Alphabet Blocks Play Table
Published
Introduction: Alphabet Blocks Play Table
About: Empowering women (and their husbands and boyfriends) one DIY project at a time -- We teach basic home maintenance and home improvement skills.
Have you ever found yourself in a meeting or on an extremely long conference call that seemed as if it would last for days? It’s so dry and boring that you find yourself gazing over into the corner of the room, your eyes fixated on a piece of lint and you start to zone out
Well like many bloggers..DIYers I have a 9 to 5. And sometimes I find myself daydreaming….about wood (yes wood, doubt judge me), woodworking and other DIY projects I could do around the house. Well one day I was in one of those meetings when I started doodling on a sticky note. I wasn’t really paying attention to what I was drawing. It was kind of my pen moving and my eyes fixated on a piece of lint in the corner. So then the meeting ends, I get back to my desk and I look down at my notes.
Huh. It looked like alphabet blocks. Made sense given at the time it felt like I was dreaming alphabet blocks. Also at the time I was trying to decide what to make for a good friend who is having a little girl. With all of my friends having babies I was running out of ideas for interesting gifts. I had made baby blanket ladders, alphabet wooden blocks and artwork for a nursery. Then it hit me. Why not make a play table inspired by alphabet blocks. So I went back home, made a few more sketches and I must say…I don’t always pat myself on the back, but I was very proud of the outcome of this project.
Ok people…you know the deal…Let’s Get Dirty!
Cost $75-90
Step 1: Materials
1 - 4x8 sheets of plywood
7 - 1x2x8
1 - 2x3x8 for the base support
2 -1x3x8
Mini L brackets
Paint, stickers and stencils for decoration
Step 2: Cuts & Dimensions
Step 3: Build. Table Top
So for the table top I'm using reclaimed wood paneling I had stored in my workshop. In true ToolBox Diva fashion I'm always looking for ways to reuse something oppose to just going out and buying it. One, its cheaper, two, it adds character, and three its just good for the Earth. However if your using plywood for the table top simply cut the plywood down to 24"x36."
Using pocket screws and wood glue attach the wood paneling for the table top.
Flip back over. Using a band sander and regular orbital sander, I sanded the surface of the wood paneling, removing the old varnish. The belt sander allows a deeper sanding than an orbital sander. The orbital sander is better for light sanding and finishing work.
Next trim the table top with the 1x3. Cut to size. I am using old wood from a previous project I had stored in my workshop.
Place a supporting 1x3 board down the center of the table top attaching with pocket screws.
Step 4: Build. the "legs"
Cut the box sides for the table base. I used my new Kreg Rip-Cut jig for the plywood cuts. It enabled me to make straight cuts using a circular saw.
To cut the sheet of plywood on the floor I created a platform using 2x4s covered by a 1"sheet of insulation. This lifts the plywood at a safe cutting height from the floor and it this low flat level it provides stability when cutting such a large piece of wood. Starting with the bottom 8 1/2" x 8 1/2 piece start attaching the sides of the boxes in accordance to the cut diagram for the 4 boxes. This projects moves faster with a nail gun. However, it can be completed with a hammer and nails.
Use a Carpenter's square to ensure each corner of the boxes are square and lined up correctly.
Step 5: Trimming.
Once the boxes are assembled trim the four sides of each box with the 1x2. Normally I would say cut to measure, but I'll provide the trim measurements I came up with. This is in order of first, second, third, & forth meaning just go in order of what side you touch first to last.
Side 1: 2 - 7" & 2 - 10" cuts
Sides 2 & 3: 2 - 7" & 2 - 10 3/4" cuts
Side 4: 2 - 7" & 2 - 11 1/2" cuts
Attach the trim using a brad nailer. Note that the two boxes at the top didn't have a horizontal top trim. I wasn't necessary given the table top would cover that portion of the boxes.
Step 6: Attaching the Boxes and Legs.
Attach 1 corner brace to each side of the top boxes. This will be used to attach the "legs" to the table top.
Also note its not necessary to cover the top box with a top panel piece. It will be attached to the table top.
Place the two top boxes a top the bottom box at an angle. Using wood screws attach the two boxes for each "leg" Then turn over and attach the "legs" to the table top by using a 3/4" screw to tie in the corner braces.
Step 7: Sand.
Now fill in the nail holes and imperfections with wood filler.
Once the wood filler is set, sand and prep for paint.
Step 8: Add Support Beams.
Once I started to look at the table I started to think of how a toddler would use this table....I realized he or she would probably try to sit on top of it. .....SOOO I flipped it back over and added 2 long 2x3 boards connecting the "legs" at the bottom.
Make sure the 2x3 boards hang 1" out from the bottom of the bottom boxes on either sides. Attach using corner braces and wood screws. The using pocket screws add 2 - 8" 2x3s on either sides of those boards to add additional support.
Step 9: Decorate It. Love It!
Now flip back over and LET YOUR CREATIVE JUICES FLOW!
Paint the top in a chalkboard paint. Paint the boxes for a girl's space, a boy's room or make it unisex. Use stencils, stickers, vinyl adhesives or just draw within each box freehand. Make decorating the play table a family affair. Enjoy and introduce your children to feeling wooden alphabet blocks brought to your childhood.
Till Next Time! T.
Check out the Alphabet Blocks Storage Ottomans to complete your play table set.
Click HERE for more information on ToolBox Divas and other DIY projects.
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
