3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Almost jigless bicycle frame building
Step 3The Dummy Axle
The Dummy Axle
The dummy axle is just a piece of the steel bar with a hole drilled in it to accept and axle. The axle is held in place by nuts on each side (not shown). You can use axles, cones, and locknuts (both quick-release and solid) scavenged from old hubs, or use threaded rod and nuts.
Since the inside of the bar is on the same vertical plane as where the right end of the bottom bracket contacts the upright reference piece, you can use it as the reference for you axle locknut locations.
Looking at the dummy axle from the rear, your left locknut will be 34mm plus half of your hub width. The right side will be half of you hub width minus 34mm. This all assumes you are using a 68mm shell.
In use, the piece is just clamped to the angle iron with a C-clamp.
Since this is so simple, you might as well make a new one for each axle size.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
41
Author:drwelby
I grew up on Legos and the Whole Earth Catalog. These days: bike builder, map maker, trail sleuth.
