I ride my bike all year round, and since I live in Canada that means I have to bundle up quite a bit in the winter! When temperatures dip below 5 Celsius or so, I put my "summer" helmet back on the shelf and reach for my custom modified all-weather helmet. It's so effective that despite my mostly bald head I don't need to wear a hat underneath, even at temperatures down to -20C at speeds in excess of 40 km/h (tested and confirmed!)
The All-Weather Helmet is also completely waterproof, so it's great to have when it's raining, sleeting, or snowing.
Virtually any helmet can be modified into an all-weather helmet, the only requirement is that the plastic decorative shell can be removed.
PARTS:
One bike helmet in your size. Make sure the plastic part comes off.
About one square yard (or one square meter) of nylon fabric
Contact cement or some other glue with a long open time, that won't melt foam
Electrician's tape
A plastic face shield (optional)
TOOLS:
A sharp knife
Scissors
Step 1: Remove the Plastic Shell
The first step is to remove the plastic decorative shell that is stuck to the foam of the helmet. Chances are it will be taped around the edges, and maybe glued in a few spots here and there underneath. If your helmet is more securely attached (like my Giro "summer" helmet) then this may not work so well.
If your helmet has a visor, pop it off and set it aside.
Start by cutting the tape around the perimeter, or just peeling it off. Lift the plastic cover at one end, and feel for the first spots of glue. Gently break the glue connection, being careful not to dent the plastic or pull pieces of foam off the actual helmet. Use a metal shim, such as a ruler, to make this easier. Do this for all the glue spots, until the plastic cover comes loose.
1-40 of 74Next »
mythbuster1633 says: Apr 3, 2013. 5:23 PM
Where would you buy the face shield?
ilpug says: Feb 22, 2012. 3:33 PM
You can use the side of a large soda bottle for the face shield.
jeff-o (author) in reply to ilpugFeb 22, 2012. 5:56 PM
Great idea! It would be a but thinner than a store bought shield, but it would probably work just fine.
ilpug in reply to jeff-oFeb 22, 2012. 6:08 PM
Yeah, I bet it would. HDPE soda bottles are surprisingly tough, and with the bonus that if you scratch it, you can replace the whole shield for about 2$.
al_packer says: Jul 21, 2011. 10:08 PM
Now-- we need to have someone design a bike helmet that gives good cooling AND protects the head, ears, neck, etc. from the sun for folks who are susceptible to melanoma
jeff-o (author) in reply to al_packerJul 24, 2011. 8:44 PM
Hmmm, perhaps you could cut the brim off a Tilley hat and glue it on! LOL.
Best to stick with sunscreen, I think.
Wasagi says: Apr 20, 2011. 7:23 PM
I have that bike helmet! I will need to try this, although it doesn't get too chilly here in DC, and if it does, there's snow.
Although, Surly Solved that problem. So did FiendofHumanity...
Underwater Chef says: Mar 1, 2011. 4:43 AM
That would be very useful!
jeff-o (author) in reply to Underwater ChefMar 2, 2011. 4:32 AM
Thanks! And also, it really is!
bendog38 says: Feb 14, 2011. 2:17 PM
did u search "windscreen"?
Darth Sensate says: Nov 19, 2010. 8:23 AM
What do you use to wipe your lens while you are out riding? That much rain and crud on the lens would be pretty annoying after more than a few minutes. Same problem with glasses in a summer downpour.
jeff-o (author) in reply to Darth SensateNov 19, 2010. 9:14 AM
My finger. If it's cold out, a gloved finger. That sometimes leads to blur-o-vision, but I can still see well enough to stay out of trouble.
[insert username here] says: Jul 10, 2010. 7:02 PM
i think you mean tuque (not toque). as it would be hard to ride a bike with a chef's hat.
jeff-o (author) in reply to [insert username here]Jul 11, 2010. 12:08 PM
Ha, you are correct! I shall correct it.
finnrambo says: May 19, 2010. 1:26 PM
YAY! bike wear that self-concious people can use, well done man!
jeff-o (author) in reply to finnramboMay 20, 2010. 6:44 AM
Thanks.  :)
keithgarvin says: Dec 26, 2009. 12:31 PM
I have to weigh in on this instructable because taking off the plastic shell and putting nylon in between compromises the integrity of the helmet.  I've been in a number of accidents where my helmet was destroyed and I can tell you that helmets are only good for one use and should never be compromised.  when I ride in the winter, I use the louis garneau time trial helmet, its the one that the visor you use is designed for, it has less air holes than a standard helmet and covers the ears, I also wear a thin thermal hoodie underneath the helmet.
jeff-o (author) in reply to keithgarvinApr 27, 2010. 9:10 AM
The key here is that the outer shell on this particular helmet is really on there for looks.  It's held on with tape and a few dabs of glue here and there.  On other helmets, like those made by Giro, the plastic shell is indeed part of the structure, and should not be removed in this way.
vanmankline in reply to keithgarvinApr 27, 2010. 8:27 AM
+1
michaeldavid says: Apr 10, 2009. 9:40 PM
Wonder if you can get the face shield tinted?
undegreenable in reply to michaeldavidMar 1, 2010. 12:06 AM
get your hands on some window tint for car glass. i believe walmart has some in automotive
jeff-o (author) in reply to michaeldavidApr 10, 2009. 10:35 PM
Dunno. If you make your own face shield, you could use plastic that's already tinted.
dollardude says: Jun 28, 2009. 4:47 PM
Great but i live in AUSTRALIA not some cold place like that
jeff-o (author) in reply to dollardudeJun 28, 2009. 8:45 PM
It still rains in Australia, doesn't it? ;) It'll keep your head dry too.
dollardude in reply to jeff-oJun 28, 2009. 11:37 PM
I... Guess... still, the only rain in AUS a lightning storm (i dont ride then(metal bike))
dollardude in reply to dollardudeJun 28, 2009. 11:39 PM
L.O.O.K...
cowscankill in reply to dollardudeOct 9, 2009. 1:11 PM
LOL! Metal bike... Haha make a bamboo bike, like in that recent Instructable :D
All Day says: Aug 15, 2009. 12:35 PM
I Love the idea. great to keep mosquitoes out of your eyes as well
jstringer94 says: Jun 19, 2009. 1:33 PM
yeah just showing ya
Zaphod Beeblebrox says: Jun 14, 2009. 5:32 AM
AAAAAAAAAAHHHHHHHHHHHHH............................ but does it have windshield wipers?
jeff-o (author) in reply to Zaphod BeeblebroxJun 14, 2009. 10:49 AM
Yes - your fingers. ;)
MarkCamano says: Apr 3, 2009. 4:49 PM
thats a great idea. and that clear viser will keep the wind out of your eyes. the wind makes my eyes water.
kergareth says: Mar 8, 2009. 4:32 PM
For the visor on the Garneau site, click here Alternatively, go to the site
Catalog Section> Fall Cycling 08-09 > Helmets > Acessories > Windscreen
coolsciencetech says: Mar 1, 2009. 11:58 AM
how do you keep your bike from rusting????
jeff-o (author) in reply to coolsciencetechMar 1, 2009. 2:03 PM
For the most part, a generous application of bike lube, WD-40, or marine-grade grease. It also helps that many of the components (including the frame) and fasteners are made of aluminum and stainless steel.
noelle_tan says: Feb 7, 2009. 6:54 PM
have you tried using dish soap on the shield, and then buffing it? I've heard that that was reliable to keep water off.
jeff-o (author) in reply to noelle_tanFeb 7, 2009. 7:34 PM
Nope, I haven't tried dish soap. I have heard that it works, though...
coolsciencetech says: Jan 18, 2009. 6:29 PM
FINALLY! someone who rides their bike in winter too. what do you do if there is a snow storm?
catman529 in reply to coolsciencetechFeb 5, 2009. 7:47 AM
I live in Tennessee where it doesn't snow much, but right now it is under 20 degrees Fahrenheit. I ride my bike year-round and this helmet seems like a good idea for the winter time. But now I am anticipating spring so I might consider something like this for next winter...
jeff-o (author) in reply to catman529Feb 5, 2009. 8:19 AM
Well, it's great for spring rain, too... ;)
1-40 of 74Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
