3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Aliens Powerloader Halloween Costume
Step 9The Body
The Body
For the front of the body, lauan sheet was used for rigidity with 1/2" foam shaped to simulate padding. Two PVC adapters are attached to the sheet where the lower cage will connect. The face of the head section (on the right) is separate since it will pivot away from the body as the cage opens.
Lauan was added for the sides of the main body, but only a sheet of foam in the back. This means I wouldn't be attaching the very large arm cylinders in the back as a weight savings measure.
Some 1x3 lumber goes around the top of the body to add the support needed for the arms. Small blocks are also used to support the mounts were the head section will pivot.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
53
Author:flaming_pele!
Web developer by day. Gamer by night. DIYer, all the time! My projects tend to combine technology and craftsmanship to produce something that's fun to use and cool to look at.
