" to take an early test drive!
Add Comment
