The scooter is geared for a top speed of about 25 mph, has around 3 horsepower, and can go 8-12 miles per charge.
Remove these ads by
Signing UpStep 1: Parts and Tools
- Donor kick scooter frame - mine was a Royce Union Transit
- Wheels - I used 12.5" low-speed pneumatic wheels from Northern Tool
- Motor(s) - 3x CIM motors, which are generally used in FIRST robots
- Gearbox - CIM motors are fairly high speed/low torque motors, so a gearbox was required in addition to the reduction from the chain drive. My franken-gearbox is a mashup of two Andy Mark Toughboxes from 2005.
- Motor Controller + throttle- I went a bit overkill, and chose a Kelly KDS72200E, 72V, 120 A continuous, 200A peak controller.
- Batteries - 8 x Turnigy 5000 mAh 4s LiPo packs
- Aluminum - angle channel and flat bar in a variety of sizesd
- Shock absorbers - 2x mountain bike rear shocks, 2x mountain bike fork shocks
- Nuts and bolts - too many and of too many different varieties to list here
- 1/2" threaded rod with matching nuts
- 1/2" and 8mm stainless steel rods + shaft collars- for the pivot points in the suspension
- Large power switch
- Fuse/Fuse holder
- High current terminal connectors
- Drill - with lots of large bits, up to at least 1/2"
- Hack Saw - if you have a bandsaw with metal cutting blades, please save yourself and use that
- Drill Press - Not strictly necessary, but it makes drilling precisely aligned holes much easier than with a hand drill
- File - for smoothing sharp corners and enlarging holes
- Propane torch and aluminum-zinc brazing rods
- An assortment of clamps
- Bench vice - mine was literally a workbench that was a vice, but the kind that bolts onto a bench would be even better
- Soldering iron + solder - one with a very heavy tip for soldering large power connectors and battery leads
- Lithium Polymer battery charger with power supply
- At least two adjustable wrenches
Visit Our Store »
Go Pro Today »
I want to build ev scooter myself and i'm wondering how much powerful motor i have to use. Can You tell me how powerful are this CMI motors ?
That would make a good instructable.
Great scooter nice job.
Where are you gong to school now?
thanks
Ralph
It's nowhere near as strong as welding, but all it takes is a propane torch and a stainless steel wire brush.
Thanks!
I am now a freshman at MIT
(Ironic sidelight - the HobbyKing web site says these batteries are available for shipping to the U.S. only. The irony is that Hobby King's warehouse is close to where I work - in Canada, and shipments to U.S. customers go out from there. How do I know that.? Their parcel pickup is the same truck as ours. Go figure).
You could get the batteries from HobbyKing's international warehouse, although shipping will take longer and be more expensive.
Years ago, I worked in an engineering research lab. It was amazing what we used to get for the price of disassembling it.
Thanks for your interesting article. Cheers.
You could seriously make and sell these. Don't pass up an opportunity to make money foo.
Have you noticed anything getting hot?
Connectors ect from the current.
How did you determine the springs to use. Maybe you used my high tech method of best guess.
W
I arbitrarily decided that I wanted the suspension to compress about 1/2" with just my weight on it, so I did some rough calculations based on the length of the lever ams involved in the suspension mechanism to get around 3000 in/lb for the total spring constant of the parallel springs.
Gone to my Portuguese Gizmo Blog post,
http://faz-voce-mesmo.blogspot.pt/2012/09/3d-em-faianca-metal-fluido-rostok-mais.html
and since China treatens to make a new Gold-based Currency, I've gone and downloaded the Pdf...
Might come handy!
Why not wire both the batteries and the motors in parallel to keep the motors at 14.8V, where they're unlikely to burn out?
I could get the same effect if I just removed one of the four modules from the battery pack, making a 44.4V pack split across 3 motors in series, for 14.8V per motor. But, assuming the motors have similar efficiency at 14.8 and 20 volts, the motors should put out about twice as much mechanical power when running at 20V vs 14.8V, and I'd rather just avoid long hills than sacrifice top speed and acceleration.
