3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
(Almost) Instant Hard Case for iPod Nano (from the Apple box!)
Step 3How to get the Nano in and out of the case
You are all done making your Nano case!
To get the Nano in and out of the case, you flex the mounting plate back with your fingers, and snap the Nano in.  Removing it is the same -- flex and pull the Nano out of the mounting ears.  Note that it will be stiffer than it was when you first removed the Nano after buying it, because the bamboo guides are reinforcing the bottom plate.
This is all to the good, as it increases the security when the case gets knocked about -- your iPod will stay securely mounted!
Take a good look at the pictures in this step, and everything should come together.
If you want to be able to listen to music with the Nano in this case, modify the end where the earphone jack lives by marking and step-drilling a hole sufficient to pass the headphone plug.  Go slowly and use water as a lubricant to avoid cracking the plastic.
Happy traveling with your new iPod Nano case.
3 comments
Feb 2, 2010. 5:27 PMmrtape01 says:
 how do make the hole for the touch weel?
Aug 1, 2010. 5:49 PMmrtape01 says:
thanks
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:chromisdesigns(GemsForJewelers)
I retired a few years ago after 30+ years in the computer industry, now live in San Francisco in an 1890's Victorian house, work part-time as a goldsmith and gem trader, and travel.
