Introduction: How to Make an All-direction Vehicle With Mecanum Wheels
Picture of How to Make an All-direction Vehicle With Mecanum Wheels
The all-direction vehicle is equipped with four Mecanum wheels. The cool part of this vehicle is the flexibility of moving in any direction while keeping itself in a constant direction. It is achieved with the special structure of Mecanum wheel and their proper configuration on the vehicle. You can visit the website and download the omndirectional.pdf file to get to know how it works. In general, the speeds of Mecanum wheel are governed by the equations in the above picture.
So, let’s build a real one from assembling its framework.
Step 1: Assemble Rectangle Framework
Picture of Assemble Rectangle Framework
Assemble rectangle framework with beams and screws from Makeblock.
Step 2: Assemble Encoder Motors
Picture of Assemble Encoder Motors
The speed of four Mecanum wheel is dependent on the speed of vehicle, therefore, it should be precisely controlled to avoid wheel sliding. Encoder motors are used to achieve this goal.
Step 3: Install Motors on the Framework
Picture of Install Motors on the Framework
Step 4: Install Mecanum Wheels
Picture of  Install Mecanum Wheels
Step 5: Wiring
Picture of Wiring
An encoder motor driver from Makeblock is able to drive two encoder motors. Two encoder motor drivers are enough for this vehicle. They are connected to port 1 and port 2 on the Orion board respectively. Please keep consistent between wiring and defining ports in your codes.
Step 6: Install a Battery
Picture of Install a Battery
The framework of all-direction vehicle with Mecanum wheels is shown in the figure above.
Step 7: Programming
Picture of Programming
The speed of four Mecanum wheels are determined by the angular velocity
and speeds in x-axis and y-axis of the vehicle. A Joystick is used to control the speed of the platform with left stick for translatory velocity, and right stick for angular velocity. Plug a Me USB Host module into port 3 of Orion board and then plug a wireless module into Me USB Host module.
Download Makeblock library and put it under Arduino library. The Arduino codes are as follows:
#include "Wire.h"
#include "SoftwareSerial.h"
#include "MeOrion.h"
MeUSBHost joypad(PORT_3);
MeEncoderMotor motor1(0x02, SLOT2);
MeEncoderMotor motor2(0x02, SLOT1);
MeEncoderMotor motor3(0x0A, SLOT2);
MeEncoderMotor motor4(0x0A, SLOT1);
float linearSpeed = 100;
float angularSpeed = 100;
float maxLinearSpeed = 200;
float maxAngularSpeed = 200;
float minLinearSpeed = 30;
float minAngularSpeed = 30;
void setup()
    motor1.begin();
    motor2.begin();
    motor3.begin();
    motor4.begin();
    Serial.begin(57600);
    joypad.init(USB1_0);
void loop()
    Serial.println("loop:");
    //setEachMotorSpeed(100, 50, 50, 100);
    if(!joypad.device_online)
        Serial.println("Device offline.");
        joypad.probeDevice();
        delay(1000);
    else
        int len = joypad.host_recv();
        parseJoystick(joypad.RECV_BUFFER);
        delay(5);
    //delay(500);
void setEachMotorSpeed(float speed1, float speed2, float speed3, float speed4)
    motor1.runSpeed(speed1);
    motor2.runSpeed(-speed2);
    motor3.runSpeed(-speed3);
    motor4.runSpeed(-speed4);
void parseJoystick(unsigned char *buf)   //Analytic function, print 8 bytes from USB Host
    //  debug joystick
    // int i = 0;
    // for(i = 0; i < 7; i++)
    //     Serial.print(buf[i]);
    //     Serial.print('-');
    // Serial.println(buf[7]);
    // delay(10);
    //  increase and decrease speed
    switch (buf[5])
    case 1:
        linearSpeed += 5;
        if (linearSpeed > maxLinearSpeed)
            linearSpeed = maxLinearSpeed;
        break;
    case 2:
        angularSpeed += 5;
        if (angularSpeed > maxAngularSpeed)
            angularSpeed = maxAngularSpeed;
        break;
    case 4:
        linearSpeed -= 5;
        if (linearSpeed < minLinearSpeed)
            linearSpeed = minLinearSpeed;
        break;
    case 8:
        angularSpeed -= 5;
        if (angularSpeed < minAngularSpeed)
            angularSpeed = minAngularSpeed;
        break;
    default:
        break;
    if ((128 != buf[0]) || (127 != buf[1]) || (128 != buf[2]) || (127 != buf[3]))
        float x = ((float)(buf[2]) - 127) / 128;
        float y = (127 - (float)(buf[3])) / 128;
        float a = (127 - (float)(buf[0])) / 128;
        mecanumRun(x * linearSpeed, y * linearSpeed, a * angularSpeed);
    else
        switch (buf[4])
        case 0:
            mecanumRun(0, linearSpeed, 0);
            break;
        case 4:
            mecanumRun(0, -linearSpeed, 0);
            break;
        case 6:
            mecanumRun(-linearSpeed, 0, 0);
            break;
        case 2:
            mecanumRun(linearSpeed, 0, 0);
            break;
        case 7:
            mecanumRun(-linearSpeed / 2, linearSpeed / 2, 0);
            break;
        case 5:
            mecanumRun(-linearSpeed / 2, -linearSpeed / 2, 0);
            break;
        case 1:
            mecanumRun(linearSpeed / 2, linearSpeed / 2, 0);
            break;
        case 3:
            mecanumRun(linearSpeed / 2,  -linearSpeed / 2, 0);
            break;
        default:
            mecanumRun(0, 0, 0);
            break;
void mecanumRun(float xSpeed, float ySpeed, float aSpeed)
    float speed1 = ySpeed - xSpeed + aSpeed;
    float speed2 = ySpeed + xSpeed - aSpeed;
    float speed3 = ySpeed - xSpeed - aSpeed;
    float speed4 = ySpeed + xSpeed + aSpeed;
    float max = speed1;
    if (max < speed2)   max = speed2;
    if (max < speed3)   max = speed3;
    if (max < speed4)   max = speed4;
    if (max > maxLinearSpeed)
        speed1 = speed1 / max * maxLinearSpeed;
        speed2 = speed2 / max * maxLinearSpeed;
        speed3 = speed3 / max * maxLinearSpeed;
        speed4 = speed4 / max * maxLinearSpeed;
    setEachMotorSpeed(speed1, speed2, speed3, speed4);
Step 8: Upload Codes to Orion Board and Have Fun
Upload codes with Arduino IDE, you are ready to play with this cool vehicle.
성혁문 (author)2016-11-07
Can I ask which motor you used for this device?
surendra2369 (author)2015-11-13
do mecanum wheels work on slopes like 60 and 90 degrees..???
like on stairs.
if so do you tried it..???
please suggest me.
i'm waiting for your reply.
daniel.setolike (author)2015-11-11
Thanks bro i need this
Jack Ruben (author)2015-11-03
Where can i bay the Joystick to move the robot?
Jack
From Amazon~ : )
boffincentral (author)2015-11-04
Just thought I would mention that if you have a 3D printer, there are models for Mecanum wheels on Thingiverse. I've not tried them so I can't comment on how well they work. I was prompted to look because of the sticker price of each wheel. I'm sure they're worth it but if you are just interested in fooling around with them the price of these parts might deter you.
Chakazuluu (author)2015-11-03
I don't understand how these wheels can move a device in all directions- are the individual components in the wheel powered - how does it work...
Chakazuluu (author)Chakazuluu2015-11-03
Never mind Wikipedia is my friend...
Dave-Smart (author)2015-11-03
Nice project! It would be awesome to strap an Android Phone to it and give it GPS, Vision, Voice, Video streaming etc. You can use DroidScript to do that. Check this project out:- https://www.instructables.com/id/Smart-Robot-with-V...
Raphango (author)2015-11-03
whoa! Great!
cybercapri (author)2015-11-03
Wow, what a great concept vehicle, I hope this goes mainstream.... Very well done...
sstraub15 (author)2015-11-02
Is it possible to add links to the exact parts that are required? The mecanum wheels appear to come with motors -- are these the same as required by this project? Thanks for the cool project idea.
You can search all the parts here: http://www.makeblock.cc/
Glad you like our project. : )
arhrevun (author)2015-11-01
this is my final project... haha
very like this because use inverse kinematic
fzumrk (author)2015-10-30
Neat wheels. I've seen fork trucks that use these, but I did not know there were miniature versions available.
About This Instructable
38,353views
448favorites
Bio: Makeblock was founded in 2012 as the world's first open-source robot and programing platform. With more than 400 mechanical components, electronic modules, and software ... More »
More by Makeblock Robotics:How to Use Scratch or Arduino to Program a MBot 3D Capture B by Makeblock How to do a cartoon project with Airblock and paper cups
Add instructable to:
